Weird emby problem
On the left - Vivaldi - doesn’t load.
On right - firefox. works.
Emby server at 192.168.4.131 never gets past the emby logo on vivaldi.
Fresh install, vivaldi is my choice and was working fine, prior to reinstall. Not caused by an extension (tried with --disable-extensions).
No firewall and can ping server (mini pc under TV). Help!
Works in vivaldi-snapshot - even weirder.
I use Emby too and I just installed Vivaldi. When I load my Emby server port 8096 the login page loads without issues, no idea why yours doesn’t though.
Going to wipe vivaldi and reinstall it - something somewhere is screwed up, especially since snapshot runs :grimacing:
Try removing the directory $HOME/.config/vivaldi and then restart Vivaldi and see what happens?
And if that doesn’t work. Try launching Vivalidi from the terminal and then try loading your Emby server to see what output you get then.
That is what I did - all working
