White outline above taskbar (KDE Plasma)
I just noticed a white outline appeared above my taskbar:
kde-taskbar-whiteoutline
I’ve tried looking for a related setting but can’t seem to find it. I found an older picture of the desktop and it doesn’t appear there:
old-setup
I’m running KDE Plasma version 5.21.5 now with Framework 5.82.0 and QT 5.15.2 if that helps.
I don’t seem to have it on mine. It may have something to do with your settings, what icons and or theme you are using? :thinking:
I’m using Breeze Dark for basically everything except for the login screen. For that, I’m using this
Are you able to just right click on the task bar, edit panel and change the size to cover the white outline?
I thought I’d be able to do the same but I ended up just making it worse haha. I just re-installed an all is well, thanks for the responses!
That’s strange. :thinking:
