In KDE, my network manager cannot connect to wifi or wired. I’ve disabled the firewall. I’ve rebooted and restarted network manager with systemctl. Nothing works.
Using journalctl, I can see that a network IP address was negotiated and my host appears on my LAN. The connections settings still shows as ‘connecting’. Journal isn’t very clear on the problem. There does seem to be a disconnect logged.
What can I do to restore my wifi connection?
What is the networkmanager version you have?
pacman -Q networkmanager
Not saying that this is the case but it may be related to this:
The issue discussed in the thread above should be fixed by now in version 1.46.0-2
Thank you. I connected to my hotspot and upgraded and rebooted. Problem solved ![]()
