I’m on EoS latest!
all packages are up to date
the command journalctl -p 3 -xb gives me this error ( only this error)
‘‘wpa_supplicant[709]: bgscan simple: Failed to enable signal strength monitoring’’
I have continuous disconnections from my line !
I can only solve it momentarily by rebooting the pc ( but then on reboot the problem recurs )
I am using mate as a DE!
Some additional info regarding the pc in question:
Kernel: 6.7.9-arch1-1 arch: x86_64 bits: 64
Desktop: MATE v: 1.26.2 Distro: EndeavourOS
Type: Laptop System: TOSHIBA product: Satellite Pro C660 v: PSC0RE-02200RIT
Mobo: TOSHIBA
UEFI-[Legacy]: TOSHIBA v: 1.80 date: 05/17/11
Info: dual core model: Intel Core i3 M 380 bits: 64 type: MT MCP cache:
L2: 512 KiB
Speed (MHz): avg: 1065 min/max: 933/2533 cores: 1: 1463 2: 933 3: 933
4: 933
Device-1: Intel Core Processor Integrated Graphics driver: i915 v: kernel
Device-2: Chicony CNF9055 Toshiba Webcam driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.11 driver: X: loaded: modesetting
dri: crocus gpu: i915 resolution: 1366x768~60Hz
API: EGL v: 1.5 drivers: crocus,swrast platforms: x11,surfaceless,device
API: OpenGL v: 4.5 compat-v: 2.1 vendor: intel mesa v: 24.0.2-arch1.2
renderer: Mesa Intel HD Graphics (ILK)
Device-1: Intel 5 Series/3400 Series High Definition Audio
driver: snd_hda_intel
API: ALSA v: k6.7.9-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.0.3 status: active
Device-1: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce
IF: wlan0 state: up mac:
Local Storage: total: 596.17 GiB used: 48.42 GiB (8.1%)
ID-1: /dev/sda vendor: Toshiba model: MK6475GSX size: 596.17 GiB
ID-1: / size: 588.2 GiB used: 48.42 GiB (8.2%) fs: btrfs dev: /dev/sda1
ID-2: /home size: 588.2 GiB used: 48.42 GiB (8.2%) fs: btrfs
dev: /dev/sda1
ID-3: /var/log size: 588.2 GiB used: 48.42 GiB (8.2%) fs: btrfs
dev: /dev/sda1
ID-1: swap-1 type: partition size: 7.97 GiB used: 0 KiB (0.0%)
dev: /dev/sda2
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 4 GiB note: est. available: 3.63 GiB used: 1.3 GiB (35.9%)
At least you would be in Full duplex instead of slowing down on Wifi. A quick “plaster” to help you experiment with your configs to make that Half duplex dial in.
Of course, knowledgeable members with experience might point you in a faster direction
I apologize if I reply with some delay and thank you for the info but I forgot to write that both arch references and your advice did not solve my problem!
I wrote here precisely because all attempts have not brought positive effects
