(i’m asking here because the problem might not be related to Waydroid itself)
I installed Waydroid following the instructions from the Arch wiki and it works OK.
Since Waydroid does not support NVIDIA cards, renders using swiftshader (CPU) and when im using graphics intensive apps (games) it gets pretty hot. So I added a Radeon card that I had sitting collecting dust and installed its drivers: yay -S xf86-video-amdgpu mesa vulkan-radeon. Then reinstalled Waydroid and it detected my Radeon
But it didn’t start. Waydroid icon appears briefly in the taskbar and disappears in a loop until waydroid session stop is run. Later i downgraded to LineageOS build 20240217 because someone on github mentioned a similar problem with their Radeon card. I ran the waydroid-choose-gpu.sh script and now it works but a black screen appeared (sounds from Android are played also). In AMDGPU_TOP i can see signs of activity in the card and my CPU fans didn’t ramp up.
If i run waydroid using waydroid show-full-ui and open apps in multi-window mode, sometimes i can get some frames of the screen or apps and i can (very briefly) interact with them.
My goal is to get waydroid running using only the Radeon card
I guess is the problem is related to XOrg (misconfiguration, frame sync)?
I have the following setup:
- EndeavourOS + Zen kernel 6.9.7
- KDE Plasma 6.1 + Kwin
- Waydroid 1.4.2
- a NVIDIA card (my main card)
- an old AMD Radeon RX 550
inxi -G
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
driver: amdgpu v: kernel
Device-2: NVIDIA GM204 [GeForce GTX 980] driver: nvidia v: 555.58.02
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
unloaded: modesetting dri: radeonsi gpu: amdgpu,nvidia resolution:
1: 1366x768 2: 1920x1080
API: EGL v: 1.5 drivers: nvidia,radeonsi,swrast,zink
platforms: gbm,wayland,x11,surfaceless,device
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.58.02
renderer: NVIDIA GeForce GTX 980/PCIe/SSE2
API: Vulkan v: 1.3.279 drivers: nvidia,radv surfaces: xcb,xlib,wayland
Contents of /var/lib/waydroid/waydroid_base.prop (idk if relevant)
ro.hardware.gralloc=gbm
ro.hardware.egl=mesa
ro.hardware.vulkan=radeon
