While watching movie on vlc and upgrading system or installing some packages makes the video and audio struck or slow
While watching movie on vlc and upgrading or installing packages in parallel makes the movie slow and some audio glitches.
The slowdown and glitches stops once the upgrade or package installation completed.
System Info:
  Kernel: 5.4.153-1-lts54 x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts54
  root=UUID=140ff4ed-d56a-4a46-8c79-545720e64c75 rw rootflags=subvol=@ quiet
  loglevel=3 nowatchdog
  Desktop: Cinnamon 5.0.5 tk: GTK 3.24.30 vt: 7 dm: LightDM 1.30.0
  Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
  serial: <filter> Chassis: type: 9 serial: <filter>
  Mobo: Dell model: 0D53F5 v: A00 serial: <filter> UEFI: Dell v: 2.15.0
  date: 06/16/2021
  Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
  arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142) stepping: 9
  microcode: EA cache: L2: 3 MiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  bogomips: 21599
  Speed: 2500 MHz min/max: 400/2500 MHz Core speeds (MHz): 1: 2500 2: 2500
  3: 2500 4: 2500
  Vulnerabilities: Type: itlb_multihit status: KVM: Split huge pages
  Type: l1tf
  mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
  Type: spec_store_bypass
  mitigation: Speculative Store Bypass disabled via prctl and seccomp
  Type: spectre_v1
  Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional,
  IBRS_FW, STIBP: conditional, RSB filling
  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
  Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 /
  Radeon 520 Mobile]
  vendor: Dell driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
  chip-ID: 1002:6660 class-ID: 0380
  Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 1-5:3 chip-ID: 0bda:5769 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org 1.20.13 driver: loaded: ati,intel,radeon
  unloaded: fbdev,modesetting,vesa resolution: <missing: xdpyinfo>
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
  driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
  class-ID: 0403
  Sound Server-1: ALSA v: k5.4.153-1-lts54 running: yes
  Sound Server-2: JACK v: 1.9.19 running: no
  Sound Server-3: PulseAudio v: 15.0 running: yes
  Sound Server-4: PipeWire v: 0.3.38 running: no
  Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000
  bus-ID: 02:00.0 chip-ID: 8086:3165 class-ID: 0280
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
  driver: N/A modules: r8169 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8136
  class-ID: 0200
Bluetooth:
  Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
  v: 0.8 bus-ID: 1-8:5 chip-ID: 8087:0a2a class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: not found
  Local Storage: total: 931.51 GiB used: 200.83 GiB (21.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
  size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
  speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM3 scheme: GPT
  ID-1: / raw-size: 100.1 GiB size: 100.1 GiB (100.00%)
  used: 9.57 GiB (9.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /boot/efi raw-size: 250.2 MiB size: 246.3 MiB (98.45%)
  used: 562 KiB (0.2%) fs: vfat dev: /dev/sda3 maj-min: 8:3
  ID-3: /home raw-size: 831.17 GiB size: 831.17 GiB (100.00%)
  used: 191.26 GiB (23.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-4: /var/log raw-size: 100.1 GiB size: 100.1 GiB (100.00%)
  System Temperatures: cpu: 52.0 C mobo: 51.0 C gpu: radeon temp: 48.0 C
  Fan Speeds (RPM): cpu: 2576
  Processes: 218 Uptime: 42m wakeups: 1 Memory: 7.65 GiB
  used: 1.65 GiB (21.6%) Init: systemd v: 249 tool: systemctl Compilers:
  gcc: 11.1.0 Packages: pacman: 914 lib: 247 Shell: Bash v: 5.1.8
  running-in: gnome-terminal inxi: 3.3.06
you are updating by command or using something else?
Could be you are on software renderer instead of hardware after installing mesa -demos you can check it with: sudo pacman -S mesa-demos
glxinfo | egrep "OpenGL vendor|OpenGL renderer" what should echo your graphic hardware or using inxi:
inxi -G
Also seems you are on a Notebook? with dual graphics/hybrid graphics ? so you may need to check here:
Have you tried newer kernels lately?
No Iam on LTS 5.4
command output of glxinfo | egrep "OpenGL vendor|OpenGL renderer" :
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) HD Graphics 620 (KBL GT2)
output of inxi -G :
  Device-1: Intel HD Graphics 620 driver: i915 v: kernel
  Radeon 520 Mobile]
  OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.3
so looks like you are running on integrated intel gpu for rendering
Yes
it should in normal case not result in such a huge system lag.
could you send the boot log:
journalctl -b -0 | eos-sendlog
and you can try if you can catch some error from live journal while this happen:
watching video while updating/installing and after this pastebin the log:
journalctl --since "10 minutes ago" | eos-sendlog
sorry I just reinstalled endeavour os with KDE, for now everything is going fine.
Thanks everyone for responding to this post.
If I face same issue in future I will refer to everyone’s respons.
Thank you all!
Are you now using the latest kernel?
no now Iam on 5.10 LTS
previously I was on 5.4 LTS
I also used 5.13 on my previous install.
and using amdgpu driver cause radeon driver is causing problem In all kernels and Distros.
except 5.4 LTS, only in this kernel my DGPU is not causing problem.
In every other kernel if I use my DPU to lauch any app system freezes.
System Info:
System:    Kernel: 5.10.74-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
           parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=5e661246-d90d-4c96-8a84-121093f54b16 rw
           rootflags=subvol=@ quiet loglevel=3 nowatchdog
           Desktop: KDE Plasma 5.23.1 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: EndeavourOS base: Arch Linux
Machine:   Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A serial: <filter> Chassis: type: 9 serial: <filter>
           Mobo: Dell model: 0D53F5 v: A00 serial: <filter> UEFI: Dell v: 2.15.0 date: 06/16/2021
Battery:   ID-1: BAT0 charge: 36.2 Wh (100.0%) condition: 36.2/41.4 Wh (87.3%) volts: 16.7 min: 14.8
           model: LGC-LGC2.80 DELL 7PY0D0A type: Li-ion serial: <filter> status: Full
CPU:       Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake note: check family: 6
           model-id: 8E (142) stepping: 9 microcode: EA cache: L2: 3 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21599
           Speed: 3103 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 3103 2: 3100 3: 3100 4: 3100
           Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp
           Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics:  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916
           class-ID: 0300
           Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile] vendor: Dell driver: amdgpu
           v: kernel alternate: radeon bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380
           Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:3 chip-ID: 0bda:5769 class-ID: 0e02
           serial: <filter>
           Display: x11 server: X.org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati,intel
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel alternate: snd_soc_skl
           bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
           Sound Server-1: ALSA v: k5.10.74-1-lts running: yes
Network:   Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 8086:3165
           class-ID: 0280
           Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: d000
           bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
           IF: enp3s0 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-8:5 chip-ID: 8087:0a2a
           class-ID: e001
           Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled rfk-block: hardware: no software: no
Drives:    Local Storage: total: 931.51 GiB used: 189.25 GiB (20.3%)
           ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB block-size: physical: 4096 B
           logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM3 scheme: GPT
Partition: ID-1: / raw-size: 100.1 GiB size: 100.1 GiB (100.00%) used: 7.08 GiB (7.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
           ID-2: /boot/efi raw-size: 250.2 MiB size: 246.3 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat dev: /dev/sda3
           maj-min: 8:3
           ID-3: /home raw-size: 831.17 GiB size: 831.17 GiB (100.00%) used: 182.17 GiB (21.9%) fs: btrfs dev: /dev/sda2
           maj-min: 8:2
           ID-4: /var/log raw-size: 100.1 GiB size: 100.1 GiB (100.00%) used: 7.08 GiB (7.1%) fs: btrfs dev: /dev/sda1
           maj-min: 8:1
Swap:      Alert: No swap data was found.
Sensors:   System Temperatures: cpu: 50.0 C mobo: 49.0 C gpu: amdgpu temp: 48.0 C
           Fan Speeds (RPM): cpu: 2569
Info:      Processes: 210 Uptime: 27m wakeups: 1 Memory: 7.64 GiB used: 1.54 GiB (20.2%) Init: systemd v: 249 tool: systemctl
           Compilers: gcc: 11.1.0 Packages: pacman: 919 lib: 210 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
