Weird font issue
Hello y’all!
Today i wanted to try the cutefish desktop environment, but after installing it and uninstalling it my fonts became weird in my terminal (alacritty).
I can’t find a way to fix it so please help me!
thanks in advance for any answer.
Screenshot_2022-06-23_18-42-01
What is the font? Is it still installed? (as in not removed in error).
Welcome to the forum. I hope you enjoy your time here.
Pudge
Thanks for the reply.
Here are my fonts settings in the xfce appearance settings :
Screenshot_2022-06-23_19-50-28
So i don’t if alacritty is using some special font or if it is the same font used in the rest of the OS that have an issue.
Alacritty defines it’s own font, normally ~/.config/alacritty/alacritty.yml
That file doesn’t exists, i also checked the 3 other files listed on the arch wiki and they don’t exit either.
From their gitub:
Configuration
You can find the default configuration file with documentation for all available fields on the GitHub releases page for each release.
Alacritty doesn’t create the config file for you, but it looks for one in the following locations:
$XDG_CONFIG_HOME/alacritty/alacritty.yml
$XDG_CONFIG_HOME/alacritty.yml
$HOME/.config/alacritty/alacritty.yml
$HOME/.alacritty.yml
i tried creating one at $XDG_CONFIG_HOME/alacritty/alacritty.yml
and put these settings that i grabbed from the arch wiki :
Screenshot_2022-06-23_20-00-47
but the issue is still there.
Try another font, list what you have with fc-list. I like fira code and jetbrains both in repo (I think!)
What is the result of this command?
fc-match monospace
Screenshot_2022-06-23_20-07-15
So change monospace to “Noto Sans”
It doesn’t work.
Sorry, no quotes my bad :smiley:
Try Noto Sans Mono.
it doesn’t work with both Noto Sans and Noto Sans Mono
Works for me:
fc-match "Noto Sans Mono"
Screenshot_2022-06-23_20-23-18
I resolved my issue by creating a config file in ~/.config/alacritty/alacritty.yml instead of $XDG_CONFIG_HOME/alacritty/alacritty.yml and setting the police to Noto Sans Mono.
Thanks a lot for your help!
