This is one of the weirdest bluetooth behavior I have encountered.
Steps how this behaves for me:
I connect the bluetooth headphones to the system (I hear short pop when that happens)
I watch YouTube, Netflix, or listen to radio/streaming service
I take a break from watching, still with my headphones in ear, just pause or do some other work and I don’t play anything for some X minutes
I start playing something again (new video, or something) and there is no sound. Headphones are still connected, I can check status on them, see that they are connected, just no sound being transferred. THINGS ARE NOT ON MUTE (I did check, and double check)!!!
I disconnect and connect headphones and start watching/listening, this time sound works.
This is without a doupt the weirdes behavior I have experienced. I just put up kde instad of gnome. Did not experience this on gnome or any other device.
Headphones are Mii earbuds S2
inxi
Did you try using a different kernel yet (e.g. lts)? In the past, there happened to be kernel-regressions with regards to bluetooth, so trying a different kernel might help.
I’ve had several issues with bluedevil and weird Bluetooth issues as well. Might want to check KDE Bug reports also to see if there is anything relevant there.
I’ve been experiencing this problem, as well as frequent disconnects while using my bluetooth earbuds. I switched from linux ZEN to LTS and for now it seems the problem has been mitigated on my side.
Can confirm, after some more testing it seems that after a minute or less of silence the earbuds disconnect if I start playing something. Sometimes they even disconnect while something is playing too which is really annoying
There is an open bug report regarding this issue with Intel AX20x bluetooth devices which is apparently connected to linux-firmware:
Following the bug log from the link it has been around for quite a while but seems to disappear and to reappear with different linux-firmware versions.
While on gnome, (just about 2 weeks since I changed to kde), I never had this issue. Not even once. My headphones even connected automatically if the computer went to sleep.
The current version of linux-firmware is 20230210.bf4115c-1
Last updated 2023-02-17 on the arch repo. So that might indeed be the issue here, if you didn’t have it around 2 weeks ago. If you want to elaborate you could downgrade to the previous version of linux-firmware and see if it still happens.
Edit: For downgrading to the previous package version you can use the the Arch Linux Archive with: sudo pacman -U https://archive.archlinux.org/packages/l/linux-firmware/linux-firmware-20230117.7e4f0ed-1-any.pkg.tar.zst
or you use the package from your pacman cache if you still have it
Well, up to you of course. It might be linked to linux-firmware. That package gets updated about once a month. So, it might solve itself.
If you want to know whether the problem is connected to this package you could do the downgrade. I think it shouldn’t cause any issues and you could just upgrade it again with your next system upgrade.
But I of course can also understand that you don’t want to play around if it doesn’t bother you too much.
I’ve had this issue before, and filed a bug report for it before. As you’ve found, this is a recurring issue with the AX2xx devices. I can confirm it affects both the AX200 and AX210.
