Weird dracut issues on Miniforum v3
This is a carry over from an earlier post:
If I rebuild dracut from a running system (sudo dracut-rebuild), the machine will not reboot.
If I chroot in from a live system - it works and I can reboot to my hearts content.
@dalto this is so weird.
 df -h        18:01:52
Filesystem            Size  Used Avail Use% Mounted on
/dev/nvme0n1p5        744G   82G  625G  12% /
devtmpfs              4.0M     0  4.0M   0% /dev
tmpfs                  15G   82M   15G   1% /dev/shm
efivarfs              128K   43K   81K  35% /sys/firmware/efi/efivars
tmpfs                 5.9G  2.2M  5.9G   1% /run
tmpfs                 1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
tmpfs                  15G   51M   15G   1% /tmp
/dev/nvme0n1p1         96M   54M   43M  56% /boot/efi
tmpfs                 3.0G  156K  3.0G   1% /run/user/1000
/dev/mmcblk0p1        500G   35G  466G   7% /media/microsd
//192.168.4.35/steve  2.7T  2.3T  479G  83% /media/steve
//192.168.4.35/mort   2.7T  2.3T  479G  83% /media/mort
htpc@192.168.4.131:/  259G   67G  180G  27% /home/xircon/htpc
Doesn’t seem to be a space issue. I am completely flumoxed.
I do get these errors at the start of the rebuild:
/gpg.conf: line 1: no-greeting: command not found
/gpg.conf: line 2: no-permission-warning: command not found
/gpg.conf: line 3: keyserver-options: command not found
/gpg.conf: line 4: keyserver-options: command not found
/gpg.conf: line 5: keyserver-options: command not found
/gpg-agent.conf: line 1: disable-scdaemon: command not found
But get them in the chroot to.
Is the uuid match in fstab?
Can you share the output from cat /etc/dracut.conf.d/*, cat /etc/kernel/cmdline and cat /etc/fstab and sudo dracut-rebuild
cat /etc/dracut.conf.d/*        18:33:49
omit_dracutmodules+=" network cifs nfs nbd brltty "
compress="zstd"
No /etc/kernel/cmdline - it’s grub not systemd-boot.
cat /etc/fstab        18:35:47
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=B4A6-EB4B                            /boot/efi      vfat    fmask=0137,dmask=0027 0 2
UUID=79ebe690-2589-4020-9aa4-644ae4215d45 /              ext4    noatime    0 1
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
UUID=EFED-F0F4                            /media/microsd exfat   noauto,rw,user 0 0
sudo dracut-rebuild        18:35:54
:: Building initramfs for linux (6.12.4-arch1-1)
dracut[I]: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline /boot/initramfs-linux.img 6.12.4-arch1-1
dracut[I]: *** Including module: bash ***
dracut[I]: *** Including module: shell-interpreter ***
dracut[I]: *** Including module: systemd ***
dracut[I]: *** Including module: systemd-ask-password ***
dracut[I]: *** Including module: systemd-initrd ***
dracut[I]: *** Including module: systemd-journald ***
dracut[I]: *** Including module: systemd-modules-load ***
dracut[I]: *** Including module: systemd-sysctl ***
dracut[I]: *** Including module: systemd-sysusers ***
dracut[I]: *** Including module: systemd-tmpfiles ***
dracut[I]: *** Including module: systemd-udevd ***
dracut[I]: *** Including module: i18n ***
dracut[I]: *** Including module: kernel-modules ***
dracut[I]: *** Including module: kernel-modules-extra ***
dracut[I]: *** Including module: hwdb ***
dracut[I]: *** Including module: resume ***
dracut[I]: *** Including module: rootfs-block ***
dracut[I]: *** Including module: terminfo ***
dracut[I]: *** Including module: udev-rules ***
dracut[I]: *** Including module: dracut-systemd ***
dracut[I]: *** Including module: usrmount ***
dracut[I]: *** Including module: base ***
dracut[I]: *** Including module: fs-lib ***
dracut[I]: *** Including module: shutdown ***
dracut[I]: *** Including modules done ***
dracut[I]: *** Installing kernel module dependencies ***
dracut[I]: *** Installing kernel module dependencies done ***
dracut[I]: *** Resolving executable dependencies ***
dracut[I]: *** Resolving executable dependencies done ***
dracut[I]: *** Hardlinking files ***
dracut[I]: *** Hardlinking files done ***
dracut[I]: *** Generating early-microcode cpio image ***
dracut[I]: *** Constructing AuthenticAMD.bin ***
dracut[I]: *** Store current command line parameters ***
dracut[I]: *** Stripping files ***
dracut[I]: *** Stripping files done ***
dracut[I]: *** Creating image file '/boot/initramfs-linux.img' ***
dracut[I]: *** Creating initramfs image file '/boot/initramfs-linux.img' done ***
:: Building fallback initramfs for linux (6.12.4-arch1-1)
dracut[I]: Executing: /usr/bin/dracut --force --no-hostonly /boot/initramfs-linux-fallback.img 6.12.4-arch1-1
dracut[I]: *** Including module: systemd-cryptsetup ***
dracut[I]: *** Including module: systemd-pcrphase ***
dracut[I]: *** Including module: modsign ***
dracut[I]: *** Including module: btrfs ***
dracut[I]: *** Including module: crypt ***
dracut[I]: *** Including module: dm ***
dracut[I]: *** Including module: lvm ***
dracut[I]: *** Including module: mdraid ***
dracut[I]: *** Including module: nvdimm ***
dracut[I]: *** Including module: qemu ***
dracut[I]: *** Including module: qemu-net ***
dracut[I]: *** Including module: btrfs-snapshot-overlay ***
dracut[I]: *** Including module: fido2 ***
dracut[I]: *** Including module: pkcs11 ***
dracut[I]: *** Including module: lunmask ***
dracut[I]: *** Including module: virtiofs ***
dracut[I]: *** Creating image file '/boot/initramfs-linux-fallback.img' ***
dracut[I]: *** Creating initramfs image file '/boot/initramfs-linux-fallback.img' done ***
:: Building initramfs for linux-lts (6.6.65-1-lts)
dracut[I]: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline /boot/initramfs-linux-lts.img 6.6.65-1-lts
dracut[I]: *** Creating image file '/boot/initramfs-linux-lts.img' ***
dracut[I]: *** Creating initramfs image file '/boot/initramfs-linux-lts.img' done ***
:: Building fallback initramfs for linux-lts (6.6.65-1-lts)
dracut[I]: Executing: /usr/bin/dracut --force --no-hostonly /boot/initramfs-linux-lts-fallback.img 6.6.65-1-lts
dracut[I]: *** Creating image file '/boot/initramfs-linux-lts-fallback.img' ***
dracut[I]: *** Creating initramfs image file '/boot/initramfs-linux-lts-fallback.img' done ***
There will be a short delay as I chroot in and redo it from chroot :smiley:
Be right back.
Oops, can you share /boot/grub/grub.cfg then?
First off - here is the dracut from the live system:
[liveuser@eos-2024.06.25 ~]$ sudo mount /dev/nvme0n1p5 /mnt
sudo mount /dev/nvme0n1p1 /mnt/boot/efi
sudo arch-chroot /mnt
[root@EndeavourOS /]#
[root@EndeavourOS /]# sudo dracut-rebuild
dracut[W]: Running in hostonly mode in a container!
On grub now
sudo cat /boot/grub/grub.cfg        18:48:11
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
  load_env
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
if [ x$feature_default_font_path = xy ] ; then
   font=unicode
else
insmod part_gpt
insmod ext2
search --no-floppy --fs-uuid --set=root 79ebe690-2589-4020-9aa4-644ae4215d45
    font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
  set locale_dir=$prefix/locale
  set lang=en_GB
  insmod gettext
fi
terminal_input console
terminal_output gfxterm
insmod part_gpt
insmod ext2
insmod gfxmenu
loadfont ($root)/usr/share/grub/themes/tela-color-2k/terminus-12.pf2
loadfont ($root)/usr/share/grub/themes/tela-color-2k/terminus-14.pf2
loadfont ($root)/usr/share/grub/themes/tela-color-2k/terminus-16.pf2
loadfont ($root)/usr/share/grub/themes/tela-color-2k/terminus-18.pf2
loadfont ($root)/usr/share/grub/themes/tela-color-2k/unifont-16.pf2
loadfont ($root)/usr/share/grub/themes/tela-color-2k/unifont-24.pf2
loadfont ($root)/usr/share/grub/themes/tela-color-2k/unifont-32.pf2
insmod jpeg
insmod png
set theme=($root)/usr/share/grub/themes/tela-color-2k/theme.txt
export theme
if [ x$feature_timeout_style = xy ] ; then
  set timeout_style=menu
  set timeout=5
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
  set timeout=5
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'EndeavourOS Linux, with Linux linux-lts' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-lts-advanced-79ebe690-2589-4020-9aa4-644ae4215d45' {
	savedefault
	load_video
	set gfxpayload=keep
	insmod gzio
	insmod part_gpt
	insmod ext2
	echo	'Loading Linux linux-lts ...'
	linux	/boot/vmlinuz-linux-lts root=UUID=79ebe690-2589-4020-9aa4-644ae4215d45 rw  fsck.mode=force nvme_load=YES pci=nommconf rw root=UUID=79ebe690-2589-4020-9aa4-644ae4215d45 resume=UUID=0942ac91-77f1-46a0-b31e-e10933c7b1bbv nowatchdog loglevel=3
	echo	'Loading initial ramdisk ...'
	initrd	/boot/initramfs-linux-lts.img
menuentry 'EndeavourOS Linux, with Linux linux-lts (fallback initramfs)' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-lts-fallback-79ebe690-2589-4020-9aa4-644ae4215d45' {
	savedefault
	load_video
	set gfxpayload=keep
	insmod gzio
	insmod part_gpt
	insmod ext2
	initrd	/boot/initramfs-linux-lts-fallback.img
menuentry 'EndeavourOS Linux, with Linux linux' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-advanced-79ebe690-2589-4020-9aa4-644ae4215d45' {
	savedefault
	load_video
	set gfxpayload=keep
	insmod gzio
	insmod part_gpt
	insmod ext2
	echo	'Loading Linux linux ...'
	linux	/boot/vmlinuz-linux root=UUID=79ebe690-2589-4020-9aa4-644ae4215d45 rw  fsck.mode=force nvme_load=YES pci=nommconf rw root=UUID=79ebe690-2589-4020-9aa4-644ae4215d45 resume=UUID=0942ac91-77f1-46a0-b31e-e10933c7b1bbv nowatchdog loglevel=3
	initrd	/boot/initramfs-linux.img
menuentry 'EndeavourOS Linux, with Linux linux (fallback initramfs)' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-fallback-79ebe690-2589-4020-9aa4-644ae4215d45' {
	savedefault
	load_video
	set gfxpayload=keep
	insmod gzio
	insmod part_gpt
	insmod ext2
	initrd	/boot/initramfs-linux-fallback.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/25_bli ###
if [ "$grub_platform" = "efi" ]; then
  insmod bli
fi
### END /etc/grub.d/25_bli ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
	fwsetup --is-supported
	if [ "$?" = 0 ]; then
		menuentry 'UEFI Firmware Settings' $menuentry_id_option 'uefi-firmware' {
			fwsetup
	fi
fi
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/35_fwupd ###
### END /etc/grub.d/35_fwupd ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/45_eos_windows ###
menuentry 'Windows Boot Manager (on /dev/nvme0n1p1)' --class windows --class os $menuentry_id_option 'osprober-efi-B4A6-EB4B' {
	insmod part_gpt
	insmod fat
	search --no-floppy --fs-uuid --set=root B4A6-EB4B
	chainloader /EFI/Microsoft/Boot/bootmgfw.efi
### END /etc/grub.d/45_eos_windows ###
cat /etc/default/grub        18:49:06
# GRUB boot loader configuration
GRUB_DEFAULT='saved'
GRUB_TIMEOUT='5'
GRUB_DISTRIBUTOR='EndeavourOS'
GRUB_CMDLINE_LINUX_DEFAULT='fsck.mode=force nvme_load=YES pci=nommconf rw root=UUID=79ebe690-2589-4020-9aa4-644ae4215d45 resume=UUID=0942ac91-77f1-46a0-b31e-e10933c7b1bbv nowatchdog loglevel=3'
GRUB_CMDLINE_LINUX=""
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=menu
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `videoinfo'
GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY='true'
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
GRUB_BACKGROUND='/usr/share/endeavouros/splash.png'
#GRUB_THEME="/path/to/gfxtheme"
GRUB_THEME="/usr/share/grub/themes/tela-color-2k/theme.txt"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
GRUB_DISABLE_SUBMENU='true'
# Probing for other operating systems is disabled for security reasons. Read
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
# functionality install os-prober and uncomment to detect and include other
# operating systems.
#GRUB_DISABLE_OS_PROBER=false
GRUB_EARLY_INITRD_LINUX_STOCK=''
What is your resume device? Is that a swap partition?
Also, when you are in the failed state, does booting the fallback help?
Good spot, I do not (and have never had) a swap file. No idea where it came from…
Removed, rebuilt, rebooted - all good, I have been struggling with this for hours. Thanks guys. esp @dalto :smiley:
Wonder where the hell it came / what the hell I did!
