Which usb wireless adapter?
hello :slight_smile:
I would like to buy an USB wireless adapter, that is working out of the box, without installing aur/git drivers :slight_smile:
(since unfortunately my new laptop has a wireless card not recognized)
please could you recommend me one?
thanks :slight_smile:
Once it was supported why would have been dropped
Check here :
A new laptop that it isn’t recognized? What laptop might that be? What is the make and model?
HP ProBook 445 G9
and is Ubuntu certified Hardware…
The first step is to check whether the appropriate kernel modules have been loaded. According to your computer’s product page, your HP ProBook has a Qualcomm Atheros Wireless Network Adapter, in which case the right kernel module is ath11k_pci
Can you run:
$ lsmod | grep ath
Also, does the Wifi connection work on a Live USB?
While you’re at it, you might as well post the result of:
$ lspci -nn | grep -i net
As @anthony93 pointed out above.
If it is in fact this chip? Qualcomm Inc Atheros QCNFA765 (17cb:1103 105b:e0c4)
Looks like it uses ath11k which is new. It’s probably missing the firmware. Maybe?
Please check dmesg
sudo dmesg | eos-sendlog
Also check
 lsmod | grep ath
Edit: The module i think is ath11k_pci
Check if the firmware is installed.
Should be possibly
/lib/firmware/ath11k/WCN6855/hw2.0
Edit: I have it on my system
Did you try using modprobe?
Edit: This is a bit dated.
Edit2: As far as i can tell it should be working by now.
thanks, but it should be the rtl8852be
not the one listed there
Okay because you have two different posts. So on the other post i said you just need to install
yay -S rtl8852be-dkms-git
Reboot
@manuel also passed that on in the same post so you must have missed it?
