Waybar issues (random dissapearances)
Waybar will sometimes not launch for me when I boot up. It seems this has become more the rule than the exception. The only way I can get it back is by running the waybar command in the terminal and then I have to leave that terminal open and running to have waybar. I also encounter the same issues whenever I plug my laptop to an external monitor. Does anyone know if this error is a compatibility issue with a package?
Here is the error code when I run waybar in the terminal:
[2022-01-17 17:21:09.344] [info] Using configuration file /home/jerry/.config/waybar/config
[2022-01-17 17:21:09.344] [info] Using CSS file /home/jerry/.config/waybar/style.css
(waybar:1526): Gtk-WARNING **: 17:21:09.344: Theme parsing error: style.css:151:13: Not using units is deprecated. Assuming 'px'.
[2022-01-17 17:21:09.355] [warning] As using a timezone, some format args may be missing as the date library haven't got a release since 2018.
[2022-01-17 17:21:09.355] [warning] For a functional tray you must have libappindicator-* installed and export XDG_CURRENT_DESKTOP=Unity
** (waybar:1526): WARNING **: 17:21:09.376: gtk-layer-shell v0.6.0 may not work on GTK v3.24.31. If you experience crashes, check https://github.com/wmww/gtk-layer-shell/blob/master/compatibility.md
[2022-01-17 17:21:09.537] [warning] Requested height: 30 is less than the minimum height: 33 required by the modules
[2022-01-17 17:21:09.537] [info] Bar configured (width: 1920, height: 33) for output: eDP-1
** (waybar:1526): WARNING **: 17:21:09.541: Status Notifier Item with bus name ':1.4' and object path '/org/ayatana/NotificationItem/nm_applet' is already registered
[2022-01-17 17:21:09.580] [warning] Requested height: 33 is less than the minimum height: 38 required by the modules
[2022-01-17 17:21:09.580] [info] Bar configured (width: 1920, height: 38) for output: eDP-1
parse error: Invalid numeric literal at line 1, column 7
[2022-01-17 17:21:11.256] [error] : * Line 1, Column 46
  Syntax error: value, object or array expected.
[2022-01-17 17:31:13.630] [error] : * Line 1, Column 46
[2022-01-17 17:41:16.159] [error] : * Line 1, Column 46
[2022-01-17 17:51:18.363] [error] : * Line 1, Column 46
What happens if you use the default config/css?
I think the only thing that I changed about the CSS was the clock module to have a different format. Do you think that would break it?
Test with the defaults. If things work, then looking into your config, css and custom modules would be the way to go.
Will do!
Welcome to :enos: forums.
It does seem like a syntax error according to the messages.
I looked up the waybar config file on the github page to find the defaults. I changed everything back to default and it seems to be working! Plugged it in to monitor as well, and it works just fine.
I have pretty much the same errors, I made a couple modification to the css and the modules too.
Did not have the time to look into it.
Summary
(waybar:159547): Gtk-WARNING **: 21:29:32.318: Theme parsing error: style.css:150:13: Not using units is deprecated. Assuming 'px'.
[2022-01-17 21:29:32.337] [warning] For a functional tray you must have libappindicator-* installed and export XDG_CURRENT_DESKTOP=Unity
[2022-01-17 21:29:32.338] [warning] As using a timezone, some format args may be missing as the date library haven't got a release since 2018.
** (waybar:159547): WARNING **: 21:29:32.367: gtk-layer-shell v0.6.0 may not work on GTK v3.24.31. If you experience crashes, check https://github.com/wmww/gtk-layer-shell/blob/master/compatibility.md
(waybar:159547): GLib-GObject-WARNING **: 21:29:32.368: ../glib/gobject/gsignal.c:2081: type 'GtkWindow' is already overridden for signal id '73'
(waybar:159547): GLib-GObject-WARNING **: 21:29:32.368: ../glib/gobject/gsignal.c:2081: type 'GtkWindow' is already overridden for signal id '72'
[2022-01-17 21:29:32.380] [warning] For a functional tray you must have libappindicator-* installed and export XDG_CURRENT_DESKTOP=Unity
[2022-01-17 21:29:32.382] [warning] As using a timezone, some format args may be missing as the date library haven't got a release since 2018.
(waybar:159547): GLib-GObject-WARNING **: 21:29:32.385: ../glib/gobject/gsignal.c:2081: type 'GtkWindow' is already overridden for signal id '73'
(waybar:159547): GLib-GObject-WARNING **: 21:29:32.385: ../glib/gobject/gsignal.c:2081: type 'GtkWindow' is already overridden for signal id '72'
[2022-01-17 21:29:32.405] [warning] For a functional tray you must have libappindicator-* installed and export XDG_CURRENT_DESKTOP=Unity
[2022-01-17 21:29:32.406] [warning] As using a timezone, some format args may be missing as the date library haven't got a release since 2018.
** (waybar:159547): WARNING **: 21:29:32.659: Status Notifier Item with bus name ':1.2079' and object path '/org/ayatana/NotificationItem/nm_applet' is already registered
[2022-01-17 21:29:32.838] [warning] Requested height: 28 is less than the minimum height: 47 required by the modules
[2022-01-17 21:29:32.838] [info] Bar configured (width: 3840, height: 47) for output: HDMI-A-1
[2022-01-17 21:29:32.840] [warning] Requested height: 28 is less than the minimum height: 47 required by the modules
[2022-01-17 21:29:32.840] [info] Bar configured (width: 3840, height: 47) for output: DP-3
[2022-01-17 21:29:32.840] [info] Bar configured (width: 3840, height: 47) for output: DP-2
[2022-01-17 21:29:33.522] [error] : * Line 1, Column 46
[2022-01-17 21:29:33.531] [error] : * Line 1, Column 46
[2022-01-17 21:29:33.533] [error] 1: * Line 1, Column 46
Yeah, those look like very similar to what I had going on. The only thing I changed was the config file.
The changes I made to the waybar config:
  1. Commented out the keyboard language module
  2. Changed the clock to have AM/PM values
  3. Changed the workspaces to not have the icons e.g. just 1, 2, 3 ,4 etc
I guess I am going to have to be very careful how I change anything on waybar
IIRC, the defaults should be in /etc/xdg/waybar.
