Ok so i think i do not apply for a iso tester.
Of course you, are, we also need enthusiastic testers for other hardware. ![]()
I can offer testing for a 1080 Ti.
I could sign up for testing on older Mac hardware in VirtualBox, and on bare-metal in limited cases, should there be any ‘really felt need’ for this, at all. The Apollo-Iso already failed, big-time on the bare-metal mentioned…
I have a Acer Nitro laptop with hybrid graphics with Nvidia RTX 2060 and intel. If you need anymore testers
I can help w/ testing, I am doing that kind of stuff all the time. Have multiple machines, and can test on all. Lot of old hardware.
hey there
im willing to test that
got 1 Laptop and 2 PCs
laptop :
Memory:
RAM: total: 15.5 GiB used: 2.88 GiB (18.6%)
RAM Report:
permissions: Unable to run dmidecode. Root privileges required.
Info: dual core model: Intel Core i5-6200U bits: 64 type: MT MCP
arch: Skylake rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 500 min/max: 400/2800 cores: 1: 500 2: 500 3: 500
4: 500 bogomips: 19204
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM107 [GeForce 940MX] vendor: Acer Incorporated ALI
driver: nvidia v: 515.43.04 arch: Maxwell bus-ID: 01:00.0
Device-3: Realtek HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:3
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: modesetting
gpu: i915 resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.1.0
direct render: Yes
Local Storage: total: 223.57 GiB used: 121.56 GiB (54.4%)
ID-1: /dev/sda vendor: Kingston model: SUV400S37 240GB size: 223.57 GiB
PC #1 → 32GB ddr4, 12700k, 3080ti
PC #2 → 8GB DDR3, 4790k, 970
@Bryanpwo you can add me as tester too, Laptop Quadro P620 & Desktop Quadro K420
Well , I am interested in testing the ISO as doing my bachelor’s I can across many Linux distributions so I hope my experience will help you in any way
Don’t know if it’s any use but I run as a VM on top of qemu with a 6900XT and 2 of the the following USB controllers passed through.
Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
yea i do think about such setup using Nvidia GPU to test Nvidia driver issues ![]()
If a VM can use the real hardware, it is good idea to test that way as well. ![]()
Hello, I would like to be a ISO tester and help if I can.
Tim
Can i get the ISO tester title too? as i help testing out the ISOs too at times
@bittin My apologies for the late reaction, at the time you posted testing was done.
But I will add you to the group, as a translator the info could come in handy.
Thank you, no worries
This is now pinned 3 years later, which suggests we’re still in need of EOS ISO testers? If so I’m happy to help…
2019 iMac desktop
2011 MacBook pro laptop
2012.'ish Dell Optiplex
2011’ish Mac mini
it will always be needed we are rolling forward all the time and every ISO will pass deep testings to be stable and save to use ![]()
Is there something special one needs to do, or simply burn ISO stick and run, observe, and report?
The link up way above the generates a 404 error.
