Waybar not starting and background not setting up on startup
Hello, i just installed endeavouros-sway, everything works well, however, after configuring what i needed, on startup the background is the default one and the waybar doesn’t start at all. However, if i logout and login again everything is fine, so i don’t think i messed up the config files. Does someone have any fix for this?
edit: the waybar now has no issues, however the background gets set and immediately reset to the default one, sometimes logging out fixes it, sometimes it doesn’t
(1) did it all work ok before you change thing ?
(2) need more info what you change . also did you make backup of config before you change thing .
  1. Yes it worked perfectly fine and even now it work all right, i just have to log out and back in
  2. no i was dumb enough not to make a backup, but i can retrieve one from another device with the same installation. the changes i made were minimal: i switched two sway keybindings, added a line so that the focus doesn’t follow the mouse and the exact same line that is in the cheatsheet to set the background.
you add line to set background ? if you add , where you add
( i ask as that already in config)
or you change this line
" # Set wallpaper:
exec swaybg -i ~/.config/sway/sway.png "
EDit… this line in cheatsheet is for show you how you can set different wallpaper + where that line is.
  # Wallpaper - ~/.config/sway/config.d/theme
    # exec swaybg -i /path/to/wallpaper
it no say add this line .
EDit (2)
I change from " general system bug report " It now " Desktop Envir Sway "
it no bug imo.
i added the line with the modified path in the “theme” file (knowing already the command set the background). How should have i done it? Should have i uncommented the lines and changed the path to the wallpaper?
# Set wallpaper:
that in your " ~/.config/sway/config.d/theme "
you just change path from " ~/.config/sway/sway.png " to where you wallpaper is . save file log out. next time you log in your wallpaper is used
Hello
If you launch waybar in a terminal it will tell you if you have an error on the waybar config file.
that’s what i did though
sway is only Environment or you have more DE installed?
pls post your
" ~/.config/sway/config.d/autostart_applications "
pls use (</>) button
# Auth with polkit-gnome:
exec /usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1
# Desktop notifications
exec mako
# Network Applet
exec nm-applet --indicator
# GTK3 applications take a long time to start
exec systemctl --user import-environment DISPLAY WAYLAND_DISPLAY SWAYSOCK
exec hash dbus-update-activation-environment 2>/dev/null && \
     dbus-update-activation-environment --systemd DISPLAY WAYLAND_DISPLAY SWAYSOCK
# Welcome App
exec dex -a -s /etc/xdg/autostart/:~/.config/autostart/
# Sway Fader
# exec python3 ~/.config/sway/scripts/swayfader.py
sway the only installed? or you have gnome,kde,xfce or other endeavouros DE’s as well
should be, i’ve installed the community version with sway, i didn’t install the wm myself. Meaning no other desktop enviroments should be present
" the background gets set and immediately reset to the default one, sometimes logging out fixes it, sometimes it doesn’t "
last idea for me tonight . i need sleep :pray:
#out
# Welcome App
#exec dex -a -s /etc/xdg/autostart/:~/.config/autostart/
save then log out .
all i can think if you configure right .
it worked, thank you so much. Still don’t know what i did exactly though ahah
glad you fix it … hope you enjoy rest of your time on Endeavouros .
sway great choice BTW
