Hello! I switched to Wayland after the Nvidia 555 drivers were released, as they solve the flickering issue that I was having for XWayland apps. The problem is, Pipewire randomly restarts or something happens which causes the entire audio system to restart. Moreover, YouTube videos do not play audio sometimes. Clicking the play button twice makes the audio return to the videos.
Is anyone else having this problem as well? What information do I have to give to get an idea of where this problem might lie?
Similar sound problem after updating June 29th. Seems to be pipewire v1.2.0 is causing the issue. I had to revert pipewire to v1.0.7 to correct the problem. Still no resolve yet that I can see.
I see. I was told that Easy Effects might be the thing that is causing the problem. I am not sure yet. There is an update that was released right now. Probably it has an update that will fix this issue.
first figure out if it is what is causing the problem, try not using easyeffects, see if the audio still crashes then.
If it doesnât, then easyeffects is the problem, so what you should try to do then is remove all your effects except 1, and then test 1 effect at a time to see if a specific effect is causing the issue.
And if it is THEN you go report the bug to the easyeffect dev assuming nobody else beat you to it.
I stopped using Easy Effects completely. That doesnât seem to be the problem. The YouTube bug is still present. The video audio doesnât play, unless I stop the video using the play button and then click the play button again.
After a while, I think KWin crashes entirely. It isnât just the audio that crashes.
I donât think itâs a pipewire issue if it only happens on wayland (You are still using pipewire on X too), itâs possible but unlikely, you said youâre on nvidia, are you using the nvidia hdmi audio or something like that? If you are, does the isssue occur still when you just use headphones plugged into the jack or something and leave the hdim audio off?
I think it might be an Nvidia HDMI audio issue. However, I am using USB Headphones. One of my screens uses Nvidia HDMI audio. Ever since putting ânvidia.NVreg_EnableGpuFirmware=0â inside of the grub.cfg file on âGRUB_CMDLINE_LINUX_DEFAULT=â the crash doesnât seem to happen. However, the YouTube audio problem still exists.
I have even told the KDE folks about this. I am quite sure it is an Nvidia problem, with the 555 drivers. Possibly due to explicit sync.
Well, the crash happened again. The only thing that I know that might be causing it is the NVIDIA driver. The crash does not happen whatsoever on X11. It might be an explicit sync issue. I wish I could find out through a log what goes wrong. I can then help other people who might have similar problem.
For anyone experiencing this issue, consider using Linux Zen kernel, which does not have this problem. There might be an effect in Easy Effects that I am using which does not work well on Wayland and is possibly related to Output Streams not being managed properly. Consider disabling the Easy Effects âserviceâ on startup and you should not have the crashes any longer.
