Hello. My WiFi has stopped connecting automatically after a recent update. The NetworkManager applet just circles and then doesn’t connect. However, it will connect if I remove the entry using Edit Connections, and retype the WiFi password.
I am using the rtl88x2bu-dkms-git driver from the AUR. I did reinstall the driver to see if that was the problem.
Any help would be appreciated!
https://aur.archlinux.org/packages/rtl88x2bu-dkms-git
journal could give some info about what is going wrong… could be also something related to users keyring?
open a terminal and proceed: journalctl -f while it spins and can not connect…
removed your private data from the log… it was not meant to be posted… only as a hint on how to find out what is going nuts for you…
looks like device is get into powesaving mode after it fails to connect
NetworkManager[513]: [1673184146.9135] device (wlan0): Activation: (wifi) association took too long
NetworkManager[513]: [1673184146.9135] device (wlan0): state change: config → failed (reason ‘no-secrets’, sys-iface-state: ‘managed’)
NetworkManager[513]: [1673184146.9138] manager: NetworkManager state is now DISCONNECTED
kernel: start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
kernel: RTW: nolinked power save leave
kernel: RTW: WARN _beamforming_leave: XXXX is neither beamforming ee or er!!
kernel: RTW: ERROR Free disconnecting network of scanned_queue failed due to pwlan == NULL
Thanks for the help and suggestion. The driver you suggested does log in automatically, although it takes over 60 seconds to do so after boot-up. Is there a way I can speed that up?
no clue … again log could tell what happens…
Is the log safe to post with SSID redacted?
generally unsave… uuids and ips and stuff should never be posted public
