Wifi dongle not detected help wanted
i just bought a
brand: tp-link
model: TX20U PLUS
name AX1800 dual attenas high gain wireless usb adapter
it detects it but cant use it it connects disconnects then connects with correct name then nothing work wifi related
@memphis_cult
Can you post the output from lsusb
Edit: Waiting for the output but it’s possibly a realtek chip.
@memphis_cult
Try installing rtl8852au-dkms
yay -S rtl8852au-dkms
Then reboot!
Edit: It may also be a mediatek chip so if you could provide the output from the above command first would be helpful.
i will try that and come back
Bus 001 Device 002: ID 0bda:c811 Realtek Semiconductor Corp. 802.11ac NIC
No AUR package found for rtl8852au-dkms
there is nothing to do
[cortix@cortix ~]$ yay rtl8852
7 aur/8852bu-dkms-git 1.15.7.112.2-1 (+1 0.00) (Orphaned)
Kernel modules and firmware for RealTek RTL8852bu
6 aur/8852be-dkms-git 1.15.10.0.5.0.4-1 (+1 0.00)
Realtek RTL8852BE Wi-Fi driver for Radxa.
5 aur/rtl8852cu-dkms-git 1.0.0.3.a246437-1 (+0 0.00)
Kernel module for USB WiFi Adapters that use the RTL8852CU and RTL8832CU Chipsets
4 aur/rtl8852bu-dkms-git 1.19.3.r6.8b02a65-1 (+1 0.00) (Orphaned) (Out-of-date: 2025-03-15)
Kernel module for Realtek RTL8852BU / RTL8832BU WiFi chipset
3 aur/rtl8852cu-dkms-morrownr-git 20250701-1 (+1 0.43)
Realtek RTL8852CU WiFi driver (DKMS, morrownr’s fork, git version)
2 aur/rtl8852au-dkms-git r110.db4fa82-1 (+4 0.60)
The WiFi driver for Realtek chipsets RTL8832AU and RTL8852AU (e.g. ASUS USB-AX56, D-Link DW-AX1850, TP-Link AX1800)
1 aur/rtl8852cu-git 1.0.0.3.a246437-1 (+0 0.00)
Linux Driver for USB WiFi Adapters that use the RTL8852CU and RTL8832CU Chipsets
i think its 2
Sorry,
I meant yay -S rtl8852au-dkms-git
i tried did not work i saw the mistake its ok
