So I find when I’m copying and pasting large files on LibreOffice Calc from one sheet to another, it won’t paste more than about 1900 rows and 4 columns of data at a time.
It just won’t let me do it.
Anyone else experience this? Just trying to figure out if just my system or something more general.
LibreOffice desk at documentfoundation.org says there should be a copy button on the ‘about’ popup, under menu/help/about but having used Libreoffice for well over a decade on two versions of Linux I’ve never seen anything other than this? Can anyone confirm that’s what they see too?
Just look behind version information the icon of the two pages is the copy button just click on it (you don’t get a message that it has copied something).
As you can see below mine seems to work.
Version: 25.2.2.2 (X86_64) / LibreOffice Community
Build ID: 520(Build:2)
CPU threads: 12; OS: Linux 6.14; UI render: default; VCL: kf6 (cairo+wayland)
Locale: nl-NL (nl_NL.UTF-8); UI: nl-NL
25.2.2-2
Calc: threaded
Not sure if this would help you but after much angst in finding that every time I tried to save a huge Libreoffice .xlsx file (1500 rows, 6 columns, somewhat similar to yours) it would take about 30-60 seconds.
Then I (oops) made a “mistake” NOT as an .xlsx but as the native Libreoffice .odf file, and poof, down went the waiting to < 1 microsecond. Every time. With each save.
So when I have to deal with the corporate Windoze world and Micro$oft I just do a Save As .xlsx … once only.
Hope that might work for ya too…
Also, a great bunch of Office software is from a German company named SoftMaker. Their Freeoffice products (Planmaker for the Excel/LOffice equivalent … has been working great for me. I kinda switched to that instead because it’s beautiful (for me) to work with. Won’t run on Silicon Macs though, as far as I can tell.
To the right of the version information is a poorly defined icon in the screen grab above it and looks like a tiny set of folders, and it does ‘click’ without giving any notice of what if anything has happened. The troubleshooter over on the LibreOffice side has not given much verbal description, except saying there should be a copy button.
I’ve bumped that icon a couple of times, so maybe it copied.
I have to talk to the other side to see if what I did is enough or if there is another step
The save feature he’s trying to get me to use, doesn’t save it to my hard drive, it’s saving it somehow to where he can see it, at least that’s what he’s implying.
Well this is something that was copied by clicking the copy icon of libreoffice.
Now I pasted the copy to the forum and it gets uploaded to the forum.
What you call transmission is probably just about the same procedure.
What I meant to say is clicking on the copy icon doesn’t automagically will take care of that procedure.
In a new spreadsheet I created 10,000 rows and 5 columns worth of numerical data.
I created a new spreadsheet.
I copied the entire sheet of data from the first, to the second spreadsheet.
I confirmed all 10,000 rows copied.
Please, let me know if I’m misunderstood those steps.
CPU threads: 24; OS: Linux 6.14; UI render: default; VCL: kf6 (cairo+xcb)
Locale: en-AU (en_AU.UTF-8); UI: en-GB
25.2.2-2
Calc: CL threaded
It looks like you might be using libreoffice-still@mlytle0, which is ordinarily fine. But as you’ve encountered an issue, perhaps try installing libreoffice-fresh instead?
O.K. it’s late here in Houston, But on my wife’s machine, I deleted LibreOffice still and installed LibreOffice fresh. I also checked that she didn’t have a clipboard manager, and she doesn’t.
I run two machines of my own, one had clipman (as the file [
xfce4-clipman-plugin])(https://archlinux.org/packages/extra/x86_64/xfce4-clipman-plugin/), but I removed it for this troubleshooting as the LibreOffice support guy insisted this was the problem. The other machine, I use, never had that installed. In safe mode on all three machines, the bug is happening.
So 0 for 3, so far.
Tomorrow will be busy, as unfortunately she is moving to a care facility for her Parkinson’s so I may be out of pocket until Tuesday.
Mousepad and Gedit, nothing, of course this isn’t text, it’s date/time and numeric formats, but maybe that doesn’t matter.
I can paste to gnumeric from Libreoffice, if it’s over 2000 rows and higher, no problem, but I can only paste from Libreoffice to gnumeric if it’s 1900 rows or fewer.
I haven’t bothered to nail down what specific number the failure point in rows is, like 1942 rows or something like that.
