I’ve started encountering another issue where my PC lags and it’s not smooth at all, often when browsing. I’ve a fairly decent and modern computer, so it can handle a bunch of browser instances.
Not sure what’s causing the issue but any insights on what to look out for when the issue happens? It isn’t permanent but really annoying when it does occur.
The cursor movement lags along with the general app UI - to be more specific. I’ve encountered this in my browsers (Firefox and Chrome) and while using Neovim in the terminal (kitty).
If you need any details, please do let me know and I’ll happily provide. Would love to get this sorted.
I recorded a screencast for convenience. Apologies for the bad quality, I used the stock GNOME utility.
Try turning off hardware acceleration in your browsers and see if there is a difference.
For kitty, that’s the whole reason for using it, so I doubt it can be turned off, but you could try a non-hardware-accelerated terminal with Neovim to see if you still have the issue.
If the issues stop, then it probably means there is some possible firmware issue — maybe a BIOS update or drivers? Or switching to a different kernel?
I have the LTS kernel installed, and BIOS are up-to date as well as the drivers (running the latest 550.90 drivers). I’m not sure how much hardware acceleration will help since the issue is not only limited to the browsers, but I shall give it a shot.
In the meantime, I tried using wayland instead of X11 to see if the problem persists. Not entirely sure, but I believe the stutters or lag have not yet occurred. However, I have encountered two total system freezes. No matter how long I waited, it remained and I had to restart my PC to get it back working.
For context, I encounter these issues while trying to work on some projects. I have Neovim running, along with a node server for the project (using pnpm), and a browser.
Additionally, my setup is a dual-boot with Windows which I primarily use for gaming. Are there any logs that I can share which can shed more light on these problems?
You’ve already provided logs. The thing you can test is to watch your system processes while you are using the apps that lag often to see what’s happening.
