Welcome endeavour os launcher won't load
when i click on the endeavour os launcher icon and i excute it… i see the icon by my curor bouncing up and down and it looks like it’s going to load but then it doesn’t. last issue on my computer i swear :wink:
i tried uninstalling it and reinstalling it with no luck
i am thinking it could be a permissions problem? but idk
  1. In a terminal window, enter
eos-welcome
and see if it throws any error codes.
  1. If not, check and see if your network is working properly. The internet not available will also affect welcome.
  2. Make sure EndeavourOS is totally up to date. When pacman changed from 6.1.0-3 to version 7.0 it introduced problems with welcome that have since been corrected.
Pudge
➜  ~ eos-welcome
Welcome app is disabled. To start it anyway, use option --enable (temporarily: --once).
➜  ~ eos-welcome --enable
➜  ~ eos-welcome
➜  ~ sudo pacman -Syu
[sudo] password for fj:
 endeavouros is up to date
 core is up to date
 extra is up to date
 multilib is up to date
 there is nothing to do
➜  ~ eos-welcome
hmmmm my internet is working fine i think… hmmmm still won’t load. thanks though for the help…
in a Terminal window enter
Then try to bring up welcome. This should work.
Pudge
If welcome has been disabled, you can have it running once without enabling it using
eos-welcome --once
no luck but thanks :-\
idk if this has anything to do with it but i found my welcome.conf file. i tried deleting it and opening the welcome app like i do when my-weather-indicator isn’t working which sometimes fixes it to no avail.
in the welcome.conf file it has this: EOS_WELCOME_ACTIVE_TAB_NUMBER=2 # default: 2 (=After Install)
just wondering if it has anything to do with why it won’t open or if i can tinker with it to make it work but i doubt it. just a thought.
your greeter config file should be in your ~/.config folder
EOS-greeter.conf
its contents for me
## Configuration file for eos-welcome.
# Note: using bash syntax.
# 'Greeter'   values: enable or disable.
# 'OnceDaily' values: no or yes; yes means eos-welcome is shown only once a day.
# 'LastCheck' values: automatically filled by eos-welcome.
Greeter=disable
OnceDaily=no
LastCheck=0
darnit on further inspection mine looks exactly like yours does. darn i really thought that might be the solution but thankx. really apreciate your taking the time to share that with me.
The default values in EOS-greeter.conf are:
Greeter=enable
OnceDaily=no
LastCheck=0
The enable above means Welcome starts when logging in.
Open up a terminal and run journalctl -f
Then open another terminal and run eos-welcome --once
Post the output you see in the terminal that is running journalctl, it may hold some clues as to what is (or isn’t) happening when you try to load the welcome app.
Sep 30 12:55:14 whitewolf conky[2666474]: No players found
Sep 30 12:55:14 whitewolf conky[2666475]: No players found
Sep 30 12:55:14 whitewolf conky[2666476]: No players found
Sep 30 12:55:14 whitewolf conky[2666478]: No players found
Sep 30 12:55:14 whitewolf conky[2666486]: No players found
Sep 30 12:55:14 whitewolf conky[2666490]: No players found
Sep 30 12:55:14 whitewolf conky[2666493]: No players found
Sep 30 12:55:14 whitewolf conky[2666498]: No players found
Sep 30 12:55:14 whitewolf conky[2666507]: No players found
Sep 30 12:55:14 whitewolf conky[2666503]: No players found
Sep 30 12:55:14 whitewolf conky[2666514]: No players found
Sep 30 12:55:14 whitewolf conky[2666511]: No players found
Sep 30 12:55:14 whitewolf conky[2666520]: No players found
Sep 30 12:55:14 whitewolf conky[2666525]: No players found
Sep 30 12:55:15 whitewolf conky[2666544]: No players found
Sep 30 12:55:15 whitewolf conky[2666545]: No players found
Sep 30 12:55:15 whitewolf conky[2666550]: No players found
Sep 30 12:55:15 whitewolf conky[2666546]: No players found
Sep 30 12:55:15 whitewolf conky[2666557]: No players found
Sep 30 12:55:15 whitewolf conky[2666567]: No players found
Sep 30 12:55:15 whitewolf conky[2666547]: No players found
Sep 30 12:55:15 whitewolf conky[2666562]: No players found
Sep 30 12:55:15 whitewolf conky[2666559]: No players found
Sep 30 12:55:15 whitewolf conky[2666578]: No players found
Sep 30 12:55:15 whitewolf conky[2666589]: No players found
Sep 30 12:55:15 whitewolf conky[2666580]: No players found
Sep 30 12:55:15 whitewolf conky[2666586]: No players found
Sep 30 12:55:15 whitewolf conky[2666593]: No players found
Sep 30 12:55:16 whitewolf conky[2666619]: No players found
Sep 30 12:55:16 whitewolf conky[2666621]: No players found
Sep 30 12:55:16 whitewolf conky[2666620]: No players found
Sep 30 12:55:16 whitewolf conky[2666622]: No players found
Sep 30 12:55:16 whitewolf conky[2666623]: No players found
Sep 30 12:55:16 whitewolf conky[2666627]: No players found
Sep 30 12:55:16 whitewolf conky[2666632]: No players found
Sep 30 12:55:16 whitewolf conky[2666635]: No players found
Sep 30 12:55:16 whitewolf conky[2666653]: No players found
Sep 30 12:55:16 whitewolf conky[2666656]: No players found
Sep 30 12:55:16 whitewolf conky[2666645]: No players found
Sep 30 12:55:16 whitewolf conky[2666665]: No players found
Sep 30 12:55:16 whitewolf conky[2666660]: No players found
Sep 30 12:55:16 whitewolf conky[2666670]: No players found
Sep 30 12:55:17 whitewolf conky[2666687]: No players found
Sep 30 12:55:17 whitewolf conky[2666691]: No players found
Sep 30 12:55:17 whitewolf conky[2666689]: No players found
Sep 30 12:55:17 whitewolf conky[2666707]: No players found
Sep 30 12:55:17 whitewolf conky[2666721]: No players found
Sep 30 12:55:17 whitewolf conky[2666703]: No players found
Sep 30 12:55:17 whitewolf conky[2666722]: No players found
Sep 30 12:55:17 whitewolf conky[2666728]: No players found
Sep 30 12:55:17 whitewolf conky[2666726]: No players found
Sep 30 12:55:17 whitewolf conky[2666744]: No players found
Sep 30 12:55:17 whitewolf conky[2666727]: No players found
Sep 30 12:55:17 whitewolf conky[2666749]: No players found
Sep 30 12:55:17 whitewolf conky[2666753]: No players found
Sep 30 12:55:17 whitewolf conky[2666754]: No players found
Sep 30 12:55:18 whitewolf conky[2666768]: No players found
Sep 30 12:55:18 whitewolf conky[2666769]: No players found
Sep 30 12:55:18 whitewolf conky[2666770]: No players found
Sep 30 12:55:18 whitewolf conky[2666772]: No players found
Sep 30 12:55:18 whitewolf conky[2666781]: No players found
Sep 30 12:55:18 whitewolf conky[2666790]: No players found
Sep 30 12:55:18 whitewolf conky[2666786]: No players found
Sep 30 12:55:18 whitewolf conky[2666793]: No players found
Sep 30 12:55:18 whitewolf conky[2666797]: No players found
Sep 30 12:55:18 whitewolf conky[2666800]: No players found
Sep 30 12:55:18 whitewolf conky[2666805]: No players found
Sep 30 12:55:18 whitewolf conky[2666812]: No players found
Sep 30 12:55:18 whitewolf conky[2666817]: No players found
Sep 30 12:55:18 whitewolf conky[2666807]: No players found
Sep 30 12:55:19 whitewolf conky[2666836]: No players found
Sep 30 12:55:19 whitewolf conky[2666838]: No players found
Sep 30 12:55:19 whitewolf conky[2666839]: No players found
Sep 30 12:55:19 whitewolf conky[2666837]: No players found
Sep 30 12:55:19 whitewolf conky[2666840]: No players found
Sep 30 12:55:19 whitewolf conky[2666848]: No players found
Sep 30 12:55:19 whitewolf conky[2666845]: No players found
Sep 30 12:55:19 whitewolf conky[2666854]: No players found
Sep 30 12:55:19 whitewolf conky[2666860]: No players found
Sep 30 12:55:19 whitewolf conky[2666868]: No players found
Sep 30 12:55:19 whitewolf conky[2666865]: No players found
Sep 30 12:55:19 whitewolf conky[2666883]: No players found
Sep 30 12:55:19 whitewolf conky[2666880]: No players found
Sep 30 12:55:19 whitewolf conky[2666873]: No players found
Sep 30 12:55:20 whitewolf conky[2667055]: No players found
Sep 30 12:55:20 whitewolf conky[2667053]: No players found
Sep 30 12:55:20 whitewolf conky[2667060]: No players found
Sep 30 12:55:20 whitewolf conky[2667067]: No players found
Sep 30 12:55:20 whitewolf conky[2667076]: No players found
Sep 30 12:55:20 whitewolf conky[2667057]: No players found
Sep 30 12:55:20 whitewolf conky[2667079]: No players found
Sep 30 12:55:20 whitewolf conky[2667087]: No players found
Sep 30 12:55:20 whitewolf conky[2667097]: No players found
Sep 30 12:55:20 whitewolf conky[2667103]: No players found
Sep 30 12:55:20 whitewolf conky[2667084]: No players found
Sep 30 12:55:20 whitewolf conky[2667105]: No players found
Sep 30 12:55:20 whitewolf conky[2667113]: No players found
Sep 30 12:55:20 whitewolf conky[2667117]: No players found
Sep 30 12:55:21 whitewolf conky[1737]: conky: statfs '/mnt/wd1tb': No such file or directory
Sep 30 12:55:21 whitewolf conky[2667249]: No players found
Sep 30 12:55:21 whitewolf conky[2667250]: No players found
Sep 30 12:55:21 whitewolf conky[2667251]: No players found
Sep 30 12:55:21 whitewolf conky[2667259]: No players found
Sep 30 12:55:21 whitewolf conky[2667270]: No players found
Sep 30 12:55:21 whitewolf conky[2667263]: No players found
Sep 30 12:55:21 whitewolf conky[2667280]: No players found
Sep 30 12:55:21 whitewolf conky[2667276]: No players found
Sep 30 12:55:21 whitewolf conky[2667272]: No players found
Sep 30 12:55:21 whitewolf conky[2667284]: No players found
Sep 30 12:55:21 whitewolf conky[2667288]: No players found
Sep 30 12:55:21 whitewolf conky[2667298]: No players found
Sep 30 12:55:21 whitewolf conky[2667302]: No players found
Sep 30 12:55:21 whitewolf conky[2667305]: No players found
Sep 30 12:55:22 whitewolf conky[2667317]: No players found
Sep 30 12:55:22 whitewolf conky[2667319]: No players found
Sep 30 12:55:22 whitewolf conky[2667320]: No players found
Sep 30 12:55:22 whitewolf conky[2667321]: No players found
Sep 30 12:55:22 whitewolf conky[2667330]: No players found
Sep 30 12:55:22 whitewolf conky[2667335]: No players found
Sep 30 12:55:22 whitewolf conky[2667340]: No players found
Sep 30 12:55:22 whitewolf conky[2667344]: No players found
Sep 30 12:55:22 whitewolf conky[2667348]: No players found
Sep 30 12:55:22 whitewolf conky[2667353]: No players found
Sep 30 12:55:22 whitewolf conky[2667354]: No players found
Sep 30 12:55:22 whitewolf conky[2667361]: No players found
Sep 30 12:55:22 whitewolf conky[2667365]: No players found
Sep 30 12:55:22 whitewolf conky[2667369]: No players found
Sep 30 12:55:23 whitewolf conky[2667383]: No players found
Sep 30 12:55:23 whitewolf conky[2667386]: No players found
Sep 30 12:55:23 whitewolf conky[2667385]: No players found
Sep 30 12:55:23 whitewolf conky[2667393]: No players found
Sep 30 12:55:23 whitewolf conky[2667411]: No players found
Sep 30 12:55:23 whitewolf conky[2667409]: No players found
Sep 30 12:55:23 whitewolf conky[2667401]: No players found
Sep 30 12:55:23 whitewolf conky[2667423]: No players found
Sep 30 12:55:23 whitewolf conky[2667419]: No players found
Sep 30 12:55:23 whitewolf conky[2667431]: No players found
Sep 30 12:55:23 whitewolf conky[2667428]: No players found
Sep 30 12:55:23 whitewolf conky[2667440]: No players found
Sep 30 12:55:23 whitewolf conky[2667436]: No players found
Sep 30 12:55:23 whitewolf conky[2667447]: No players found
Sep 30 12:55:24 whitewolf conky[2667463]: No players found
Sep 30 12:55:24 whitewolf conky[2667464]: No players found
Sep 30 12:55:24 whitewolf conky[2667466]: No players found
Sep 30 12:55:24 whitewolf conky[2667467]: No players found
Sep 30 12:55:24 whitewolf conky[2667475]: No players found
Sep 30 12:55:24 whitewolf conky[2667471]: No players found
Sep 30 12:55:24 whitewolf conky[2667483]: No players found
Sep 30 12:55:24 whitewolf conky[2667488]: No players found
Sep 30 12:55:24 whitewolf conky[2667492]: No players found
Sep 30 12:55:24 whitewolf conky[2667495]: No players found
Sep 30 12:55:24 whitewolf conky[2667503]: No players found
Sep 30 12:55:24 whitewolf conky[2667511]: No players found
Sep 30 12:55:24 whitewolf conky[2667507]: No players found
Sep 30 12:55:24 whitewolf conky[2667517]: No players found
Sep 30 12:55:25 whitewolf conky[2667538]: No players found
Sep 30 12:55:25 whitewolf conky[2667537]: No players found
Sep 30 12:55:25 whitewolf conky[2667547]: No players found
Sep 30 12:55:25 whitewolf conky[2667540]: No players found
Sep 30 12:55:25 whitewolf conky[2667544]: No players found
Sep 30 12:55:25 whitewolf conky[2667551]: No players found
Sep 30 12:55:25 whitewolf conky[2667558]: No players found
Sep 30 12:55:25 whitewolf conky[2667554]: No players found
Sep 30 12:55:25 whitewolf conky[2667562]: No players found
Sep 30 12:55:25 whitewolf conky[2667573]: No players found
Sep 30 12:55:25 whitewolf conky[2667569]: No players found
Sep 30 12:55:25 whitewolf conky[2667578]: No players found
Sep 30 12:55:25 whitewolf conky[2667582]: No players found
Sep 30 12:55:25 whitewolf conky[2667584]: No players found
Sep 30 12:55:26 whitewolf conky[2667607]: No players found
Sep 30 12:55:26 whitewolf conky[2667609]: No players found
Sep 30 12:55:26 whitewolf conky[2667613]: No players found
Sep 30 12:55:26 whitewolf conky[2667611]: No players found
Sep 30 12:55:26 whitewolf conky[2667618]: No players found
Sep 30 12:55:26 whitewolf conky[2667620]: No players found
Sep 30 12:55:26 whitewolf conky[2667633]: No players found
Sep 30 12:55:26 whitewolf conky[2667641]: No players found
Sep 30 12:55:26 whitewolf conky[2667626]: No players found
Sep 30 12:55:26 whitewolf conky[2667642]: No players found
Sep 30 12:55:26 whitewolf conky[2667647]: No players found
Sep 30 12:55:26 whitewolf conky[2667636]: No players found
Sep 30 12:55:26 whitewolf conky[2667653]: No players found
Sep 30 12:55:26 whitewolf conky[2667658]: No players found
Sep 30 12:55:26 whitewolf rtkit-daemon[1134]: Supervising 8 threads of 5 processes of 1 users.
Sep 30 12:55:27 whitewolf conky[2667698]: No players found
Sep 30 12:55:27 whitewolf conky[2667701]: No players found
Sep 30 12:55:27 whitewolf conky[2667700]: No players found
Sep 30 12:55:27 whitewolf conky[2667706]: No players found
Sep 30 12:55:27 whitewolf conky[2667712]: No players found
Sep 30 12:55:27 whitewolf conky[2667722]: No players found
Sep 30 12:55:27 whitewolf conky[2667713]: No players found
Sep 30 12:55:27 whitewolf conky[2667726]: No players found
Sep 30 12:55:27 whitewolf conky[2667718]: No players found
Sep 30 12:55:27 whitewolf conky[2667731]: No players found
Sep 30 12:55:27 whitewolf conky[2667743]: No players found
Sep 30 12:55:27 whitewolf conky[2667740]: No players found
Sep 30 12:55:27 whitewolf conky[2667748]: No players found
Sep 30 12:55:27 whitewolf conky[2667753]: No players found
Sep 30 12:55:28 whitewolf conky[2667768]: No players found
Sep 30 12:55:28 whitewolf conky[2667770]: No players found
Sep 30 12:55:28 whitewolf conky[2667769]: No players found
Sep 30 12:55:28 whitewolf conky[2667776]: No players found
Sep 30 12:55:28 whitewolf conky[2667778]: No players found
Sep 30 12:55:28 whitewolf conky[2667782]: No players found
Sep 30 12:55:28 whitewolf conky[2667792]: No players found
Sep 30 12:55:28 whitewolf conky[2667786]: No players found
Sep 30 12:55:28 whitewolf conky[2667802]: No players found
Sep 30 12:55:28 whitewolf conky[2667808]: No players found
Sep 30 12:55:28 whitewolf conky[2667799]: No players found
Sep 30 12:55:28 whitewolf conky[2667812]: No players found
Sep 30 12:55:28 whitewolf conky[2667820]: No players found
Sep 30 12:55:28 whitewolf conky[2667813]: No players found
Sep 30 12:55:29 whitewolf conky[2667837]: No players found
Sep 30 12:55:29 whitewolf conky[2667840]: No players found
Sep 30 12:55:29 whitewolf conky[2667842]: No players found
Sep 30 12:55:29 whitewolf conky[2667839]: No players found
Sep 30 12:55:29 whitewolf conky[2667866]: No players found
Sep 30 12:55:29 whitewolf conky[2667869]: No players found
Sep 30 12:55:29 whitewolf conky[2667859]: No players found
Sep 30 12:55:29 whitewolf conky[2667850]: No players found
Sep 30 12:55:29 whitewolf conky[2667882]: No players found
Sep 30 12:55:29 whitewolf conky[2667888]: No players found
Sep 30 12:55:29 whitewolf conky[2667891]: No players found
Sep 30 12:55:29 whitewolf conky[2667895]: No players found
Sep 30 12:55:29 whitewolf conky[2667898]: No players found
Sep 30 12:55:29 whitewolf conky[2667902]: No players found
Sep 30 12:55:30 whitewolf conky[2667917]: No players found
Sep 30 12:55:30 whitewolf conky[2667918]: No players found
Sep 30 12:55:30 whitewolf conky[2667919]: No players found
Sep 30 12:55:30 whitewolf conky[2667923]: No players found
Sep 30 12:55:30 whitewolf conky[2667927]: No players found
Sep 30 12:55:30 whitewolf conky[2667932]: No players found
Sep 30 12:55:30 whitewolf conky[2667933]: No players found
Sep 30 12:55:30 whitewolf conky[2667941]: No players found
Sep 30 12:55:30 whitewolf conky[2667937]: No players found
Sep 30 12:55:30 whitewolf conky[2667946]: No players found
Sep 30 12:55:30 whitewolf conky[2667960]: No players found
Sep 30 12:55:30 whitewolf conky[2667963]: No players found
Sep 30 12:55:30 whitewolf conky[2667966]: No players found
Sep 30 12:55:30 whitewolf conky[2667969]: No players found
Sep 30 12:55:31 whitewolf conky[2667982]: No players found
Sep 30 12:55:31 whitewolf conky[2667983]: No players found
Sep 30 12:55:31 whitewolf conky[2667985]: No players found
Sep 30 12:55:31 whitewolf conky[2667994]: No players found
Sep 30 12:55:31 whitewolf conky[2667989]: No players found
Sep 30 12:55:31 whitewolf conky[2667986]: No players found
Sep 30 12:55:31 whitewolf conky[2667998]: No players found
Sep 30 12:55:31 whitewolf conky[2668007]: No players found
Sep 30 12:55:31 whitewolf conky[2668018]: No players found
Sep 30 12:55:31 whitewolf conky[2668014]: No players found
Sep 30 12:55:31 whitewolf conky[2668022]: No players found
Sep 30 12:55:31 whitewolf conky[2668024]: No players found
Sep 30 12:55:31 whitewolf conky[2668029]: No players found
Sep 30 12:55:31 whitewolf conky[2668036]: No players found
Sep 30 12:55:32 whitewolf conky[2668050]: No players found
Sep 30 12:55:32 whitewolf conky[2668051]: No players found
Sep 30 12:55:32 whitewolf conky[2668060]: No players found
Sep 30 12:55:32 whitewolf conky[2668061]: No players found
Sep 30 12:55:32 whitewolf conky[2668052]: No players found
Sep 30 12:55:32 whitewolf conky[2668068]: No players found
Sep 30 12:55:32 whitewolf conky[2668075]: No players found
Sep 30 12:55:32 whitewolf conky[2668077]: No players found
Sep 30 12:55:32 whitewolf conky[2668081]: No players found
Sep 30 12:55:32 whitewolf conky[2668085]: No players found
Sep 30 12:55:32 whitewolf conky[2668086]: No players found
Sep 30 12:55:32 whitewolf conky[2668096]: No players found
Sep 30 12:55:32 whitewolf conky[2668103]: No players found
Sep 30 12:55:32 whitewolf conky[2668104]: No players found
Sep 30 12:55:33 whitewolf conky[2668115]: No players found
Sep 30 12:55:33 whitewolf conky[2668118]: No players found
Sep 30 12:55:33 whitewolf conky[2668116]: No players found
Sep 30 12:55:33 whitewolf conky[2668117]: No players found
Sep 30 12:55:33 whitewolf conky[2668123]: No players found
Sep 30 12:55:33 whitewolf conky[2668131]: No players found
Sep 30 12:55:33 whitewolf conky[2668135]: No players found
Sep 30 12:55:33 whitewolf conky[2668140]: No players found
Sep 30 12:55:33 whitewolf conky[2668143]: No players found
Sep 30 12:55:33 whitewolf conky[2668148]: No players found
Sep 30 12:55:33 whitewolf conky[2668153]: No players found
Sep 30 12:55:33 whitewolf conky[2668159]: No players found
Sep 30 12:55:33 whitewolf conky[2668166]: No players found
Sep 30 12:55:33 whitewolf conky[2668170]: No players found
Sep 30 12:55:34 whitewolf conky[2668183]: No players found
Sep 30 12:55:34 whitewolf conky[2668184]: No players found
Sep 30 12:55:34 whitewolf conky[2668185]: No players found
Sep 30 12:55:34 whitewolf conky[2668186]: No players found
Sep 30 12:55:34 whitewolf conky[2668191]: No players found
Sep 30 12:55:34 whitewolf conky[2668193]: No players found
Sep 30 12:55:34 whitewolf conky[2668198]: No players found
Sep 30 12:55:34 whitewolf conky[2668202]: No players found
Sep 30 12:55:34 whitewolf conky[2668212]: No players found
Sep 30 12:55:34 whitewolf conky[2668222]: No players found
Sep 30 12:55:34 whitewolf conky[2668228]: No players found
Sep 30 12:55:34 whitewolf conky[2668217]: No players found
Sep 30 12:55:34 whitewolf conky[2668238]: No players found
Sep 30 12:55:34 whitewolf conky[2668234]: No players found
Sep 30 12:55:35 whitewolf conky[1737]: conky: statfs '/mnt/wd1tb': No such file or directory
Sep 30 12:55:35 whitewolf conky[2668254]: No players found
Sep 30 12:55:35 whitewolf conky[2668251]: No players found
Sep 30 12:55:35 whitewolf conky[2668256]: No players found
Sep 30 12:55:35 whitewolf conky[2668261]: No players found
Sep 30 12:55:35 whitewolf conky[2668270]: No players found
Sep 30 12:55:35 whitewolf conky[2668278]: No players found
Sep 30 12:55:35 whitewolf conky[2668291]: No players found
Sep 30 12:55:35 whitewolf conky[2668292]: No players found
Sep 30 12:55:35 whitewolf conky[2668293]: No players found
Sep 30 12:55:35 whitewolf conky[2668301]: No players found
Sep 30 12:55:35 whitewolf conky[2668303]: No players found
Sep 30 12:55:35 whitewolf conky[2668307]: No players found
Sep 30 12:55:35 whitewolf conky[2668315]: No players found
Sep 30 12:55:35 whitewolf conky[2668311]: No players found
Sep 30 12:55:36 whitewolf conky[2668332]: No players found
Sep 30 12:55:36 whitewolf conky[2668334]: No players found
Sep 30 12:55:36 whitewolf conky[2668346]: No players found
Sep 30 12:55:36 whitewolf conky[2668338]: No players found
Sep 30 12:55:36 whitewolf conky[2668340]: No players found
Sep 30 12:55:36 whitewolf conky[2668348]: No players found
Sep 30 12:55:36 whitewolf conky[2668335]: No players found
Sep 30 12:55:36 whitewolf conky[2668354]: No players found
Sep 30 12:55:36 whitewolf conky[2668360]: No players found
Sep 30 12:55:36 whitewolf conky[2668367]: No players found
Sep 30 12:55:36 whitewolf conky[2668362]: No players found
Sep 30 12:55:36 whitewolf conky[2668374]: No players found
Sep 30 12:55:36 whitewolf conky[2668356]: No players found
Sep 30 12:55:36 whitewolf conky[2668381]: No players found
Sep 30 12:55:37 whitewolf conky[2668397]: No players found
Sep 30 12:55:37 whitewolf conky[2668398]: No players found
Sep 30 12:55:37 whitewolf conky[2668399]: No players found
Sep 30 12:55:37 whitewolf conky[2668400]: No players found
Sep 30 12:55:37 whitewolf conky[2668403]: No players found
Sep 30 12:55:37 whitewolf conky[2668414]: No players found
Sep 30 12:55:37 whitewolf conky[2668418]: No players found
Sep 30 12:55:37 whitewolf conky[2668422]: No players found
Sep 30 12:55:37 whitewolf conky[2668427]: No players found
Sep 30 12:55:37 whitewolf conky[2668433]: No players found
Sep 30 12:55:37 whitewolf conky[2668436]: No players found
Sep 30 12:55:37 whitewolf conky[2668442]: No players found
Sep 30 12:55:37 whitewolf conky[2668448]: No players found
Sep 30 12:55:37 whitewolf conky[2668450]: No players found
Sep 30 12:55:38 whitewolf conky[2668464]: No players found
Sep 30 12:55:38 whitewolf conky[2668466]: No players found
Sep 30 12:55:38 whitewolf conky[2668465]: No players found
Sep 30 12:55:38 whitewolf conky[2668468]: No players found
Sep 30 12:55:38 whitewolf conky[2668473]: No players found
Sep 30 12:55:38 whitewolf conky[2668483]: No players found
Sep 30 12:55:38 whitewolf conky[2668486]: No players found
Sep 30 12:55:38 whitewolf conky[2668489]: No players found
Sep 30 12:55:38 whitewolf conky[2668493]: No players found
Sep 30 12:55:38 whitewolf conky[2668501]: No players found
Sep 30 12:55:38 whitewolf conky[2668496]: No players found
Sep 30 12:55:38 whitewolf conky[2668504]: No players found
Sep 30 12:55:38 whitewolf conky[2668514]: No players found
Sep 30 12:55:38 whitewolf conky[2668511]: No players found
Sep 30 12:55:39 whitewolf conky[2668543]: No players found
Sep 30 12:55:39 whitewolf conky[2668542]: No players found
Sep 30 12:55:39 whitewolf conky[2668545]: No players found
Sep 30 12:55:39 whitewolf conky[2668544]: No players found
Sep 30 12:55:39 whitewolf conky[2668549]: No players found
Sep 30 12:55:39 whitewolf conky[2668559]: No players found
Sep 30 12:55:39 whitewolf conky[2668566]: No players found
Sep 30 12:55:39 whitewolf conky[2668561]: No players found
Sep 30 12:55:39 whitewolf conky[2668574]: No players found
Sep 30 12:55:39 whitewolf conky[2668572]: No players found
Sep 30 12:55:39 whitewolf conky[2668578]: No players found
Sep 30 12:55:39 whitewolf conky[2668584]: No players found
Sep 30 12:55:39 whitewolf conky[2668593]: No players found
Sep 30 12:55:39 whitewolf conky[2668588]: No players found
Sep 30 12:55:40 whitewolf conky[2668606]: No players found
Sep 30 12:55:40 whitewolf conky[2668607]: No players found
Sep 30 12:55:40 whitewolf conky[2668610]: No players found
Sep 30 12:55:40 whitewolf conky[2668613]: No players found
Sep 30 12:55:40 whitewolf conky[2668609]: No players found
Sep 30 12:55:40 whitewolf conky[2668623]: No players found
Sep 30 12:55:40 whitewolf conky[2668618]: No players found
Sep 30 12:55:40 whitewolf conky[2668628]: No players found
Sep 30 12:55:40 whitewolf conky[2668650]: No players found
Sep 30 12:55:40 whitewolf conky[2668636]: No players found
Sep 30 12:55:40 whitewolf conky[2668634]: No players found
Sep 30 12:55:40 whitewolf conky[2668651]: No players found
Sep 30 12:55:40 whitewolf conky[2668652]: No players found
Sep 30 12:55:40 whitewolf conky[2668640]: No players found
Sep 30 12:55:41 whitewolf conky[2668675]: No players found
Sep 30 12:55:41 whitewolf conky[2668673]: No players found
Sep 30 12:55:41 whitewolf conky[2668683]: No players found
Sep 30 12:55:41 whitewolf conky[2668676]: No players found
Sep 30 12:55:41 whitewolf conky[2668694]: No players found
Sep 30 12:55:41 whitewolf conky[2668698]: No players found
Sep 30 12:55:41 whitewolf conky[2668707]: No players found
Sep 30 12:55:41 whitewolf conky[2668704]: No players found
Sep 30 12:55:41 whitewolf conky[2668720]: No players found
Sep 30 12:55:41 whitewolf conky[2668727]: No players found
Sep 30 12:55:41 whitewolf conky[2668723]: No players found
Sep 30 12:55:41 whitewolf conky[2668730]: No players found
Sep 30 12:55:41 whitewolf conky[2668714]: No players found
Sep 30 12:55:41 whitewolf conky[2668728]: No players found
Sep 30 12:55:42 whitewolf conky[2668748]: No players found
Sep 30 12:55:42 whitewolf conky[2668749]: No players found
Sep 30 12:55:42 whitewolf conky[2668751]: No players found
Sep 30 12:55:42 whitewolf conky[2668752]: No players found
Sep 30 12:55:42 whitewolf conky[2668758]: No players found
Sep 30 12:55:42 whitewolf conky[2668761]: No players found
Sep 30 12:55:42 whitewolf conky[2668765]: No players found
Sep 30 12:55:42 whitewolf conky[2668769]: No players found
Sep 30 12:55:42 whitewolf conky[2668773]: No players found
Sep 30 12:55:42 whitewolf conky[2668777]: No players found
Sep 30 12:55:42 whitewolf conky[2668783]: No players found
Sep 30 12:55:42 whitewolf conky[2668787]: No players found
Sep 30 12:55:42 whitewolf conky[2668792]: No players found
Sep 30 12:55:42 whitewolf conky[2668797]: No players found
Sep 30 12:55:43 whitewolf conky[2668816]: No players found
Sep 30 12:55:43 whitewolf conky[2668817]: No players found
Sep 30 12:55:43 whitewolf conky[2668818]: No players found
Sep 30 12:55:43 whitewolf conky[2668821]: No players found
Sep 30 12:55:43 whitewolf conky[2668824]: No players found
Sep 30 12:55:43 whitewolf conky[2668830]: No players found
Sep 30 12:55:43 whitewolf conky[2668836]: No players found
Sep 30 12:55:43 whitewolf conky[2668845]: No players found
Sep 30 12:55:43 whitewolf conky[2668832]: No players found
Sep 30 12:55:43 whitewolf conky[2668857]: No players found
Sep 30 12:55:43 whitewolf conky[2668852]: No players found
Sep 30 12:55:43 whitewolf conky[2668861]: No players found
Sep 30 12:55:43 whitewolf conky[2668864]: No players found
Sep 30 12:55:43 whitewolf conky[2668872]: No players found
Sep 30 12:55:44 whitewolf conky[2668884]: No players found
Sep 30 12:55:44 whitewolf conky[2668885]: No players found
Sep 30 12:55:44 whitewolf conky[2668887]: No players found
Sep 30 12:55:44 whitewolf conky[2668886]: No players found
Sep 30 12:55:44 whitewolf conky[2668894]: No players found
Sep 30 12:55:44 whitewolf conky[2668900]: No players found
Sep 30 12:55:44 whitewolf conky[2668891]: No players found
Sep 30 12:55:44 whitewolf conky[2668909]: No players found
Sep 30 12:55:44 whitewolf conky[2668917]: No players found
Sep 30 12:55:44 whitewolf conky[2668905]: No players found
Sep 30 12:55:44 whitewolf conky[2668922]: No players found
Sep 30 12:55:44 whitewolf conky[2668925]: No players found
Sep 30 12:55:44 whitewolf conky[2668929]: No players found
Sep 30 12:55:44 whitewolf conky[2668930]: No players found
Sep 30 12:55:45 whitewolf conky[2668951]: No players found
Sep 30 12:55:45 whitewolf conky[2668952]: No players found
Sep 30 12:55:45 whitewolf conky[2668950]: No players found
Sep 30 12:55:45 whitewolf conky[2668954]: No players found
Sep 30 12:55:45 whitewolf conky[2668964]: No players found
Sep 30 12:55:45 whitewolf conky[2668959]: No players found
Sep 30 12:55:45 whitewolf conky[2668966]: No players found
Sep 30 12:55:45 whitewolf conky[2668983]: No players found
Sep 30 12:55:45 whitewolf conky[2668976]: No players found
Sep 30 12:55:45 whitewolf conky[2668987]: No players found
Sep 30 12:55:45 whitewolf conky[2668991]: No players found
Sep 30 12:55:45 whitewolf conky[2668995]: No players found
Sep 30 12:55:45 whitewolf conky[2668999]: No players found
Sep 30 12:55:45 whitewolf conky[2669003]: No players found
Sep 30 12:55:46 whitewolf conky[2669018]: No players found
Sep 30 12:55:46 whitewolf conky[2669020]: No players found
Sep 30 12:55:46 whitewolf conky[2669024]: No players found
Sep 30 12:55:46 whitewolf conky[2669026]: No players found
Sep 30 12:55:46 whitewolf conky[2669035]: No players found
Sep 30 12:55:46 whitewolf conky[2669032]: No players found
Sep 30 12:55:46 whitewolf conky[2669041]: No players found
Sep 30 12:55:46 whitewolf conky[2669047]: No players found
Sep 30 12:55:46 whitewolf conky[2669039]: No players found
Sep 30 12:55:46 whitewolf conky[2669055]: No players found
Sep 30 12:55:46 whitewolf conky[2669052]: No players found
Sep 30 12:55:46 whitewolf conky[2669059]: No players found
Sep 30 12:55:46 whitewolf conky[2669072]: No players found
Sep 30 12:55:46 whitewolf conky[2669065]: No players found
Sep 30 12:55:47 whitewolf conky[2669090]: No players found
Sep 30 12:55:47 whitewolf conky[2669084]: No players found
Sep 30 12:55:47 whitewolf conky[2669086]: No players found
Sep 30 12:55:47 whitewolf conky[2669097]: No players found
Sep 30 12:55:47 whitewolf conky[2669088]: No players found
Sep 30 12:55:47 whitewolf conky[2669106]: No players found
Sep 30 12:55:47 whitewolf conky[2669117]: No players found
Sep 30 12:55:47 whitewolf conky[2669111]: No players found
Sep 30 12:55:47 whitewolf conky[2669123]: No players found
Sep 30 12:55:47 whitewolf conky[2669127]: No players found
Sep 30 12:55:47 whitewolf conky[2669146]: No players found
Sep 30 12:55:47 whitewolf conky[2669138]: No players found
Sep 30 12:55:47 whitewolf conky[2669141]: No players found
Sep 30 12:55:47 whitewolf conky[2669148]: No players found
Sep 30 12:55:48 whitewolf conky[2669164]: No players found
Sep 30 12:55:48 whitewolf conky[2669163]: No players found
Sep 30 12:55:48 whitewolf conky[2669166]: No players found
Sep 30 12:55:48 whitewolf conky[2669173]: No players found
Sep 30 12:55:48 whitewolf conky[2669167]: No players found
Sep 30 12:55:48 whitewolf conky[2669179]: No players found
Sep 30 12:55:48 whitewolf conky[2669186]: No players found
Sep 30 12:55:48 whitewolf conky[2669177]: No players found
Sep 30 12:55:48 whitewolf conky[2669197]: No players found
Sep 30 12:55:48 whitewolf conky[2669202]: No players found
Sep 30 12:55:48 whitewolf conky[2669205]: No players found
Sep 30 12:55:48 whitewolf conky[2669207]: No players found
Sep 30 12:55:48 whitewolf conky[2669189]: No players found
Sep 30 12:55:48 whitewolf conky[2669213]: No players found
Sep 30 12:55:49 whitewolf conky[1737]: conky: statfs '/mnt/wd1tb': No such file or directory
Sep 30 12:55:49 whitewolf conky[2669228]: No players found
Sep 30 12:55:49 whitewolf conky[2669230]: No players found
Sep 30 12:55:49 whitewolf conky[2669232]: No players found
Sep 30 12:55:49 whitewolf conky[2669231]: No players found
Sep 30 12:55:49 whitewolf conky[2669239]: No players found
Sep 30 12:55:49 whitewolf conky[2669249]: No players found
Sep 30 12:55:49 whitewolf conky[2669244]: No players found
Sep 30 12:55:49 whitewolf conky[2669258]: No players found
Sep 30 12:55:49 whitewolf conky[2669252]: No players found
Sep 30 12:55:49 whitewolf conky[2669262]: No players found
Sep 30 12:55:49 whitewolf conky[2669266]: No players found
Sep 30 12:55:49 whitewolf conky[2669269]: No players found
Sep 30 12:55:49 whitewolf conky[2669273]: No players found
Sep 30 12:55:49 whitewolf conky[2669276]: No players found
Sep 30 12:55:50 whitewolf conky[2669295]: No players found
Sep 30 12:55:50 whitewolf conky[2669296]: No players found
Sep 30 12:55:50 whitewolf conky[2669298]: No players found
Sep 30 12:55:50 whitewolf conky[2669303]: No players found
Sep 30 12:55:50 whitewolf conky[2669299]: No players found
Sep 30 12:55:50 whitewolf conky[2669308]: No players found
Sep 30 12:55:50 whitewolf conky[2669311]: No players found
Sep 30 12:55:50 whitewolf conky[2669324]: No players found
Sep 30 12:55:50 whitewolf conky[2669317]: No players found
Sep 30 12:55:50 whitewolf conky[2669325]: No players found
Sep 30 12:55:50 whitewolf conky[2669334]: No players found
Sep 30 12:55:50 whitewolf conky[2669348]: No players found
Sep 30 12:55:50 whitewolf conky[2669351]: No players found
Sep 30 12:55:50 whitewolf conky[2669341]: No players found
Sep 30 12:55:51 whitewolf conky[2669364]: No players found
Sep 30 12:55:51 whitewolf conky[2669369]: No players found
Sep 30 12:55:51 whitewolf conky[2669365]: No players found
Sep 30 12:55:51 whitewolf conky[2669379]: No players found
Sep 30 12:55:51 whitewolf conky[2669377]: No players found
Sep 30 12:55:51 whitewolf conky[2669366]: No players found
Sep 30 12:55:51 whitewolf conky[2669392]: No players found
Sep 30 12:55:51 whitewolf conky[2669395]: No players found
Sep 30 12:55:51 whitewolf conky[2669384]: No players found
Sep 30 12:55:51 whitewolf conky[2669374]: No players found
Sep 30 12:55:51 whitewolf conky[2669406]: No players found
Sep 30 12:55:51 whitewolf conky[2669416]: No players found
Sep 30 12:55:51 whitewolf conky[2669417]: No players found
Sep 30 12:55:51 whitewolf conky[2669409]: No players found
Sep 30 12:55:52 whitewolf conky[2669430]: No players found
Sep 30 12:55:52 whitewolf conky[2669431]: No players found
Sep 30 12:55:52 whitewolf conky[2669432]: No players found
Sep 30 12:55:52 whitewolf conky[2669436]: No players found
Sep 30 12:55:52 whitewolf conky[2669439]: No players found
Sep 30 12:55:52 whitewolf conky[2669445]: No players found
Sep 30 12:55:52 whitewolf conky[2669433]: No players found
Sep 30 12:55:52 whitewolf conky[2669449]: No players found
Sep 30 12:55:52 whitewolf conky[2669458]: No players found
Sep 30 12:55:52 whitewolf conky[2669455]: No players found
Sep 30 12:55:52 whitewolf conky[2669475]: No players found
Sep 30 12:55:52 whitewolf conky[2669478]: No players found
Sep 30 12:55:52 whitewolf conky[2669479]: No players found
Sep 30 12:55:52 whitewolf conky[2669482]: No players found
Sep 30 12:55:53 whitewolf conky[2669498]: No players found
Sep 30 12:55:53 whitewolf conky[2669507]: No players found
Sep 30 12:55:53 whitewolf conky[2669500]: No players found
Sep 30 12:55:53 whitewolf conky[2669511]: No players found
Sep 30 12:55:53 whitewolf conky[2669502]: No players found
Sep 30 12:55:53 whitewolf conky[2669518]: No players found
Sep 30 12:55:53 whitewolf conky[2669525]: No players found
Sep 30 12:55:53 whitewolf conky[2669529]: No players found
Sep 30 12:55:53 whitewolf conky[2669531]: No players found
Sep 30 12:55:53 whitewolf conky[2669543]: No players found
Sep 30 12:55:53 whitewolf conky[2669541]: No players found
Sep 30 12:55:53 whitewolf conky[2669553]: No players found
Sep 30 12:55:53 whitewolf conky[2669558]: No players found
Sep 30 12:55:53 whitewolf conky[2669564]: No players found
Sep 30 12:55:54 whitewolf conky[2669577]: No players found
Sep 30 12:55:54 whitewolf conky[2669578]: No players found
Sep 30 12:55:54 whitewolf conky[2669587]: No players found
Sep 30 12:55:54 whitewolf conky[2669579]: No players found
Sep 30 12:55:54 whitewolf conky[2669580]: No players found
Sep 30 12:55:54 whitewolf conky[2669592]: No players found
Sep 30 12:55:54 whitewolf conky[2669596]: No players found
Sep 30 12:55:54 whitewolf conky[2669597]: No players found
Sep 30 12:55:54 whitewolf conky[2669603]: No players found
Sep 30 12:55:54 whitewolf conky[2669616]: No players found
Sep 30 12:55:54 whitewolf conky[2669620]: No players found
Sep 30 12:55:54 whitewolf conky[2669613]: No players found
Sep 30 12:55:54 whitewolf conky[2669623]: No players found
Sep 30 12:55:54 whitewolf conky[2669622]: No players found
Sep 30 12:55:55 whitewolf conky[2669642]: No players found
Sep 30 12:55:55 whitewolf conky[2669643]: No players found
Sep 30 12:55:55 whitewolf conky[2669648]: No players found
Sep 30 12:55:55 whitewolf conky[2669644]: No players found
Sep 30 12:55:55 whitewolf conky[2669655]: No players found
Sep 30 12:55:55 whitewolf conky[2669670]: No players found
Sep 30 12:55:55 whitewolf conky[2669671]: No players found
Sep 30 12:55:55 whitewolf conky[2669665]: No players found
Sep 30 12:55:55 whitewolf conky[2669681]: No players found
Sep 30 12:55:55 whitewolf conky[2669673]: No players found
Sep 30 12:55:55 whitewolf conky[2669652]: No players found
Sep 30 12:55:55 whitewolf conky[2669682]: No players found
Sep 30 12:55:55 whitewolf conky[2669690]: No players found
Sep 30 12:55:55 whitewolf conky[2669691]: No players found
Sep 30 12:55:56 whitewolf conky[2669710]: No players found
Sep 30 12:55:56 whitewolf conky[2669711]: No players found
Sep 30 12:55:56 whitewolf conky[2669712]: No players found
Sep 30 12:55:56 whitewolf conky[2669716]: No players found
Sep 30 12:55:56 whitewolf conky[2669734]: No players found
Sep 30 12:55:56 whitewolf conky[2669723]: No players found
Sep 30 12:55:56 whitewolf conky[2669726]: No players found
Sep 30 12:55:56 whitewolf conky[2669738]: No players found
Sep 30 12:55:56 whitewolf conky[2669742]: No players found
Sep 30 12:55:56 whitewolf conky[2669746]: No players found
Sep 30 12:55:56 whitewolf conky[2669730]: No players found
Sep 30 12:55:56 whitewolf conky[2669754]: No players found
Sep 30 12:55:56 whitewolf conky[2669758]: No players found
Sep 30 12:55:56 whitewolf conky[2669749]: No players found
Sep 30 12:55:57 whitewolf conky[2669775]: No players found
Sep 30 12:55:57 whitewolf conky[2669777]: No players found
Sep 30 12:55:57 whitewolf conky[2669779]: No players found
Sep 30 12:55:57 whitewolf conky[2669791]: No players found
Sep 30 12:55:57 whitewolf conky[2669787]: No players found
Sep 30 12:55:57 whitewolf conky[2669785]: No players found
Sep 30 12:55:57 whitewolf conky[2669795]: No players found
Sep 30 12:55:57 whitewolf conky[2669800]: No players found
Sep 30 12:55:57 whitewolf conky[2669809]: No players found
Sep 30 12:55:57 whitewolf conky[2669815]: No players found
Sep 30 12:55:57 whitewolf conky[2669811]: No players found
Sep 30 12:55:57 whitewolf conky[2669819]: No players found
Sep 30 12:55:57 whitewolf conky[2669829]: No players found
Sep 30 12:55:57 whitewolf conky[2669826]: No players found
Sep 30 12:55:58 whitewolf conky[2669844]: No players found
Sep 30 12:55:58 whitewolf conky[2669843]: No players found
Sep 30 12:55:58 whitewolf conky[2669845]: No players found
Sep 30 12:55:58 whitewolf conky[2669854]: No players found
Sep 30 12:55:58 whitewolf conky[2669858]: No players found
Sep 30 12:55:58 whitewolf conky[2669851]: No players found
Sep 30 12:55:58 whitewolf conky[2669870]: No players found
Sep 30 12:55:58 whitewolf conky[2669866]: No players found
Sep 30 12:55:58 whitewolf conky[2669862]: No players found
Sep 30 12:55:58 whitewolf conky[2669880]: No players found
Sep 30 12:55:58 whitewolf conky[2669881]: No players found
Sep 30 12:55:58 whitewolf conky[2669890]: No players found
Sep 30 12:55:58 whitewolf conky[2669875]: No players found
Sep 30 12:55:58 whitewolf conky[2669897]: No players found
Sep 30 12:55:59 whitewolf conky[2669910]: No players found
Sep 30 12:55:59 whitewolf conky[2669914]: No players found
Sep 30 12:55:59 whitewolf conky[2669915]: No players found
Sep 30 12:55:59 whitewolf conky[2669922]: No players found
Sep 30 12:55:59 whitewolf conky[2669938]: No players found
Sep 30 12:55:59 whitewolf conky[2669947]: No players found
Sep 30 12:55:59 whitewolf conky[2669934]: No players found
Sep 30 12:55:59 whitewolf conky[2669954]: No players found
Sep 30 12:55:59 whitewolf conky[2669942]: No players found
Sep 30 12:55:59 whitewolf conky[2669948]: No players found
Sep 30 12:55:59 whitewolf conky[2669961]: No players found
Sep 30 12:55:59 whitewolf conky[2669958]: No players found
Sep 30 12:55:59 whitewolf conky[2669971]: No players found
Sep 30 12:55:59 whitewolf conky[2669965]: No players found
Sep 30 12:56:00 whitewolf conky[2669990]: No players found
Sep 30 12:56:00 whitewolf conky[2669991]: No players found
Sep 30 12:56:00 whitewolf conky[2669997]: No players found
Sep 30 12:56:00 whitewolf conky[2670004]: No players found
Sep 30 12:56:00 whitewolf conky[2670008]: No players found
Sep 30 12:56:00 whitewolf conky[2669993]: No players found
Sep 30 12:56:00 whitewolf conky[2670011]: No players found
Sep 30 12:56:00 whitewolf conky[2670019]: No players found
Sep 30 12:56:00 whitewolf conky[2670022]: No players found
Sep 30 12:56:00 whitewolf conky[2670028]: No players found
Sep 30 12:56:00 whitewolf conky[2670031]: No players found
Sep 30 12:56:00 whitewolf conky[2670035]: No players found
Sep 30 12:56:00 whitewolf conky[2670038]: No players found
Sep 30 12:56:00 whitewolf conky[2670041]: No players found
Sep 30 12:56:01 whitewolf conky[2670056]: No players found
Sep 30 12:56:01 whitewolf conky[2670058]: No players found
Sep 30 12:56:01 whitewolf conky[2670057]: No players found
Sep 30 12:56:01 whitewolf conky[2670059]: No players found
Sep 30 12:56:01 whitewolf conky[2670062]: No players found
Sep 30 12:56:01 whitewolf conky[2670064]: No players found
Sep 30 12:56:01 whitewolf conky[2670070]: No players found
Sep 30 12:56:01 whitewolf conky[2670077]: No players found
Sep 30 12:56:01 whitewolf conky[2670084]: No players found
Sep 30 12:56:01 whitewolf conky[2670074]: No players found
Sep 30 12:56:01 whitewolf conky[2670081]: No players found
Sep 30 12:56:01 whitewolf conky[2670097]: No players found
Sep 30 12:56:01 whitewolf conky[2670105]: No players found
Sep 30 12:56:01 whitewolf conky[2670101]: No players found
Sep 30 12:56:02 whitewolf conky[2670121]: No players found
Sep 30 12:56:02 whitewolf conky[2670122]: No players found
Sep 30 12:56:02 whitewolf conky[2670123]: No players found
Sep 30 12:56:02 whitewolf conky[2670124]: No players found
Sep 30 12:56:02 whitewolf conky[2670125]: No players found
Sep 30 12:56:02 whitewolf conky[2670129]: No players found
Sep 30 12:56:02 whitewolf conky[2670132]: No players found
Sep 30 12:56:02 whitewolf conky[2670142]: No players found
Sep 30 12:56:02 whitewolf conky[2670150]: No players found
Sep 30 12:56:02 whitewolf conky[2670155]: No players found
Sep 30 12:56:02 whitewolf conky[2670137]: No players found
Sep 30 12:56:02 whitewolf conky[2670162]: No players found
Sep 30 12:56:02 whitewolf conky[2670167]: No players found
Sep 30 12:56:02 whitewolf conky[2670173]: No players found
Sep 30 12:56:03 whitewolf conky[1737]: conky: statfs '/mnt/wd1tb': No such file or directory
Sep 30 12:56:03 whitewolf conky[2670189]: No players found
Sep 30 12:56:03 whitewolf conky[2670190]: No players found
Sep 30 12:56:03 whitewolf conky[2670191]: No players found
Sep 30 12:56:03 whitewolf conky[2670196]: No players found
Sep 30 12:56:03 whitewolf conky[2670200]: No players found
Sep 30 12:56:03 whitewolf conky[2670192]: No players found
Sep 30 12:56:03 whitewolf conky[2670206]: No players found
Sep 30 12:56:03 whitewolf conky[2670209]: No players found
Sep 30 12:56:03 whitewolf conky[2670218]: No players found
Sep 30 12:56:03 whitewolf conky[2670214]: No players found
Sep 30 12:56:03 whitewolf conky[2670223]: No players found
Sep 30 12:56:03 whitewolf conky[2670233]: No players found
Sep 30 12:56:03 whitewolf conky[2670238]: No players found
Sep 30 12:56:03 whitewolf conky[2670241]: No players found
Sep 30 12:56:04 whitewolf conky[2670260]: No players found
Sep 30 12:56:04 whitewolf conky[2670258]: No players found
Sep 30 12:56:04 whitewolf conky[2670259]: No players found
Sep 30 12:56:04 whitewolf conky[2670263]: No players found
Sep 30 12:56:04 whitewolf conky[2670269]: No players found
Sep 30 12:56:04 whitewolf conky[2670265]: No players found
Sep 30 12:56:04 whitewolf conky[2670281]: No players found
Sep 30 12:56:04 whitewolf conky[2670284]: No players found
Sep 30 12:56:04 whitewolf conky[2670277]: No players found
Sep 30 12:56:04 whitewolf conky[2670290]: No players found
Sep 30 12:56:04 whitewolf conky[2670273]: No players found
Sep 30 12:56:04 whitewolf conky[2670301]: No players found
Sep 30 12:56:04 whitewolf conky[2670307]: No players found
Sep 30 12:56:04 whitewolf conky[2670314]: No players found
Sep 30 12:56:05 whitewolf konsole[1609566]: qt.qpa.wayland: Creating a popup with a parent, QWidgetWindow(0x58de8a97b160, name="MainWindow#1Window") which does not match the current topmost grabbing popup, QWidgetWindow(0x58de8acab2a0, name="session-popup-menuWindow") With some shell surface protocols, this is not allowed. The wayland QPA plugin is currently handling it by setting the parent to the topmost grabbing popup. Note, however, that this may cause positioning errors and popups closing unxpectedly. Please fix the transient parent of the popup.
Sep 30 12:56:05 whitewolf conky[2670331]: No players found
Sep 30 12:56:05 whitewolf conky[2670333]: No players found
Sep 30 12:56:05 whitewolf conky[2670337]: No players found
Sep 30 12:56:05 whitewolf conky[2670335]: No players found
Sep 30 12:56:05 whitewolf conky[2670356]: No players found
Sep 30 12:56:05 whitewolf conky[2670365]: No players found
Sep 30 12:56:05 whitewolf conky[2670374]: No players found
Sep 30 12:56:05 whitewolf conky[2670367]: No players found
Sep 30 12:56:05 whitewolf conky[2670381]: No players found
Sep 30 12:56:05 whitewolf conky[2670383]: No players found
Sep 30 12:56:05 whitewolf conky[2670378]: No players found
Sep 30 12:56:05 whitewolf conky[2670388]: No players found
Sep 30 12:56:05 whitewolf conky[2670391]: No players found
Sep 30 12:56:05 whitewolf conky[2670396]: No players found
Sep 30 12:56:06 whitewolf conky[2670411]: No players found
Sep 30 12:56:06 whitewolf conky[2670412]: No players found
Sep 30 12:56:06 whitewolf conky[2670414]: No players found
Sep 30 12:56:06 whitewolf conky[2670427]: No players found
Sep 30 12:56:06 whitewolf conky[2670432]: No players found
Sep 30 12:56:06 whitewolf conky[2670419]: No players found
Sep 30 12:56:06 whitewolf conky[2670425]: No players found
Sep 30 12:56:06 whitewolf conky[2670436]: No players found
Sep 30 12:56:06 whitewolf conky[2670441]: No players found
Sep 30 12:56:06 whitewolf conky[2670443]: No players found
Sep 30 12:56:06 whitewolf conky[2670451]: No players found
Sep 30 12:56:06 whitewolf conky[2670446]: No players found
Sep 30 12:56:06 whitewolf conky[2670456]: No players found
Sep 30 12:56:06 whitewolf conky[2670459]: No players found
Sep 30 12:56:06 whitewolf rtkit-daemon[1134]: Supervising 8 threads of 5 processes of 1 users.
Sep 30 12:56:07 whitewolf conky[2670508]: No players found
Sep 30 12:56:07 whitewolf conky[2670509]: No players found
Sep 30 12:56:07 whitewolf conky[2670510]: No players found
Sep 30 12:56:07 whitewolf conky[2670515]: No players found
Sep 30 12:56:07 whitewolf conky[2670522]: No players found
Sep 30 12:56:07 whitewolf conky[2670512]: No players found
Sep 30 12:56:07 whitewolf conky[2670530]: No players found
Sep 30 12:56:07 whitewolf conky[2670526]: No players found
Sep 30 12:56:07 whitewolf conky[2670536]: No players found
Sep 30 12:56:07 whitewolf conky[2670540]: No players found
Sep 30 12:56:07 whitewolf conky[2670549]: No players found
Sep 30 12:56:07 whitewolf conky[2670554]: No players found
Sep 30 12:56:07 whitewolf conky[2670548]: No players found
Sep 30 12:56:07 whitewolf conky[2670560]: No players found
Sep 30 12:56:08 whitewolf conky[2670576]: No players found
Sep 30 12:56:08 whitewolf conky[2670577]: No players found
Sep 30 12:56:08 whitewolf conky[2670584]: No players found
Sep 30 12:56:08 whitewolf conky[2670578]: No players found
Sep 30 12:56:08 whitewolf conky[2670580]: No players found
Sep 30 12:56:08 whitewolf conky[2670589]: No players found
Sep 30 12:56:08 whitewolf conky[2670598]: No players found
Sep 30 12:56:08 whitewolf conky[2670601]: No players found
Sep 30 12:56:08 whitewolf conky[2670607]: No players found
Sep 30 12:56:08 whitewolf conky[2670611]: No players found
Sep 30 12:56:08 whitewolf conky[2670615]: No players found
Sep 30 12:56:08 whitewolf conky[2670620]: No players found
Sep 30 12:56:08 whitewolf conky[2670621]: No players found
Sep 30 12:56:08 whitewolf conky[2670626]: No players found
Sep 30 12:56:09 whitewolf conky[2670642]: No players found
Sep 30 12:56:09 whitewolf conky[2670643]: No players found
Sep 30 12:56:09 whitewolf conky[2670644]: No players found
Sep 30 12:56:09 whitewolf conky[2670652]: No players found
Sep 30 12:56:09 whitewolf conky[2670653]: No players found
Sep 30 12:56:09 whitewolf conky[2670655]: No players found
Sep 30 12:56:09 whitewolf conky[2670658]: No players found
Sep 30 12:56:09 whitewolf conky[2670670]: No players found
Sep 30 12:56:09 whitewolf conky[2670675]: No players found
Sep 30 12:56:09 whitewolf conky[2670684]: No players found
Sep 30 12:56:09 whitewolf conky[2670680]: No players found
Sep 30 12:56:09 whitewolf conky[2670687]: No players found
Sep 30 12:56:09 whitewolf conky[2670673]: No players found
Sep 30 12:56:09 whitewolf conky[2670695]: No players found
Sep 30 12:56:10 whitewolf conky[2670708]: No players found
Sep 30 12:56:10 whitewolf conky[2670709]: No players found
Sep 30 12:56:10 whitewolf conky[2670710]: No players found
Sep 30 12:56:10 whitewolf conky[2670711]: No players found
Sep 30 12:56:10 whitewolf conky[2670722]: No players found
Sep 30 12:56:10 whitewolf conky[2670718]: No players found
Sep 30 12:56:10 whitewolf conky[2670724]: No players found
Sep 30 12:56:10 whitewolf conky[2670741]: No players found
Sep 30 12:56:10 whitewolf conky[2670733]: No players found
Sep 30 12:56:10 whitewolf conky[2670746]: No players found
Sep 30 12:56:10 whitewolf conky[2670737]: No players found
Sep 30 12:56:10 whitewolf conky[2670749]: No players found
Sep 30 12:56:10 whitewolf conky[2670752]: No players found
Sep 30 12:56:10 whitewolf conky[2670758]: No players found
Sep 30 12:56:11 whitewolf conky[2670775]: No players found
Sep 30 12:56:11 whitewolf conky[2670778]: No players found
Sep 30 12:56:11 whitewolf conky[2670783]: No players found
Sep 30 12:56:11 whitewolf conky[2670794]: No players found
Sep 30 12:56:11 whitewolf conky[2670789]: No players found
Sep 30 12:56:11 whitewolf conky[2670811]: No players found
Sep 30 12:56:11 whitewolf conky[2670807]: No players found
Sep 30 12:56:11 whitewolf conky[2670818]: No players found
Sep 30 12:56:11 whitewolf conky[2670817]: No players found
Sep 30 12:56:11 whitewolf conky[2670821]: No players found
Sep 30 12:56:11 whitewolf conky[2670829]: No players found
Sep 30 12:56:11 whitewolf conky[2670835]: No players found
Sep 30 12:56:11 whitewolf conky[2670830]: No players found
Sep 30 12:56:11 whitewolf conky[2670840]: No players found
Sep 30 12:56:12 whitewolf conky[2670856]: No players found
Sep 30 12:56:12 whitewolf conky[2670858]: No players found
Sep 30 12:56:12 whitewolf conky[2670857]: No players found
Sep 30 12:56:12 whitewolf conky[2670861]: No players found
Sep 30 12:56:12 whitewolf conky[2670878]: No players found
Sep 30 12:56:12 whitewolf conky[2670867]: No players found
Sep 30 12:56:12 whitewolf conky[2670874]: No players found
Sep 30 12:56:12 whitewolf conky[2670883]: No players found
Sep 30 12:56:12 whitewolf conky[2670893]: No players found
Sep 30 12:56:12 whitewolf conky[2670870]: No players found
Sep 30 12:56:12 whitewolf conky[2670886]: No players found
Sep 30 12:56:12 whitewolf conky[2670900]: No players found
Sep 30 12:56:12 whitewolf conky[2670904]: No players found
Sep 30 12:56:12 whitewolf conky[2670906]: No players found
Sep 30 12:56:13 whitewolf conky[2670923]: No players found
Sep 30 12:56:13 whitewolf conky[2670922]: No players found
Sep 30 12:56:13 whitewolf conky[2670924]: No players found
Sep 30 12:56:13 whitewolf conky[2670925]: No players found
Sep 30 12:56:13 whitewolf conky[2670936]: No players found
Sep 30 12:56:13 whitewolf conky[2670927]: No players found
Sep 30 12:56:13 whitewolf conky[2670947]: No players found
Sep 30 12:56:13 whitewolf conky[2670955]: No players found
Sep 30 12:56:13 whitewolf conky[2670949]: No players found
Sep 30 12:56:13 whitewolf conky[2670959]: No players found
Sep 30 12:56:13 whitewolf conky[2670957]: No players found
Sep 30 12:56:13 whitewolf conky[2670964]: No players found
Sep 30 12:56:13 whitewolf conky[2670967]: No players found
Sep 30 12:56:13 whitewolf conky[2670975]: No players found
Sep 30 12:56:14 whitewolf conky[2670989]: No players found
Sep 30 12:56:14 whitewolf conky[2670990]: No players found
Sep 30 12:56:14 whitewolf conky[2670991]: No players found
Sep 30 12:56:14 whitewolf conky[2670995]: No players found
Sep 30 12:56:14 whitewolf conky[2670998]: No players found
Sep 30 12:56:14 whitewolf conky[2671002]: No players found
Sep 30 12:56:14 whitewolf conky[2671007]: No players found
Sep 30 12:56:14 whitewolf conky[2671012]: No players found
Sep 30 12:56:14 whitewolf conky[2671014]: No players found
Sep 30 12:56:14 whitewolf conky[2671021]: No players found
Sep 30 12:56:14 whitewolf conky[2671027]: No players found
Sep 30 12:56:14 whitewolf conky[2671033]: No players found
Sep 30 12:56:14 whitewolf conky[2671036]: No players found
Sep 30 12:56:14 whitewolf conky[2671029]: No players found
Sep 30 12:56:15 whitewolf conky[2671053]: No players found
Sep 30 12:56:15 whitewolf conky[2671054]: No players found
Sep 30 12:56:15 whitewolf conky[2671055]: No players found
Sep 30 12:56:15 whitewolf conky[2671056]: No players found
Sep 30 12:56:15 whitewolf conky[2671057]: No players found
Sep 30 12:56:15 whitewolf conky[2671065]: No players found
Sep 30 12:56:15 whitewolf conky[2671071]: No players found
Sep 30 12:56:15 whitewolf conky[2671073]: No players found
Sep 30 12:56:15 whitewolf conky[2671082]: No players found
Sep 30 12:56:15 whitewolf conky[2671094]: No players found
Sep 30 12:56:15 whitewolf conky[2671087]: No players found
Sep 30 12:56:15 whitewolf conky[2671090]: No players found
Sep 30 12:56:15 whitewolf conky[2671091]: No players found
Sep 30 12:56:15 whitewolf conky[2671102]: No players found
Sep 30 12:56:16 whitewolf conky[2671121]: No players found
Sep 30 12:56:16 whitewolf conky[2671122]: No players found
Sep 30 12:56:16 whitewolf conky[2671129]: No players found
Sep 30 12:56:16 whitewolf conky[2671123]: No players found
Sep 30 12:56:16 whitewolf conky[2671132]: No players found
Sep 30 12:56:16 whitewolf conky[2671124]: No players found
Sep 30 12:56:16 whitewolf conky[2671139]: No players found
Sep 30 12:56:16 whitewolf conky[2671140]: No players found
Sep 30 12:56:16 whitewolf conky[2671147]: No players found
Sep 30 12:56:16 whitewolf conky[2671157]: No players found
Sep 30 12:56:16 whitewolf conky[2671144]: No players found
Sep 30 12:56:16 whitewolf conky[2671165]: No players found
Sep 30 12:56:16 whitewolf conky[2671160]: No players found
Sep 30 12:56:16 whitewolf conky[2671170]: No players found
Sep 30 12:56:17 whitewolf conky[1737]: conky: statfs '/mnt/wd1tb': No such file or directory
Sep 30 12:56:17 whitewolf conky[2671189]: No players found
Sep 30 12:56:17 whitewolf conky[2671192]: No players found
Sep 30 12:56:17 whitewolf conky[2671206]: No players found
Sep 30 12:56:17 whitewolf conky[2671199]: No players found
Sep 30 12:56:17 whitewolf conky[2671197]: No players found
Sep 30 12:56:17 whitewolf conky[2671215]: No players found
Sep 30 12:56:17 whitewolf conky[2671221]: No players found
Sep 30 12:56:17 whitewolf conky[2671223]: No players found
Sep 30 12:56:17 whitewolf conky[2671227]: No players found
Sep 30 12:56:17 whitewolf conky[2671229]: No players found
Sep 30 12:56:17 whitewolf conky[2671230]: No players found
Sep 30 12:56:17 whitewolf conky[2671241]: No players found
Sep 30 12:56:17 whitewolf conky[2671238]: No players found
Sep 30 12:56:17 whitewolf conky[2671248]: No players found
Sep 30 12:56:18 whitewolf conky[2671266]: No players found
Sep 30 12:56:18 whitewolf conky[2671267]: No players found
Sep 30 12:56:18 whitewolf conky[2671269]: No players found
Sep 30 12:56:18 whitewolf conky[2671274]: No players found
Sep 30 12:56:18 whitewolf conky[2671278]: No players found
Sep 30 12:56:18 whitewolf conky[2671290]: No players found
Sep 30 12:56:18 whitewolf conky[2671282]: No players found
Sep 30 12:56:18 whitewolf conky[2671286]: No players found
Sep 30 12:56:18 whitewolf conky[2671295]: No players found
Sep 30 12:56:18 whitewolf conky[2671300]: No players found
Sep 30 12:56:18 whitewolf conky[2671302]: No players found
Sep 30 12:56:18 whitewolf conky[2671311]: No players found
Sep 30 12:56:18 whitewolf conky[2671307]: No players found
Sep 30 12:56:18 whitewolf conky[2671314]: No players found
Sep 30 12:56:19 whitewolf conky[2671333]: No players found
Sep 30 12:56:19 whitewolf conky[2671332]: No players found
Sep 30 12:56:19 whitewolf conky[2671334]: No players found
Sep 30 12:56:19 whitewolf conky[2671335]: No players found
Sep 30 12:56:19 whitewolf conky[2671336]: No players found
Sep 30 12:56:19 whitewolf conky[2671341]: No players found
Sep 30 12:56:19 whitewolf conky[2671351]: No players found
Sep 30 12:56:19 whitewolf conky[2671353]: No players found
Sep 30 12:56:19 whitewolf conky[2671363]: No players found
Sep 30 12:56:19 whitewolf conky[2671367]: No players found
Sep 30 12:56:19 whitewolf conky[2671371]: No players found
Sep 30 12:56:19 whitewolf conky[2671373]: No players found
Sep 30 12:56:19 whitewolf conky[2671378]: No players found
Sep 30 12:56:19 whitewolf conky[2671381]: No players found
Sep 30 12:56:20 whitewolf conky[2671399]: No players found
Sep 30 12:56:20 whitewolf conky[2671400]: No players found
Sep 30 12:56:20 whitewolf conky[2671398]: No players found
Sep 30 12:56:20 whitewolf conky[2671403]: No players found
Sep 30 12:56:20 whitewolf conky[2671406]: No players found
Sep 30 12:56:20 whitewolf conky[2671409]: No players found
Sep 30 12:56:20 whitewolf conky[2671414]: No players found
Sep 30 12:56:20 whitewolf conky[2671401]: No players found
Sep 30 12:56:20 whitewolf conky[2671418]: No players found
Sep 30 12:56:20 whitewolf conky[2671430]: No players found
Sep 30 12:56:20 whitewolf conky[2671427]: No players found
Sep 30 12:56:20 whitewolf conky[2671444]: No players found
Sep 30 12:56:20 whitewolf conky[2671447]: No players found
Sep 30 12:56:20 whitewolf conky[2671450]: No players found
Sep 30 12:56:21 whitewolf conky[2671465]: No players found
Sep 30 12:56:21 whitewolf conky[2671466]: No players found
Sep 30 12:56:21 whitewolf conky[2671467]: No players found
Sep 30 12:56:21 whitewolf conky[2671468]: No players found
Sep 30 12:56:21 whitewolf conky[2671471]: No players found
Sep 30 12:56:21 whitewolf conky[2671478]: No players found
Sep 30 12:56:21 whitewolf conky[2671486]: No players found
Sep 30 12:56:21 whitewolf conky[2671473]: No players found
Sep 30 12:56:21 whitewolf conky[2671496]: No players found
Sep 30 12:56:21 whitewolf conky[2671501]: No players found
Sep 30 12:56:21 whitewolf conky[2671511]: No players found
Sep 30 12:56:21 whitewolf conky[2671515]: No players found
Sep 30 12:56:21 whitewolf conky[2671506]: No players found
Sep 30 12:56:21 whitewolf conky[2671518]: No players found
Sep 30 12:56:22 whitewolf conky[2671535]: No players found
Sep 30 12:56:22 whitewolf conky[2671536]: No players found
Sep 30 12:56:22 whitewolf conky[2671537]: No players found
Sep 30 12:56:22 whitewolf conky[2671542]: No players found
Sep 30 12:56:22 whitewolf conky[2671553]: No players found
Sep 30 12:56:22 whitewolf conky[2671545]: No players found
Sep 30 12:56:22 whitewolf conky[2671558]: No players found
Sep 30 12:56:22 whitewolf conky[2671552]: No players found
Sep 30 12:56:22 whitewolf conky[2671561]: No players found
Sep 30 12:56:22 whitewolf conky[2671569]: No players found
Sep 30 12:56:22 whitewolf conky[2671576]: No players found
Sep 30 12:56:22 whitewolf conky[2671573]: No players found
Sep 30 12:56:22 whitewolf conky[2671580]: No players found
Sep 30 12:56:22 whitewolf conky[2671582]: No players found
Sep 30 12:56:23 whitewolf conky[2671601]: No players found
Sep 30 12:56:23 whitewolf conky[2671602]: No players found
Sep 30 12:56:23 whitewolf conky[2671604]: No players found
Sep 30 12:56:23 whitewolf conky[2671609]: No players found
Sep 30 12:56:23 whitewolf conky[2671615]: No players found
Sep 30 12:56:23 whitewolf conky[2671620]: No players found
Sep 30 12:56:23 whitewolf conky[2671637]: No players found
Sep 30 12:56:23 whitewolf conky[2671640]: No players found
Sep 30 12:56:23 whitewolf conky[2671646]: No players found
Sep 30 12:56:23 whitewolf conky[2671650]: No players found
Sep 30 12:56:23 whitewolf conky[2671655]: No players found
Sep 30 12:56:23 whitewolf conky[2671656]: No players found
Sep 30 12:56:23 whitewolf conky[2671657]: No players found
Sep 30 12:56:23 whitewolf conky[2671661]: No players found
Sep 30 12:56:24 whitewolf conky[2671678]: No players found
Sep 30 12:56:24 whitewolf conky[2671680]: No players found
Sep 30 12:56:24 whitewolf conky[2671681]: No players found
Sep 30 12:56:24 whitewolf conky[2671682]: No players found
Sep 30 12:56:24 whitewolf conky[2671686]: No players found
Sep 30 12:56:24 whitewolf conky[2671695]: No players found
Sep 30 12:56:24 whitewolf conky[2671697]: No players found
Sep 30 12:56:24 whitewolf conky[2671703]: No players found
Sep 30 12:56:24 whitewolf conky[2671715]: No players found
Sep 30 12:56:24 whitewolf conky[2671710]: No players found
Sep 30 12:56:24 whitewolf conky[2671723]: No players found
Sep 30 12:56:24 whitewolf conky[2671722]: No players found
Sep 30 12:56:24 whitewolf conky[2671718]: No players found
Sep 30 12:56:24 whitewolf conky[2671727]: No players found
Sep 30 12:56:25 whitewolf conky[2671747]: No players found
Sep 30 12:56:25 whitewolf conky[2671748]: No players found
Sep 30 12:56:25 whitewolf conky[2671746]: No players found
Sep 30 12:56:25 whitewolf conky[2671750]: No players found
Sep 30 12:56:25 whitewolf conky[2671754]: No players found
Sep 30 12:56:25 whitewolf conky[2671749]: No players found
Sep 30 12:56:25 whitewolf conky[2671776]: No players found
Sep 30 12:56:25 whitewolf conky[2671771]: No players found
Sep 30 12:56:25 whitewolf conky[2671784]: No players found
Sep 30 12:56:25 whitewolf conky[2671778]: No players found
Sep 30 12:56:25 whitewolf conky[2671782]: No players found
Sep 30 12:56:25 whitewolf conky[2671788]: No players found
Sep 30 12:56:25 whitewolf conky[2671793]: No players found
Sep 30 12:56:25 whitewolf conky[2671796]: No players found
Sep 30 12:56:26 whitewolf conky[2671814]: No players found
Sep 30 12:56:26 whitewolf conky[2671813]: No players found
Sep 30 12:56:26 whitewolf conky[2671817]: No players found
Sep 30 12:56:26 whitewolf conky[2671822]: No players found
Sep 30 12:56:26 whitewolf conky[2671832]: No players found
Sep 30 12:56:26 whitewolf conky[2671828]: No players found
Sep 30 12:56:26 whitewolf conky[2671847]: No players found
Sep 30 12:56:26 whitewolf conky[2671825]: No players found
Sep 30 12:56:26 whitewolf conky[2671850]: No players found
Sep 30 12:56:26 whitewolf conky[2671838]: No players found
Sep 30 12:56:26 whitewolf conky[2671844]: No players found
Sep 30 12:56:26 whitewolf conky[2671854]: No players found
Sep 30 12:56:26 whitewolf conky[2671861]: No players found
Sep 30 12:56:26 whitewolf conky[2671857]: No players found
Sep 30 12:56:27 whitewolf conky[2671881]: No players found
Sep 30 12:56:27 whitewolf conky[2671883]: No players found
Sep 30 12:56:27 whitewolf conky[2671882]: No players found
Sep 30 12:56:27 whitewolf conky[2671887]: No players found
Sep 30 12:56:27 whitewolf conky[2671890]: No players found
Sep 30 12:56:27 whitewolf conky[2671893]: No players found
Sep 30 12:56:27 whitewolf conky[2671900]: No players found
Sep 30 12:56:27 whitewolf conky[2671896]: No players found
Sep 30 12:56:27 whitewolf conky[2671909]: No players found
Sep 30 12:56:27 whitewolf conky[2671915]: No players found
Sep 30 12:56:27 whitewolf conky[2671919]: No players found
Sep 30 12:56:27 whitewolf conky[2671924]: No players found
Sep 30 12:56:27 whitewolf conky[2671928]: No players found
Sep 30 12:56:27 whitewolf conky[2671932]: No players found
Sep 30 12:56:28 whitewolf conky[2671945]: No players found
Sep 30 12:56:28 whitewolf conky[2671947]: No players found
Sep 30 12:56:28 whitewolf conky[2671948]: No players found
Sep 30 12:56:28 whitewolf conky[2671951]: No players found
Sep 30 12:56:28 whitewolf conky[2671953]: No players found
Sep 30 12:56:28 whitewolf conky[2671965]: No players found
Sep 30 12:56:28 whitewolf conky[2671970]: No players found
Sep 30 12:56:28 whitewolf conky[2671974]: No players found
Sep 30 12:56:28 whitewolf conky[2671977]: No players found
Sep 30 12:56:28 whitewolf conky[2671962]: No players found
Sep 30 12:56:28 whitewolf conky[2671986]: No players found
Sep 30 12:56:28 whitewolf conky[2671982]: No players found
Sep 30 12:56:28 whitewolf conky[2671996]: No players found
Sep 30 12:56:28 whitewolf conky[2671990]: No players found
Can you do it again without Conky running? Looks like there’s something in your Conky setup that isn’t quite right and it’s flooding your logs so you can’t see anything else.
yes i shall kill conky now
➜ ~ killall conky
➜ ~ journalctl -f
Sep 30 13:00:04 whitewolf kwin_wayland[1058]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsuppo
rted buffer GL_BACK_LEFT)
Sep 30 13:00:05 whitewolf kwin_wayland[1058]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsuppo
Sep 30 13:00:07 whitewolf rtkit-daemon[1134]: Supervising 8 threads of 5 processes of 1 users.
Sep 30 13:00:19 whitewolf baloo_file_extractor[2718]: qt.gui.imageio: libpng warning: iCCP: known incorrect sRGB pr
ofile
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"thot.observer.cpu", fil
eName: "/home/fj/.local/share/plasma/plasmoids/thot.observer.cpu/metadata.json") does not match requested format "P
lasma/Applet"
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"launchpadPlasma", fileN
ame: "/home/fj/.local/share/plasma/plasmoids/launchpadPlasma/metadata.json") does not match requested format "Plasm
a/Applet"
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"org.kde.MinimalMusic.P6
", fileName: "/home/fj/.local/share/plasma/plasmoids/org.kde.MinimalMusic.P6/metadata.json") does not match request
ed format "Plasma/Applet"
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"org.kde.windowtitle.For
k", fileName: "/home/fj/.local/share/plasma/plasmoids/org.kde.windowtitle.Fork/metadata.json") does not match reque
sted format "Plasma/Applet"
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"Date.Urban.kde", fileNa
me: "/home/fj/.local/share/plasma/plasmoids/Date.Urban.kde/metadata.json") does not match requested format "Plasma/
Applet"
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"Plasma.Control.Hub", fi
leName: "/home/fj/.local/share/plasma/plasmoids/Plasma.Control.Hub/metadata.json") does not match requested format
"Plasma/Applet"
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"Audio.Wave.Widget", fil
eName: "/home/fj/.local/share/plasma/plasmoids/Audio.Wave.Widget/metadata.json") does not match requested format "P
lasma/Applet"
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"org.kde.netspeedWidget"
, fileName: "/home/fj/.local/share/plasma/plasmoids/org.kde.netspeedWidget/metadata.json") does not match requested
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"org.kde.plasma.plasm6de
sktopindicator", fileName: "/home/fj/.local/share/plasma/plasmoids/org.kde.plasma.plasm6desktopindicator/metadata.j
son") does not match requested format "Plasma/Applet"
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"org.kde.plasma.clearclo
ck", fileName: "/home/fj/.local/share/plasma/plasmoids/org.kde.plasma.clearclock/metadata.json") does not match req
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"org.kde.shutdownOrSwitc
h", fileName: "/home/fj/.local/share/plasma/plasmoids/org.kde.shutdownOrSwitch/metadata.json") does not match reque
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"Weather.IntiSol.kde", f
ileName: "/home/fj/.local/share/plasma/plasmoids/Weather.IntiSol.kde/metadata.json") does not match requested forma
t "Plasma/Applet"
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"thot.observer.ram", fil
eName: "/home/fj/.local/share/plasma/plasmoids/thot.observer.ram/metadata.json") does not match requested format "P
lasma/Applet"
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"zayron.chaac.weather",
fileName: "/home/fj/.local/share/plasma/plasmoids/zayron.chaac.weather/metadata.json") does not match requested for
mat "Plasma/Applet"
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"OnlyText.Date.Kde", fil
eName: "/home/fj/.local/share/plasma/plasmoids/OnlyText.Date.Kde/metadata.json") does not match requested format "P
lasma/Applet"
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"org.kpple.kppleMenu", f
ileName: "/home/fj/.local/share/plasma/plasmoids/org.kpple.kppleMenu/metadata.json") does not match requested forma
t "Plasma/Applet"
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"zayron.simple.separator
", fileName: "/home/fj/.local/share/plasma/plasmoids/zayron.simple.separator/metadata.json") does not match request
Sep 30 13:00:19 whitewolf plasmashell[1336]: KPackageStructure of KPluginMetaData(pluginId:"org.kde.plasma.kweather
_1x4", fileName: "/usr/share/plasma/plasmoids/org.kde.plasma.kweather_1x4/metadata.json") does not match requested
Sep 30 13:00:23 whitewolf systemd[1006]: Started Konsole - Terminal.
Sep 30 13:00:23 whitewolf konsole[2687473]: kf.config.core: Watching absolute paths is not supported "/home/fj/.loc
al/share/color-schemes/DraculaPurple.colors"
Sep 30 13:00:23 whitewolf konsole[2687473]: org.kde.konsole.plugin.widget.sshmanager: Controller changed to Konsole
::SessionController(0x5dfe12dc0040)
Sep 30 13:00:32 whitewolf kwin_wayland[1058]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsuppo
Sep 30 13:00:33 whitewolf kwin_wayland[1058]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsuppo
Sep 30 13:00:46 whitewolf rtkit-daemon[1134]: Supervising 8 threads of 5 processes of 1 users.
Sep 30 13:01:26 whitewolf rtkit-daemon[1134]: Supervising 8 threads of 5 processes of 1 users.
Sep 30 13:02:06 whitewolf rtkit-daemon[1134]: Supervising 8 threads of 5 processes of 1 users.
Sep 30 13:02:46 whitewolf rtkit-daemon[1134]: Supervising 8 threads of 5 processes of 1 users.
Sep 30 13:02:57 whitewolf plasmashell[1336]: org.kde.pim.akonadi_search_pim: Xapian Database does not exist at "/h
ome/fj/.local/share/akonadi/search_db/contacts/"
ome/fj/.local/share/akonadi/search_db/emailContacts/"
Sep 30 13:02:59 whitewolf systemd[1006]: Started Welcome.
Sep 30 13:03:26 whitewolf rtkit-daemon[1134]: Supervising 8 threads of 5 processes of 1 users.
Odd, I see nothing unusual? SUPER confusing
this has a bit more info that it spat out:
➜  ~ eos-welcome --once
➜  ~ journalctl -f
Sep 30 13:04:46 whitewolf rtkit-daemon[1134]: Supervising 8 threads of 5 processes of 1 users.
Sep 30 13:05:26 whitewolf rtkit-daemon[1134]: Supervising 8 threads of 5 processes of 1 users.
Sep 30 13:06:06 whitewolf rtkit-daemon[1134]: Supervising 8 threads of 5 processes of 1 users.
Sep 30 13:06:46 whitewolf rtkit-daemon[1134]: Supervising 8 threads of 5 processes of 1 users.
Sep 30 13:07:26 whitewolf rtkit-daemon[1134]: Supervising 8 threads of 5 processes of 1 users.
Sep 30 13:07:36 whitewolf plasmashell[1336]: org.kde.pim.akonadi_search_pim: Xapian Database does not exist at  "/home/fj/.local/share/akonadi/search_db/contacts/"
Sep 30 13:07:36 whitewolf plasmashell[1336]: org.kde.pim.akonadi_search_pim: Xapian Database does not exist at  "/home/fj/.local/share/akonadi/search_db/emailContacts/"
Sep 30 13:07:37 whitewolf systemd[1006]: Started Welcome.
Sep 30 13:08:06 whitewolf rtkit-daemon[1134]: Supervising 8 threads of 5 processes of 1 users.
Sep 30 13:08:11 whitewolf wireplumber[1123]: wp-event-dispatcher: <WpAsyncEventHook:0x58b8e580a470> failed: <WpSiStandardLink:0x58b8e59fa470> link failed: 1 of 1 PipeWire links failed to activate
Sep 30 13:08:21 whitewolf baloo_file_extractor[2718]: qt.gui.imageio: libpng warning: iCCP: known incorrect sRGB profile
Sep 30 13:08:28 whitewolf baloo_file_extractor[2718]: "Error (251): Bad 'Length' attribute in stream"
Sep 30 13:08:28 whitewolf baloo_file_extractor[2718]: "Error (449): Missing 'endstream' or incorrect stream length"
Sep 30 13:08:28 whitewolf baloo_file_extractor[2718]: "Error: Unknown operator 'endstream'"
i thought for sure that would have worked. it should show what is going wrong shouldn’t it no matter what? odd when i open the welcome and run the journalctl -f command like you said nothing changes in the terminal really other than well NOTHING. :-\ i am enterataing the thought of a entire reinstall but idk. i would have to back up everything on my external. hmm… thank you for your time and effort though i foind it odd not even a hint in the termainl.
yeah when i get a chance i may just do a fresh install of endeavouros… the welcome thing is helpful
