Hello!
I noticed during some tests on the live ISO, there is both mousepad (xfce notepad) and leafpad (from lxde project if I’m right).
Why both? I know they are both lightweight, but this is a duplicate. Any explanation?
Thanks!
Hello!
Thanks!
Mousepad is provided by Xfce and leafpad by us. There was a problem with mousepad not working in the earlier releases, but it might be fixed with Xfce 4.14, so maybe it is worth to re-examen.
Indeed. Some tests will be needed
problem was if you do sudo mousepad xxx.txt in root, it couldn’t do. some issue with xfconf.
thats why leafpad in for that.
Edit: the bug is, Mousepad is not fixed on current dbus. when you install dbus-x11 the root wil run with mousepad. but that path is no good ![]()
only way to use root with mousepad, if you create an allias in .bashrc
alias rootpad=‘sudo dbus-launch mousepad’
this way you can run root ![]()
edit : and running with thunar & pkexec should be around :https://gist.github.com/cvetan/91dd566b45a816ee91501856e6644df0) some pieces and chunks : bad idea btw
The problem still persists.
Mousepad needs a workaround like @ringo mentioned.
Leafpad is not so heavy if stil persist on mousepad, can also make a script call mpad, with dbus-launch mousepad. , You can do sudo mpad , thats also a simple workaround you can leafpad out if needed, buts to confused in mather of things i think
also had to to do on dbus , manjaro stil using dbus-x11 in arch thats decapriated
