I did add nohwcrypt
as mentioned here:
But I will gladly try again with ps_enable
too.
I did add nohwcrypt
as mentioned here:
too.
Just to make sure: The correct path is /etc/modprobe.d/ath9k.conf
not /etc/modprob.d/ath9k.conf
right?
Yes, sorry if i had a typo?
In regards to the bluetooth. Have you tried modprobe ath9k btcoex_enable=1
According to Linux Wireless.
Bluetooth coexistence has to be manually enabled when loading ath9k by setting the btcoex_enable module parameter. I am not sure if this is the chip you have exactly.
http://linuxwireless.sipsolutions.net/en/users/Drivers/ath9k/btcoex/
Edit: The new site is here.
Well, that worked out quiet well. My speed is now up to a stable 31Mbps. It’s not as fast as the live-session, but faster than before and seems more stable too, so thanks for that. I added it to my ath9k.conf
Maybe bluetooth is at the core of my problem, as it is disabled by default on the live-session. I had to install some packages and enable it manually after installation too.
I’m glad this worked. There are so many different chips used out there and different manufacturers. I like to look at the hardware and know what chip the device is using and go from there. Some WIFi have integrated Bluetooth as yours and this is a single band 2.4 Ghz. Others have both 2.4 and 5.0 Ghz Sometimes it is a matter of trial and error.
Edit: Bluetooth wasn’t being turned on by default In EndeavourOS and the packages had to be installed. Now i think the Bluetooth packages are there but not activated?
I was curious and just deactivated my Bluetooth. The speed is now up at ~40Mbps as the live session. So I guess my chip has to split up between the two services a little in general, but enabling coexisting did help a lot. So, I think I’m going with this. Thanks a lot
Your welcome. I agree with that analogy as it has to share across the signal band and also consume power at the same time.
So, I think we are done here now. Thanks to you all very much
I will leave my ath9k.conf here for others to find and mark this as solved
My ath9k.conf
saved at /etc/modprobe.d/
## ath9k (Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter)
## Available Parameters ( /sbin/modinfo ath9k | grep ^parm: )
# debug: Debugging mask (uint)
# nohwcrypt: Disable hardware encryption (int)
# blink: Enable LED blink on activity (int)
# led_active_high: Invert LED polarity (int)
# btcoex_enable: Enable wifi-BT coexistence (int)
# bt_ant_diversity: Enable WLAN/BT RX antenna diversity (int)
# ps_enable: Enable WLAN PowerSave (int)
# use_chanctx: Enable channel context for concurrency (int)
# use_msi: Use MSI instead of INTx if possible (int)
## Suggested settings
# nohwcrypt=1
# btcoex_enable=0
# ps_enable=0
## Seen elsewhere
## Active Options
options ath9k nohwcrypt=1 btcoex_enable=1 ps_enable=0
