Wifi disconnects and reconnects frequently
My wifi becomes connecting and disconnecting again and which is very annoying to work with specifically while watching videos online
Here, is the log, for
sudo dmesg | eos-sendlog
http://ix.io/4yK4
and also
sudo systemctl list-unit-files --state=enabled
http://ix.io/4yK6
I don’t know where the issue happens whether it’s based on power manager conflict and any other stuff
ps aux | grep power
http://ix.io/4yK7
and also network manager log
sudo journactl -b | grep wlan0
http://ix.io/4yK8
Are you dual booting with Windows?
nope I have fully booted with linux
hardware address with driver
http://ix.io/4yKf
It looks like it’s using 2.4 Ghz. Is it able to connect to 5.0 Ghz? I see this in the logs.
 10.547129] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   10.547135] cfg80211: failed to load regulatory.db
But my WiFi uses only 2.4GHz band support, It doesn’t have 5GHz support
Okay just asking.
https://wiki.archlinux.org/title/Network_configuration/Wireless#Random_disconnections
@Vishnu105
What does this show?
iw reg get
http://ix.io/4yKL
and also I have resolved my issue with this by installing ‘iw’ on my machine with adding rules on /etc/udev/rules.d/81-wifi-powersave.rules
ACTION=="add", SUBSYSTEM=="net", KERNEL=="wl*", RUN+="/usr/bin/iw dev $name set power_save on"
