What is this UNKNOWN process with PID 0 making network connections?
I can see this process making connections, sending and receiving data:
Should I nuke my system and burn my laptop? ![]()
There are two tasks with specially distinguished process IDs: PID 0 is used for swapper or sched, which is part of the kernel and is a process that runs on a CPU core whenever that CPU core has nothing else to do.[1] Linux also calls the threads of this process idle tasks.
The UNKNOWN process with PID 0 making network connections is usually seen when monitoring tools show a network connection, but cannot associate it with a specific user-space process, resulting in the PID being reported as 0 or as âUNKNOWNâ. In most operating systems, including Arch Linux and other Linux distributions, PID 0 does not correspond to a typical user-space process, but is reserved for kernel-related tasks or system-level operations.
https://www.baeldung.com/linux/network-processes-with-no-pid
Thanks for the reply! But as I understand, it wouldnât need to make network connections. Or am I wrong?
Thanks @swh! That makes sense, at least somewhat, to me. Time to dig deeper and educate myself.
Looks like it may be related to firewall rules and/or VPN (openvpn).
I use both. Looking furtherâŚ
