Hello!
I’ve had this issue for quite a while but it would be nice to fix it.
Wifi is working fine, then, after closing the lid and reopening the wifi is hardblocked. There is no hard switch to press to get it back on.
I’ve tried adding acpi stuff to grub, fiddled with systemd, following discussions on this forum and others, but to no avail.
Not sure what the problem is. The driver is a few up from the device but not a clue if that’s relevant at all.
Anyone got any ideas? Thank you
Maybe this helps:
inxi -Fxxxza
Kernel: 6.6.3-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: hpet,acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=23bf8d97-4fcf-48b2-ab14-e5c2f052c373 rw loglevel=3 nowatchdog
nvme_load=YES
Desktop: i3 v: 4.23 info: i3bar vt: 7 dm: 1: LightDM v: 1.32.0 2: SDDM
note: stopped Distro: EndeavourOS base: Arch Linux
Type: Laptop System: LENOVO product: 3045CTO v: ThinkPad X121e
serial: Chassis: type: 10 serial:
Mobo: LENOVO model: 3045CTO serial: UEFI: LENOVO
v: 8QET23WW (1.07 ) date: 06/16/2011
Battery:
ID-1: BAT1 charge: 0 Wh condition: N/A/28.9 Wh volts: N/A min: 11.1
model: SANYO 42T4953 type: Unknown serial: status: not charging
Info: model: Intel Core i3-2357M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache:
L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 838 high: 955 min/max: 800/1300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 955 2: 800 3: 800 4: 800
bogomips: 10380
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Vulnerabilities:
Type: gather_data_sampling status: Not affected
Type: itlb_multihit status: KVM: VMX unsupported
Type: l1tf mitigation: PTE Inversion
Type: mmio_stale_data status: Unknown: No mitigations
Type: spec_rstack_overflow status: Not affected
prctl
sanitization
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Lenovo driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: LVDS-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0116
class-ID: 0300
Device-2: Suyin Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.4:3 chip-ID: 064e:e285
class-ID: 0e02 serial:
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2 driver: X:
loaded: intel unloaded: modesetting alternate: fbdev,vesa dri: i965
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS1 model: AU Optronics 0x315c built: 2010
res: 1366x768 hz: 60 dpi: 133 gamma: 1.2 size: 260x140mm (10.24x5.51")
diag: 294mm (11.6") ratio: 16:9 modes: 1366x768
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast surfaceless: drv: crocus x11: drv: crocus
inactive: gbm,wayland
API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 3000 (SNB
GT2) device-ID: 8086:0116 memory: 1.46 GiB unified: yes
Device-1: Intel 6 Series/C200 Series Family High Definition Audio
vendor: Lenovo 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
API: ALSA v: k6.6.3-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
status: off 2: wireplumber status: active 3: pipewire-alsa type: plugin
Device-1: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0
chip-ID: 10ec:8176 class-ID: 0280
IF: wlan0 state: up mac:
Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: Lenovo
driver: atl1c v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 08:00.0 chip-ID: 1969:1083 class-ID: 0200
IF: enp8s0 state: down mac:
Bluetooth:
Device-1: Broadcom BCM2045B (BDC-2.1) driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.6:4
chip-ID: 0a5c:217f class-ID: fe01 serial:
Report: btmgmt ID: hci0 rfk-id: 1 state: down bt-service: disabled
Local Storage: total: 298.09 GiB used: 12.46 GiB (4.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS723232A7A364
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: fw-rev: B70B scheme: GPT
ID-1: / raw-size: 73.06 GiB size: 70.86 GiB (96.99%) used: 12.45 GiB (17.6%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 6.2 MiB (2.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: yes
compressor: zstd max-pool: 20%
ID-1: swap-1 type: partition size: 6.24 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 58.0 C mobo: 0.0 C
Fan Speeds (rpm): cpu: 503 fan-2: 503
Processes: 176 Uptime: 10m wakeups: 0 Memory: total: 3 GiB
available: 2.82 GiB used: 1.28 GiB (45.2%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages:
pm: pacman pkgs: 988 libs: 261 tools: yay Shell: Bash v: 5.2.21
running-in: xfce4-terminal inxi: 3.3.31
Cheers!
