lew
August 15, 2025, 8:27pm
1
Wanted to update my system today and pacman asked me if I wanted to
:: Import PGP key 06313911057DD5A8, "George Hu <integral@archlinux.org>"? [Y/n]
So I looked that up and it turns out George Hu’s key is not signed by any of the 5 arch linux master keys .
But there is no way to update without importing that key. Even though I do not have any of the packages that George Hu is a maintainer on.
I obviously have no reason not to trust this key and it’s probably fine. (Probably much safer than installing anything from the AUR.)
It does seem a little strange that I can’t update without trusting that key.
dalto
August 15, 2025, 8:31pm
2
Can you share that message in full context? i.e. the full terminal output including the command you ran.
Also, please don’t post terminal output as an image.
lew
August 16, 2025, 4:28am
4
It’s a code block.
$ sudo pacman -Syu [22:17:32]
[sudo] password for lew:
core is up to date
extra is up to date
warning: yad: local (14.1-2.1) is newer than extra (14.1-2)
resolving dependencies...
warning: dependency cycle detected:
warning: phonon-qt6-vlc will be installed before its phonon-qt6 dependency
warning: plasma-workspace will be installed before its plasma-integration dependency
warning: rubygems will be installed before its ruby dependency
Packages (680) ...[[Cut these and posted them below to save space.]]
Total Installed Size: 8756,71 MiB
Net Upgrade Size: 75,43 MiB
:: Proceed with installation? [Y/n]
(680/680) checking keys in keyring [-----------------------------------------------------------------------------------------------] 100%
downloading required keys...
Packages to be upgraded
7zip-25.01-1 aalib-1.4rc5-19 acpi-1.8-2 ada-3.2.7-1 alsa-card-profiles-1:1.4.7-1 archlinux-keyring-20250807.1-1 at-spi2-core-2.56.4-1 attica-6.17.0-1 aurorae-6.4.4-1 automake-1.18.1-1 avahi-1:0.9rc2-1 bash-5.3.3-2 bind-9.20.11-1
binutils-2.45+r29+g2b2e51a31ec7-1 breeze-6.4.4-1 breeze-icons-6.17.0-1 btop-1.4.4-1 ca-certificates-mozilla-3.114-1 catch2-3.9.1-1 clang-20.1.8-1 compiler-rt-20.1.8-1 containerd-2.1.4-1 curl-8.15.0-1 debugedit-5.2-1
device-mapper-2.03.34-1 djvulibre-3.5.29-1 dmenu-5.4-1 docker-1:28.3.3-1 docker-compose-2.39.2-1 dracut-108-1 e2fsprogs-1.47.3-1 egl-wayland-4:1.1.20-1 electron35-35.7.4-1 electron36-36.7.4-1 enchant-2.8.12-1
extra-cmake-modules-6.17.0-1 fcft-3.3.2-1 ffmpeg-2:7.1.1-5 ffmpeg4.4-4.4.6-2 file-5.46-5 findutils-4.10.0-3 firefox-141.0.3-1 flameshot-13.0.1-1 fluidsynth-2.4.7-1 frameworkintegration-6.17.0-1 fzf-0.65.1-1
gcc-15.2.1+r22+gc4e96a094636-1 gcc-libs-15.2.1+r22+gc4e96a094636-1 gettext-0.26-1 git-2.50.1-3 git-annex-10.20250721-33 git-lfs-3.7.0-1 glances-4.3.3-1 glibc-2.42+r17+gd7274d718e6f-1 glslang-1:1.4.321.0-1 gnutls-3.8.10-1
go-2:1.24.6-1 gperftools-2.17-1 graphite-1:1.3.14-5 grim-1.5.0-2 gsfonts-20200910-5 gst-libav-1.26.5-1 gst-plugin-gtk-1.26.5-1 gst-plugin-pipewire-1:1.4.7-1 gst-plugins-bad-1.26.5-1 gst-plugins-bad-libs-1.26.5-1
gst-plugins-base-1.26.5-1 gst-plugins-base-libs-1.26.5-1 gst-plugins-ugly-1.26.5-1 gstreamer-1.26.5-1 gtk3-1:3.24.50-1 harfbuzz-11.4.1-1 harfbuzz-icu-11.4.1-1 haskell-adjunctions-4.4.3-35 haskell-aeson-2.1.2.1-119
haskell-aeson-pretty-0.8.10-79 haskell-ansi-terminal-1.0.2-34 haskell-ansi-terminal-types-0.11.5-74 haskell-ansi-wl-pprint-1.0.2-23 haskell-asn1-encoding-0.9.6-270 haskell-asn1-parse-0.9.5-269 haskell-asn1-types-0.3.4-248
haskell-assoc-1.1.1-39 haskell-async-2.2.5-127 haskell-attoparsec-0.14.4-114 haskell-attoparsec-aeson-2.1.0.0-103 haskell-attoparsec-iso8601-1.1.0.0-92 haskell-auto-update-0.1.6-388 haskell-aws-0.24.1-15
haskell-base-compat-batteries-0.12.3-26 haskell-base-orphans-0.9.1-27 haskell-base16-bytestring-1.0.2.0-119 haskell-base64-0.4.2.4-114 haskell-base64-bytestring-1.2.1.0-148 haskell-bencode-0.6.1.1-240 haskell-bifunctors-5.6.1-6
haskell-binary-orphans-1.0.5-49 haskell-bitvec-1.1.4.0-5 haskell-blaze-builder-0.4.3-5 haskell-blaze-html-0.9.2.0-40 haskell-blaze-markup-0.8.3.0-50 haskell-bsb-http-chunked-0.0.0.4-434 haskell-call-stack-0.4.0-260
haskell-case-insensitive-1.2.1.0-248 haskell-cassava-0.5.4.0-8 haskell-citeproc-0.8.1.1-5 haskell-clientsession-0.9.3.0-3 haskell-clock-0.8.4-73 haskell-colour-2.3.6-284 haskell-commonmark-0.2.5.1-37
haskell-commonmark-extensions-0.2.5.3-35 haskell-commonmark-pandoc-0.2.2.1-64 haskell-comonad-5.0.9-60 haskell-concurrent-output-1.10.21-48 haskell-conduit-1.3.6.1-60 haskell-conduit-extra-1.3.8-2 haskell-constraints-0.13.4-98
haskell-criterion-1.6.2.0-4 haskell-criterion-measurement-0.2.2.0-67 haskell-cryptohash-md5-0.11.101.0-141 haskell-cryptohash-sha1-0.11.101.0-122 haskell-crypton-1.0.1-5 haskell-crypton-connection-0.4.2-5 haskell-crypton-x509-1.7.7-1
haskell-crypton-x509-store-1.6.10-11 haskell-crypton-x509-system-1.6.7-71 haskell-crypton-x509-validation-1.6.13-25 haskell-cryptonite-0.30-112 haskell-cryptonite-conduit-0.2.2-718 haskell-css-text-0.1.3.0-325
haskell-data-default-0.7.1.1-361 haskell-data-default-instances-containers-0.1.0.3-1 haskell-data-default-instances-dlist-0.0.1.2-42 haskell-data-default-instances-old-locale-0.0.1.1-1 haskell-data-fix-0.3.4-15 haskell-dav-1.3.4-778
haskell-dbus-1.3.2-1 haskell-dense-linear-algebra-0.1.0.0-371 haskell-digest-0.0.2.0-1 haskell-digits-0.3.1-60 haskell-distributive-0.6.2.1-260 haskell-djot-0.1.1.3-41 haskell-dlist-1.0-292 haskell-doclayout-0.4.0.1-73
haskell-doctemplates-0.11.0.1-4 haskell-easy-file-0.2.5-60 haskell-edit-distance-0.2.2.1-247 haskell-email-validate-2.3.2.21-41 haskell-emojis-0.1.4.1-21 haskell-fast-logger-3.2.3-4 haskell-fdo-notify-0.3.1-840
haskell-feed-1.3.2.1-254 haskell-file-embed-0.0.16.0-1 haskell-filepath-bytestring-1.4.2.1.13-43 haskell-foldable1-classes-compat-0.1-207 haskell-free-5.2-57 haskell-generically-0.1.1-27 haskell-git-lfs-1.2.5-2
haskell-glob-0.10.2-129 haskell-gridtables-0.1.0.0-92 haskell-haddock-library-1.11.0-107 haskell-hashable-1.4.4.0-111 haskell-hinotify-0.4.2-21 haskell-hjsmin-0.2.1-27 haskell-hourglass-0.2.12-285 haskell-hslua-2.3.0-125
haskell-hslua-aeson-2.3.0.1-107 haskell-hslua-classes-2.3.0-121 haskell-hslua-core-2.3.1-113 haskell-hslua-list-1.1.3-51 haskell-hslua-marshalling-2.3.1-73 haskell-hslua-module-doclayout-1.1.1-26 haskell-hslua-module-path-1.1.1-27
haskell-hslua-module-system-1.1.1-36 haskell-hslua-module-text-1.1.0.1-99 haskell-hslua-module-version-1.1.1-69 haskell-hslua-module-zip-1.1.2-5 haskell-hslua-objectorientation-2.3.0-117 haskell-hslua-packaging-2.3.1-82
haskell-hslua-repl-0.1.2-79 haskell-hslua-typing-0.1.1-75 haskell-http-api-data-0.5.1-121 haskell-http-client-0.7.18-26 haskell-http-client-restricted-0.1.0-113 haskell-http-client-tls-0.3.6.4-52 haskell-http-conduit-2.3.9.1-95
haskell-http-date-0.0.11-177 haskell-http-media-0.8.1.1-53 haskell-http-types-0.12.4-73 haskell-http2-4.1.4-15 haskell-hunit-1.6.2.0-302 haskell-indexed-traversable-0.1.4-115 haskell-indexed-traversable-instances-0.1.2-64
haskell-integer-logarithms-1.0.4-20 haskell-invariant-0.6.4-28 haskell-iproute-1.7.15-23 haskell-ipynb-0.2-212 haskell-jira-wiki-markup-1.5.1-61 haskell-juicypixels-3.3.9-30 haskell-kan-extensions-5.2.7-18
haskell-language-javascript-0.7.1.0-199 haskell-lens-5.3-7 haskell-lexer-1.1.2-1 haskell-libyaml-0.1.4-88 haskell-lift-type-0.1.2.0-39 haskell-lifted-base-0.2.3.12-313 haskell-lpeg-1.0.4-66 haskell-lua-2.3.3-38
haskell-math-functions-0.3.4.4-117 haskell-memory-0.18.0-47 haskell-microlens-0.4.14.0-1 haskell-microlens-mtl-0.2.1.0-1 haskell-microlens-th-0.4.3.17-4 haskell-microstache-1.0.2.3-141 haskell-mmorph-1.2.1-1
haskell-monad-control-1.0.3.1-147 haskell-monad-logger-0.3.42-36 haskell-mono-traversable-1.0.21.0-62 haskell-mwc-random-0.15.2.0-29 haskell-network-3.1.4.0-60 haskell-network-bsd-2.8.1.0-250 haskell-network-multicast-0.3.2-252
haskell-network-uri-2.6.4.2-72 haskell-onetuple-0.4.2-60 haskell-optparse-applicative-0.18.1.0-27 haskell-ordered-containers-0.2.4-39 haskell-os-string-2.0.7-52 haskell-pandoc-3.1.12.1-115 haskell-pandoc-lua-engine-0.2.1.2-201
haskell-pandoc-lua-marshal-0.2.7.1-10 haskell-pandoc-server-0.1.0.5-227 haskell-pandoc-types-1.23.1-93 haskell-pem-0.2.4-325 haskell-persistent-2.14.5.1-121 haskell-persistent-sqlite-2.13.1.0-255 haskell-pretty-show-1.10-18
haskell-prettyprinter-1.7.1-238 haskell-prettyprinter-ansi-terminal-1.1.3-253 haskell-prettyprinter-compat-ansi-wl-pprint-1.0.2-24 haskell-primitive-0.9.0.0-10 haskell-profunctors-5.6.3-16 haskell-psqueues-0.2.8.1-27
haskell-quickcheck-2.14.3-173 haskell-random-1.2.1.3-6 haskell-recv-0.1.1-10 haskell-reflection-2.1.9-15 haskell-regex-tdfa-1.3.2.4-21 haskell-resource-pool-0.2.3.2-340 haskell-resourcet-1.2.6-98 haskell-rio-0.1.22.0-169
haskell-safe-0.3.21-44 haskell-safe-exceptions-0.1.7.4-66 haskell-sandi-0.5-524 haskell-scientific-0.3.7.0-161 haskell-securemem-0.1.10-328 haskell-semialign-1.3-53 haskell-semigroupoids-6.0.1-35 haskell-servant-0.20.2-71
haskell-servant-client-0.20-158 haskell-servant-client-core-0.20.2-73 haskell-servant-server-0.20.2-110 haskell-shakespeare-2.1.3-10 haskell-simple-sendfile-0.2.32-122 haskell-singleton-bool-0.1.7-18 haskell-skylighting-0.14.1.1-81
haskell-skylighting-core-0.14.1.1-79 haskell-skylighting-format-ansi-0.1-213 haskell-skylighting-format-blaze-html-0.1.1.3-67 haskell-skylighting-format-context-0.1.0.2-177 haskell-skylighting-format-latex-0.1-212
haskell-socks-0.6.1-277 haskell-some-1.0.6-11 haskell-split-0.2.5-48 haskell-splitmix-0.1.0.5-99 haskell-statistics-0.16.3.0-43 haskell-streaming-commons-0.2.3.0-23 haskell-strict-0.5-99 haskell-string-conversions-0.4.0.1-210
haskell-syb-0.7.2.4-68 haskell-tagsoup-0.14.8-265 haskell-tasty-1.4.3-163 haskell-tasty-hunit-0.10.1-137 haskell-tasty-quickcheck-0.10.2-504 haskell-tasty-rerun-1.1.19-59 haskell-temporary-1.3-712 haskell-texmath-0.12.8.7-61
haskell-text-conversions-0.3.1.1-103 haskell-text-icu-0.8.0.5-42 haskell-text-short-0.1.6-44 haskell-th-compat-0.1.6-22 haskell-th-lift-instances-0.1.20-90 haskell-these-1.2.1-38 haskell-time-compat-1.9.6.1-147
haskell-time-manager-0.0.1-85 haskell-tls-1.9.0-40 haskell-tls-session-manager-0.0.4-438 haskell-toml-parser-2.0.1.2-2 haskell-torrent-10000.1.3-64 haskell-transformers-base-0.4.6-147 haskell-typed-process-0.2.13.0-15
haskell-typst-0.5.0.2-53 haskell-unicode-collation-0.1.3.6-57 haskell-unicode-data-0.5.0-18 haskell-unicode-transforms-0.4.0.1-115 haskell-uniplate-1.6.13-274 haskell-unix-compat-0.7.4-6 haskell-unix-time-0.4.17-8
haskell-unliftio-0.2.25.1-28 haskell-unordered-containers-0.2.20-78 haskell-utf8-string-1.0.2-194 haskell-uuid-1.3.16-27 haskell-uuid-types-1.0.6-37 haskell-vault-0.3.1.5-236 haskell-vector-0.13.2.0-47
haskell-vector-algorithms-0.9.1.0-50 haskell-vector-binary-instances-0.2.5.2-159 haskell-vector-th-unbox-0.2.2-372 haskell-void-0.7.3-248 haskell-wai-3.2.4-86 haskell-wai-app-static-3.1.9-137 haskell-wai-cors-0.2.7-422
haskell-wai-extra-3.1.17-46 haskell-wai-logger-2.5.0-72 haskell-warp-3.3.30-168 haskell-warp-tls-3.4.9-92 haskell-witherable-0.4.2-169 haskell-xml-conduit-1.9.1.4-73 haskell-xml-hamlet-0.5.0.2-286 haskell-xss-sanitize-0.3.7.2-66
haskell-yaml-0.11.11.2-132 haskell-yesod-1.6.2.1-351 haskell-yesod-core-1.6.27.1-15 haskell-yesod-form-1.7.9-51 haskell-yesod-persistent-1.6.0.8-412 haskell-yesod-static-1.6.1.0-868 haskell-zip-archive-0.4.3.2-43
haskell-zlib-0.7.0.0-6 highway-1.3.0-1 hslua-cli-1.4.3-19 hwinfo-25.0-2 i3lock-2.15-3 imagemagick-7.1.2.1-1 intel-ucode-20250812-1 iproute2-6.16.0-2 jre-openjdk-24.0.2.u12-1 julia-2:1.11.6-1 kactivitymanagerd-6.4.4-1
karchive-6.17.0-1 kauth-6.17.0-1 kbookmarks-6.17.0-1 kcmutils-6.17.0-1 kcodecs-6.17.0-1 kcolorscheme-6.17.0-1 kcompletion-6.17.0-1 kconfig-6.17.0-1 kconfigwidgets-6.17.0-1 kcontacts-1:6.17.0-1 kcoreaddons-6.17.0-1 kcrash-6.17.0-1
kdbusaddons-6.17.0-1 kde-cli-tools-6.4.4-1 kdeclarative-6.17.0-1 kdecoration-6.4.4-1 kded-6.17.0-1 kdesu-6.17.0-1 kdnssd-6.17.0-1 keepassxc-2.7.10-3 kglobalaccel-6.17.0-1 kglobalacceld-6.4.4-1 kguiaddons-6.17.0-1
kholidays-1:6.17.0-1 ki18n-6.17.0-1 kiconthemes-6.17.0-1 kidletime-6.17.0-1 kio-6.17.0-1 kirigami-6.17.0-1 kirigami-addons-1.9.0-1 kitemmodels-6.17.0-1 kitemviews-6.17.0-1 kjobwidgets-6.17.0-1 knewstuff-6.17.0-1
knotifications-6.17.0-1 knotifyconfig-6.17.0-1 kpackage-6.17.0-1 kparts-6.17.0-1 kpeople-6.17.0-1 kpipewire-6.4.4-1 kpty-6.17.0-1 kquickcharts-6.17.0-1 krunner-6.17.0-1 kscreen-6.4.4-1 kscreenlocker-6.4.4-1 kservice-6.17.0-1
kstatusnotifieritem-6.17.0-1 ksvg-6.17.0-1 ksystemstats-6.4.4-1 ktexteditor-6.17.0-1 ktextwidgets-6.17.0-1 kunitconversion-6.17.0-1 kuserfeedback-6.17.0-1 kwallet-6.17.0-1 kwayland-6.4.4-1 kwidgetsaddons-6.17.0-1 kwin-6.4.4-1
kwindowsystem-6.17.0-1 kxmlgui-6.17.0-1 layer-shell-qt-6.4.4-1 ldb-2:4.22.3-1 leancrypto-1.5.1-1 less-1:679-1 libadwaita-1:1.7.6-1 libass-0.17.4-1 libblastrampoline-5.14.0-1 libdeflate-1.24-1 libdovi-3.3.2-1 libelf-0.193-5
libev-4.33-4 libfabric-2.2.0-1 libfakekey-0.3-4 libgexiv2-0.14.6-1 libgphoto2-2.5.32-3 libheif-1.20.2-1 libimagequant-4.4.0-1 libimobiledevice-1.3.0-17 libinih-61-1 libjxl-0.11.1-4 libkscreen-6.4.4-1 libksysguard-6.4.4-1
libldap-2.6.10-2 libmm-glib-1.24.2-1 libmpeg2-0.5.1-11 libnftnl-1.3.0-1 libnghttp3-1.11.0-1 libngtcp2-1.13.0-2 libnm-1.54.0-1 libnvme-1.15-1 libogg-1.3.6-1 libopenmpt-0.8.2-1 libpipewire-1:1.4.7-1 libplacebo-7.351.0-2
libplasma-6.4.4-1 libreoffice-still-24.8.7-5 libshout-1:2.4.6-5 libsoup-2.74.3-4 libsysprof-capture-48.0-7 libtool-2.5.4+r62+g6389dce8-1 libvips-8.17.1-1 libvlc-3.0.21-27 libwbclient-2:4.22.3-1 libwebp-1.6.0-1 libx86emu-3.7-2
libxkbcommon-1.11.0-1 libxkbcommon-x11-1.11.0-1 libxml2-2.14.5-1 lightdm-slick-greeter-2.2.2-1 linux-6.16.arch2-1 linux-api-headers-6.16-1 linux-firmware-20250808-1 linux-firmware-amdgpu-20250808-1 linux-firmware-atheros-20250808-1
linux-firmware-broadcom-20250808-1 linux-firmware-cirrus-20250808-1 linux-firmware-intel-20250808-1 linux-firmware-mediatek-20250808-1 linux-firmware-nvidia-20250808-1 linux-firmware-other-20250808-1 linux-firmware-radeon-20250808-1
linux-firmware-realtek-20250808-1 linux-firmware-whence-20250808-1 linux-headers-6.16.arch2-1 lld-20.1.8-1 llvm-20.1.8-1 llvm-julia-libs-16.0.6.3-3 llvm-libs-20.1.8-1 lsof-4.99.5-2 luajit-2.1.1753364724-1 lvm2-2.03.34-1
lxqt-powermanagement-2.2.1-1 man-pages-6.15-1 mbedtls-3.6.4-1 mercurial-7.1-1 mesa-1:25.1.7-1 meson-1.8.3-1 milou-6.4.4-1 mjpegtools-2.2.1-3 modemmanager-1.24.2-1 modemmanager-qt-6.17.0-1 mpg123-1.33.1-1 mpv-1:0.40.0-5
neon-0.35.0-1 neovim-0.11.3-1 net-snmp-5.9.4-7 networkmanager-1.54.0-1 networkmanager-openvpn-1.12.2-1 nftables-1:1.1.4-1 node-gyp-11.3.0-1 nodejs-24.6.0-1 noto-fonts-1:2025.08.01-1 npm-11.5.2-1 nspr-4.37-1 nss-3.114-1
oath-toolkit-2.6.13-1 ocean-sound-theme-6.4.4-1 ollama-0.11.4-1 openexr-3.3.5-1 openmpi-5.0.8-2 openssh-10.0p1-4 openssl-3.5.2-1 openucx-1.19.0-1 otf-font-awesome-7.0.0-4 pambase-20250719-1 pandoc-cli-3.1.12.1-141
parallel-20250722-2 perl-5.42.0-1 perl-alien-build-2.84-3 perl-alien-libxml2-0.20-3 perl-capture-tiny-0.50-3 perl-clone-0.47-2 perl-dbi-1.647-2 perl-encode-locale-1.05-14 perl-error-0.17030-2 perl-ffi-checklib-0.31-7
perl-file-listing-6.16-5 perl-file-which-1.27-7 perl-html-parser-3.83-2 perl-html-tagset-3.24-3 perl-http-cookiejar-0.014-4 perl-http-cookies-6.11-3 perl-http-daemon-6.16-5 perl-http-date-6.06-4 perl-http-message-7.00-2
perl-http-negotiate-6.01-15 perl-image-exiftool-13.30-3 perl-io-html-1.004-7 perl-libwww-6.79-2 perl-lwp-mediatypes-6.04-7 perl-mailtools-2.22-2 perl-net-http-6.23-5 perl-path-tiny-0.150-1 perl-timedate-2.33-8 perl-try-tiny-0.32-3
perl-uri-5.32-2 perl-www-robotrules-6.02-15 perl-xml-libxml-2.0210-4 perl-xml-parser-2.47-3 perl-xml-writer-0.900-5 perl-yaml-libyaml-0.904.0-2 phonon-qt6-4.12.0-5 phonon-qt6-vlc-0.12.0-5 pinentry-1.3.2-1 pipewire-1:1.4.7-1
pipewire-alsa-1:1.4.7-1 pipewire-audio-1:1.4.7-1 pipewire-jack-1:1.4.7-1 pipewire-pulse-1:1.4.7-1 pixman-0.46.4-1 plasma-activities-6.4.4-1 plasma-activities-stats-6.4.4-1 plasma-integration-6.4.4-1 plasma-workspace-6.4.4-1
plasma5support-6.4.4-1 poppler-25.08.0-1 poppler-glib-25.08.0-1 poppler-qt5-25.08.0-1 poppler-qt6-25.08.0-1 print-manager-1:6.4.4-1 prison-6.17.0-1 protobuf-31.1-2 purpose-6.17.0-1 pv-1.9.34-1 python-3.13.6-1 python-build-1.3.0-1
python-certifi-2025.08.03-1 python-charset-normalizer-3.4.3-1 python-cryptography-45.0.5-1 python-gpgme-2.0.0-1 python-greenlet-3.2.4-1 python-orjson-3.11.1-1 python-pip-25.2-1 python-platformdirs-4.3.8-1 python-setproctitle-1.3.6-1
python-termcolor-3.1.0-1 python-tomli-2.2.1-1 python-trove-classifiers-2025.8.6.13-1 python-typing_extensions-4.14.1-1 qqc2-breeze-style-6.4.4-1 qqc2-desktop-style-6.17.0-1 qt6-base-6.9.1-5 qt6-declarative-6.9.1-2
qt6-webengine-6.9.1-2 readline-8.3.001-1 ruby-3.4.5-1 ruby-bundled-gems-3.4.5-1 ruby-debug-1.11.0-1 ruby-default-gems-3.4.5-1 ruby-rake-13.2.1-5 ruby-rdoc-6.14.0-1 ruby-stdlib-3.4.5-1 rubygems-3.6.9-1 rust-1:1.89.0-1 sbc-2.1-1
sdl2-compat-2.32.56-2 sdl3-3.2.20-1 shaderc-2025.3-1 signal-desktop-7.66.0-1 slang-2.3.3-4 smbclient-2:4.22.3-1 solid-6.17.0-1 sonnet-6.17.0-1 spirv-tools-1:1.4.321.0-1 sqlite-3.50.4-1 suitesparse-7.11.0-1 svt-av1-3.1.0-1
switchboard-8.0.3-1 syncthing-2.0.1-1 syndication-6.17.0-1 syntax-highlighting-6.17.0-1 systemd-257.8-2 systemd-libs-257.8-2 systemd-sysvcompat-257.8-2 tdb-1.4.14-1 telegram-desktop-6.0.2-1 tevent-1:0.17.1-1 threadweaver-6.17.0-1
thunar-4.20.4-1 thunderbird-141.0-1 tor-0.4.8.17-2 tree-sitter-0.25.8-1 tree-sitter-vim-0.7.0-1 twolame-0.4.0-4 unrar-1:7.1.10-1 unzip-6.0-23 vapoursynth-72-1 vim-9.1.1623-1 vim-runtime-9.1.1623-1 virtualbox-7.2.0-1
virtualbox-host-modules-arch-7.2.0-1 vlc-3.0.21-27 vlc-cli-3.0.21-27 vlc-gui-qt-3.0.21-27 vlc-plugin-a52dec-3.0.21-27 vlc-plugin-alsa-3.0.21-27 vlc-plugin-archive-3.0.21-27 vlc-plugin-dav1d-3.0.21-27 vlc-plugin-dbus-3.0.21-27
vlc-plugin-dbus-screensaver-3.0.21-27 vlc-plugin-faad2-3.0.21-27 vlc-plugin-flac-3.0.21-27 vlc-plugin-gnutls-3.0.21-27 vlc-plugin-inflate-3.0.21-27 vlc-plugin-journal-3.0.21-27 vlc-plugin-jpeg-3.0.21-27 vlc-plugin-lua-3.0.21-27
vlc-plugin-mpg123-3.0.21-27 vlc-plugin-ogg-3.0.21-27 vlc-plugin-opus-3.0.21-27 vlc-plugin-png-3.0.21-27 vlc-plugin-pulse-3.0.21-27 vlc-plugin-shout-3.0.21-27 vlc-plugin-speex-3.0.21-27 vlc-plugin-tag-3.0.21-27
vlc-plugin-theora-3.0.21-27 vlc-plugin-twolame-3.0.21-27 vlc-plugin-vorbis-3.0.21-27 vlc-plugin-vpx-3.0.21-27 vlc-plugin-xml-3.0.21-27 vlc-plugins-base-3.0.21-27 vlc-plugins-video-output-3.0.21-27 vulkan-headers-1:1.4.321.0-1
vulkan-icd-loader-1.4.321.0-1 wayland-1.24.0-1 webkit2gtk-2.48.5-1 webkit2gtk-4.1-2.48.5-1 x264-3:0.164.r3108.31e19f9-3 xdg-desktop-portal-kde-6.4.4-1 xorg-xdpyinfo-1.4.0-1 xterm-401-1 yt-dlp-2025.07.21-1 zathura-0.5.12-1
zlib-ng-2.2.5-1
</details>
lew
August 16, 2025, 4:33am
5
Thanks!
Good to have an official source.
I wonder why the key is still listed as completely unsigned on archlinux.org/master-keys/ , in that thread are multiple people who have master keys.
SdW
August 16, 2025, 9:50am
6
I wondered about the new signature, too. Thanks, @MichelN for following it up.
Before you received the signature warning, when was the last time you updated from the Arch repository?
For myself, I have had the odd time where the archlinux-keyring was not up to date. So then I would get messages to update a particular packages pgp key. This was an infrequent used /updated system.
NX-01
August 16, 2025, 3:49pm
8
Hm, everytime my keyring was out of date the update failed.
lew
August 16, 2025, 4:46pm
9
It was one two weeks ago, but I updated the keyring manually after i got this message.
We would have to see the specific error you faced. An out of date key ring has a different error where the specific package key does not match … I believe this is when you are prompted to import a key.
I have had systems which have not updated for past 6 months and the arch-keyring will not update unless I disabled the signature check when updating the one arch keyring file.
Source:
https://wiki.archlinux.org/title/Pacman/Package_signing
Did you run ‘sudo pacman -Sy --needed archlinux-keyring && pacman -Su’
Source:
