Wayland Dual Monitor Issue
Hey there,
I use Wayland Hyprland, wlr-randr as an alternative to xrandr. Anyways, moving to the main issue.
I was recently trying to output my laptop screen to my TV using an hdmi cable, after a few configs, i got everything working just Perfectly. Except one thing, i cant turn off my laptop screen and it just eats my cpu power and battery.
I tried wlr-randr --output eDP-1 -off, and it restarted the gui of both my laptop and my tv screen. Which ended up bringing me to the login screen.
So, i was wondering, if anyone of you can suggest me a fix for this. I would be thankful, if you do so.
Kudos!
Hi I have been having display issues as well.
Can you help us help you by displaying the following outputs in a terminal?
xrandr --listmonitors
xrandr
Thanks.
Data
As i have mentioned, i use wlr-randr since xrandr does not work on wayland. But i will provide you with the data you asked for.
xrandr output:
20220915_123658
wlr-randr output:
20220915_123752
Sorry for bad quality, since i have to take this from my phone because electricity is gone and my WiFi will not work.
Forgot to mention, that i tried xrandr in budgie and it works perfectly fine. Its either a wlr-randr issue or wayland issue.
And tried with kanshi or wldisplays?
I am assuming there are gui display tools for wayland, which i have not tried any yet. Lemme do so pretty quickly.
i dont know how to use kanshi, so i used wdisplays, and it ended up doing the same thing as wlr-randr.
yeah i am kinda noob in this :slight_smile:
No issues, thanks for the attempt though.
Hi, did you ended up with a solution :slight_smile:
