Hi. When I check my list of running widgets it shows that I have 2 trash can instances running. However, there are none that are visible anywhere on the desktop or either of my panels. How can I address this discrepancy?
Thanks.
Thanks.
I found out how to solve my problem.
Open /.config/plasma-org.kde.plasma.desktop-appletsrc and removed the two references to the trash can widget. I restarted and the problem is gone.
