or do not install pip… and wait till package gets updated on the repo… instead of installing something in a way you are not using …
Yup, I’m a conky -addict for monitoring my systems, and that’s beautiful!
Would you mind sharing your code for that conky? I’m curious how you implement some of those features/ layouts, especially in the processors + temp + storage section …
you are simply a conkist
The actual ‘connections’ to the information are normal enough - but the look is all down to the conkywx library of goodies (AUR) - set of mostly lua based extensions that also provide the weather. Same guy maintains conky-cairo for sensible lua integration…
Don’t think I am ready to be a conkyst-ador just yet.
Maybe that should be a word
While I love conky, it pulls me into a tweak-fest where I never seem to stop. lol
Conky here too…I build them/use them & post on GnomeLook.org–I have about 20 different ones I’ve posted–the highest rated one is: https://www.pling.com/p/1337738/
I use btop
or bpytop
. Terminal-based, good UI, configurable, and low resource usage.
I mostly use htop
, sometimes ps
I keep hearing about conky. Sure beats my barren desktop space.
from the cmd line, I prefer glances.
Me too.
I am having no issues with Glances v3.2.4 with PsUtil v5.9.0
Evisum
I mostly use htop on every newly installed machine.
None tbh. Am I a bad people now because I’m not interested in such geeky stuffz?
I guess I had htop installed on another machine, looked at it once, mumbled something in my imaginary neckbeard, closed it and never looked at it again.
But if you insist, I just installed htop:
And? Pray tell, what am I sposed to see there?
That shows that your system is running fine.
For me, I would only use a process monitor like htop if things weren’t running fine. In that case, the process monitor can help you figure out what it wrong.
I agree. I don’t believe in running something like that all the time just to make my desktop look interesting. If it’s going to be a hot summer, I’ll only run sensors on another desktop to check the temperatures, but that’s not absolutely necessary because my computer is very well cooled.
Thank you.I kinda knew it already since it’s Manjaro, so nothing can really go wrong.
