Warning: ...: local newer than
Hey there. After system update I’m getting what looks like several hundreds of errors for individual packages.
sudo pacman -Syyu
 endeavouros        14.4 KiB   248 KiB/s 00:00 [--------------------------------------------------------------------------------------] 100%
 core        121.6 KiB  2.64 MiB/s 00:00 [--------------------------------------------------------------------------------------] 100%
 extra        7.9 MiB  3.79 MiB/s 00:02 [--------------------------------------------------------------------------------------] 100%
 community        45.0   B   865   B/s 00:00 [--------------------------------------------------------------------------------------] 100%
 multilib        130.8 KiB  2.51 MiB/s 00:00 [--------------------------------------------------------------------------------------] 100%
warning: abseil-cpp: local (20240722.0-1) is newer than extra (20240116.2-2)
warning: acpi: local (1.7-4) is newer than extra (1.7-3)
warning: adobe-source-code-pro-fonts: local (2.042u+1.062i+1.026vf-2) is newer than extra (2.042u+1.062i+1.026vf-1)
warning: adwaita-cursors: local (47.0-1) is newer than extra (46.2-1)
warning: adwaita-icon-theme: local (47.0-1) is newer than extra (46.2-1)
warning: adwaita-icon-theme-legacy: local (46.2-3) is newer than extra (46.2-1)
warning: alacritty: local (0.15.0-1) is newer than extra (0.13.2-2)
warning: alsa-card-profiles: local (1:1.2.7-1) is newer than extra (1:1.2.0-2)
warning: alsa-firmware: local (1.2.4-4) is newer than extra (1.2.4-3)
warning: alsa-lib: local (1.2.13-1) is newer than extra (1.2.12-1)
warning: alsa-plugins: local (1:1.2.12-4) is newer than extra (1:1.2.12-2)
warning: alsa-topology-conf: local (1.2.5.1-4) is newer than extra (1.2.5.1-3)
warning: alsa-ucm-conf: local (1.2.13-2) is newer than extra (1.2.12-1)
warning: alsa-utils: local (1.2.13-2) is newer than extra (1.2.12-1)
warning: amd-ucode: local (20250109.7673dffd-1) is newer than core (20240610.9c10a208-1)
warning: aom: local (3.11.0-1) is newer than extra (3.9.1-1)
warning: appstream: local (1.0.4-1) is newer than extra (1.0.3-1)
warning: arandr: local (0.1.11-4) is newer than extra (0.1.11-3)
warning: archlinux-keyring: local (20241203-1) is newer than core (20240609-1)
warning: archlinux-xdg-menu: local (0.7.6.6-2) is newer than extra (0.7.6.6-1)
warning: arduino-cli: local (1.1.1-1) is newer than extra (0.35.3-1)
warning: argon2: local (20190702-6) is newer than core (20190702-5)
warning: ark: local (24.12.1-1) is newer than extra (24.05.1-1)
warning: at-spi2-core: local (2.54.1-1) is newer than extra (2.52.0-1)
warning: audacity: local (1:3.7.1-1) is newer than extra (1:3.5.1-3)
warning: audit: local (4.0.2-3) is newer than core (4.0.1-3)
warning: automake: local (1.17-1) is newer than core (1.16.5-2)
warning: avahi: local (1:0.8+r194+g3f79789-3) is newer than extra (1:0.8+r194+g3f79789-2)
warning: b43-fwcutter: local (019-5) is newer than core (019-4)
warning: babl: local (0.1.110-1) is newer than extra (0.1.108-1)
warning: bash: local (5.2.037-1) is newer than core (5.2.026-2)
warning: bash-completion: local (2.16.0-1) is newer than extra (2.14.0-2)
warning: bind: local (9.20.4-2) is newer than extra (9.18.27-1)
warning: binutils: local (2.43_1+r171+g01da089627be-1) is newer than core (2.42+r91+g6224493e457-1)
warning: bison: local (3.8.2-8) is newer than core (3.8.2-6)
warning: blas: local (3.12.1-2) is newer than extra (3.12.0-5)
warning: bluez: local (5.79-1) is newer than extra (5.76-1)
warning: bluez-libs: local (5.79-1) is newer than extra (5.76-1)
warning: bluez-utils: local (5.79-1) is newer than extra (5.76-1)
warning: boost-libs: local (1.86.0-6) is newer than extra (1.83.0-9)
warning: breeze-icons: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: brotli: local (1.1.0-3) is newer than core (1.1.0-2)
warning: bspwm: local (0.9.10-4) is newer than extra (0.9.10-3)
warning: btop: local (1.4.0-4) is newer than extra (1.3.2-1)
warning: btrfs-progs: local (6.12-2) is newer than core (6.9.2-1)
warning: bubblewrap: local (0.11.0-1) is newer than extra (0.9.0-1)
warning: bullet-dp: local (3.25-6) is newer than extra (3.25-5)
warning: c-ares: local (1.34.4-1) is newer than extra (1.29.0-1)
warning: ca-certificates-mozilla: local (3.107-1) is newer than core (3.101.1-1)
warning: cabextract: local (1.11-2) is newer than extra (1.11-1)
warning: cairo: local (1.18.2-2) is newer than extra (1.18.0-2)
warning: cantarell-fonts: local (1:0.303.1-2) is newer than extra (1:0.303.1-1)
warning: cataclysm-dda: local (0.H-2) is newer than extra (0.G-2)
warning: cataclysm-dda-tiles: local (0.H-2) is newer than extra (0.G-2)
warning: cblas: local (3.12.1-2) is newer than extra (3.12.0-5)
warning: checkbashisms: local (2.24.5-1) is newer than extra (2.23.7-1)
warning: chromaprint: local (1.5.1-9) is newer than extra (1.5.1-8)
warning: cifs-utils: local (7.1-1) is newer than extra (7.0-4)
warning: cmake: local (3.31.4-1) is newer than extra (3.29.6-1)
warning: cmus: local (2.12.0-1) is newer than extra (2.11.0-1)
warning: code: local (1.96.4-1) is newer than extra (1.90.0-1)
warning: coreutils: local (9.5-2) is newer than core (9.5-1)
warning: cryptsetup: local (2.7.5-2) is newer than core (2.7.3-1)
warning: cups: local (2:2.4.11-2) is newer than extra (2:2.4.10-1)
warning: cups-filters: local (2.0.1-2) is newer than extra (2.0.0-2)
warning: curl: local (8.11.1-3) is newer than core (8.8.0-1)
warning: dav1d: local (1.5.0-1) is newer than extra (1.4.3-1)
warning: dbus: local (1.16.0-1) is newer than core (1.14.10-2)
warning: dbus-broker: local (36-4) is newer than core (36-2)
warning: dbus-broker-units: local (36-4) is newer than core (36-2)
warning: dbus-glib: local (0.112-4) is newer than extra (0.112-3)
warning: dconf: local (0.40.0-3) is newer than extra (0.40.0-2)
warning: debugedit: local (5.1-1) is newer than core (5.0-6)
warning: default-cursors: local (3-1) is newer than extra (2-1)
warning: desktop-file-utils: local (0.28-1) is newer than extra (0.27-1)
warning: device-mapper: local (2.03.29-1) is newer than core (2.03.24-1)
warning: dex: local (0.9.0-2) is newer than extra (0.9.0-1)
warning: dhclient: local (4.4.3.P1-4) is newer than extra (4.4.3.P1-3)
warning: dialog: local (1:1.3_20240619-2) is newer than core (1:1.3_20240307-2)
warning: discord: local (0.0.80-1) is newer than extra (0.0.58-1)
warning: dmidecode: local (3.6-1) is newer than extra (3.5-1)
warning: dmraid: local (1.0.0.rc16.3-15) is newer than core (1.0.0.rc16.3-14)
warning: dnsmasq: local (2.90-2) is newer than extra (2.90-1)
warning: dnssec-anchors: local (20190629-4) is newer than core (20190629-3)
warning: dosfstools: local (4.2-5) is newer than core (4.2-3)
warning: dotnet-host: local (8.0.11.sdk111-1) is newer than extra (8.0.6.sdk106-1)
warning: duf: local (0.8.1-3) is newer than extra (0.8.1-2)
warning: duktape: local (2.7.0-7) is newer than extra (2.7.0-6)
warning: dunst: local (1.12.1-1) is newer than extra (1.11.0-1)
warning: dvisvgm: local (3.4.3-1) is newer than extra (3.3-1)
warning: dwarffortress: local (50.15-1) is newer than extra (50.13-1)
warning: e2fsprogs: local (1.47.2-1) is newer than core (1.47.1-4)
warning: easyeffects: local (7.2.3-2) is newer than extra (7.1.7-1)
warning: ell: local (0.71-1) is newer than extra (0.66-1)
warning: enchant: local (2.8.2-1) is newer than extra (2.8.0-1)
warning: exfatprogs: local (1.2.6-1) is newer than extra (1.2.4-1)
warning: exiv2: local (0.28.3-1) is newer than extra (0.28.2-4)
warning: exo: local (4.20.0-2) is newer than extra (4.18.0-1)
warning: expac: local (10-11) is newer than extra (10-10)
warning: expat: local (2.6.4-1) is newer than core (2.6.2-1)
warning: f2fs-tools: local (1.16.0-3) is newer than extra (1.16.0-2)
warning: faac: local (1.30-5) is newer than extra (1.30-4)
warning: fakeroot: local (1.36.2-1) is newer than core (1.35-1)
warning: fd: local (10.2.0-1) is newer than extra (10.1.0-1)
warning: ffcall: local (2.4-3) is newer than extra (2.4-2)
warning: ffmpeg: local (2:7.1-6) is newer than extra (2:7.0.1-1)
warning: ffmpeg4.4: local (4.4.5-2) is newer than extra (4.4.4-6)
warning: ffmpegthumbnailer: local (2.2.3-3) is newer than extra (2.2.2-6)
warning: file: local (5.46-3) is newer than core (5.45-1)
warning: file-roller: local (44.4-1) is newer than extra (44.3-1)
warning: filesystem: local (2024.11.21-1) is newer than core (2024.04.07-1)
warning: findutils: local (4.10.0-2) is newer than core (4.10.0-1)
warning: firefox: local (134.0.1-1) is newer than extra (127.0.2-1)
warning: firewalld: local (2.3.0-2) is newer than extra (2.1.2-3)
warning: flac: local (1.4.3-2) is newer than extra (1.4.3-1)
warning: flameshot: local (12.1.0-5) is newer than extra (12.1.0-3)
warning: fluidsynth: local (2.4.2-1) is newer than extra (2.3.5-1)
warning: fmt: local (11.1.2-1) is newer than extra (10.2.0-1)
warning: freetype2: local (2.13.3-1) is newer than extra (2.13.2-2)
warning: fribidi: local (1.0.16-1) is newer than extra (1.0.15-1)
warning: fsarchiver: local (0.8.8-1) is newer than extra (0.8.7-1)
warning: fuse2: local (2.9.9-5) is newer than extra (2.9.9-4)
warning: fzf: local (0.57.0-1) is newer than extra (0.53.0-1)
warning: gamemode: local (1.8.2-1) is newer than extra (1.8.1-2)
warning: gawk: local (5.3.1-1) is newer than core (5.3.0-1)
warning: gc: local (8.2.8-2) is newer than core (8.2.6-1)
warning: gcc: local (14.2.1+r134+gab884fffe3fc-2) is newer than core (14.1.1+r58+gfc9fb69ad62-1)
warning: gcc-libs: local (14.2.1+r134+gab884fffe3fc-2) is newer than core (14.1.1+r58+gfc9fb69ad62-1)
warning: gd: local (2.3.3-8) is newer than extra (2.3.3-7)
warning: gdbm: local (1.24-1) is newer than core (1.23-2)
warning: gdk-pixbuf2: local (2.42.12-2) is newer than extra (2.42.12-1)
warning: gegl: local (0.4.52-1) is newer than extra (0.4.48-4)
warning: geoclue: local (2.7.2-1) is newer than extra (2.7.1-3)
warning: geoip: local (1.6.12-3) is newer than extra (1.6.12-2)
warning: geoip-database: local (20241116-1) is newer than extra (20240406-1)
warning: gettext: local (0.23.1-2) is newer than core (0.22.5-1)
warning: ghostscript: local (10.04.0-1) is newer than extra (10.03.1-1)
warning: gimp: local (2.10.38-5) is newer than extra (2.10.38-1)
warning: git: local (2.48.1-1) is newer than extra (2.45.2-1)
warning: glances: local (4.3.0.8-2) is newer than extra (4.1.1-1)
warning: glew: local (2.2.0-7) is newer than extra (2.2.0-6)
warning: glew1.10: local (1.10.0-4) is newer than extra (1.10.0-3)
warning: glib-networking: local (1:2.80.1-1) is newer than extra (1:2.80.0-1)
warning: glib2: local (2.82.4-2) is newer than core (2.80.3-2)
warning: glibc: local (2.40+r16+gaa533d58ff-2) is newer than core (2.39+r52+gf8e4623421-1)
warning: glibmm-2.68: local (2.82.0-1) is newer than extra (2.80.0-1)
warning: glslang: local (15.1.0-1) is newer than extra (14.2.0-1)
warning: glu: local (9.0.3-2) is newer than extra (9.0.3-1)
warning: gnome-autoar: local (0.4.5-1) is newer than extra (0.4.4-1)
warning: gnome-desktop: local (1:44.1-1) is newer than extra (1:44.0-1)
warning: gnome-desktop-4: local (1:44.1-1) is newer than extra (1:44.0-1)
warning: gnome-desktop-common: local (1:44.1-1) is newer than extra (1:44.0-1)
warning: gnome-keyring: local (1:46.2-1) is newer than extra (1:46.1-2)
warning: gnome-themes-extra: local (3.28+r6+g45b1d457-2) is newer than extra (3.28+r6+g45b1d457-1)
warning: gnupg: local (2.4.7-1) is newer than core (2.4.5-1)
warning: gnutls: local (3.8.8-1) is newer than core (3.8.5-1)
warning: gobject-introspection-runtime: local (1.82.0-2) is newer than extra (1.80.1-3)
warning: gparted: local (1.6.0-2) is newer than extra (1.6.0-1)
warning: gperftools: local (2.16-1) is newer than extra (2.15-1)
warning: gpgme: local (1.24.1-3) is newer than core (1.23.2-4)
warning: gpick: local (0.3-2) is newer than extra (0.3-1)
warning: gpm: local (1.20.7.r38.ge82d1a6-6) is newer than core (1.20.7.r38.ge82d1a6-5)
warning: graphene: local (1.10.8-2) is newer than extra (1.10.8-1)
warning: graphite: local (1:1.3.14-4) is newer than extra (1:1.3.14-3)
warning: groff: local (1.23.0-7) is newer than core (1.23.0-6)
warning: grub: local (2:2.12-3) is newer than core (2:2.12-2)
warning: gsettings-desktop-schemas: local (47.1-1) is newer than extra (46.0-2)
warning: gsm: local (1.0.22-2) is newer than extra (1.0.22-1)
warning: gspell: local (1.14.0-1) is newer than extra (1.12.2-3)
warning: gssdp: local (1.6.3-2) is newer than extra (1.6.3-1)
warning: gst-libav: local (1.24.11-2) is newer than extra (1.24.5-2)
warning: gst-plugin-pipewire: local (1:1.2.7-1) is newer than extra (1:1.2.0-2)
warning: gst-plugins-bad: local (1.24.11-2) is newer than extra (1.24.5-2)
warning: gst-plugins-bad-libs: local (1.24.11-2) is newer than extra (1.24.5-2)
warning: gst-plugins-base-libs: local (1.24.11-2) is newer than extra (1.24.5-2)
warning: gst-plugins-ugly: local (1.24.11-2) is newer than extra (1.24.5-2)
warning: gstreamer: local (1.24.11-2) is newer than extra (1.24.5-2)
warning: gtest: local (1.15.2-1) is newer than extra (1.14.0-1)
warning: gtk-layer-shell: local (0.9.0-1) is newer than extra (0.8.2-1)
warning: gtk-update-icon-cache: local (1:4.16.12-1) is newer than extra (1:4.14.4-1)
warning: gtk2: local (2.24.33-5) is newer than extra (2.24.33-4)
warning: gtk3: local (1:3.24.43-4) is newer than extra (1:3.24.42-1)
warning: gtk4: local (1:4.16.12-1) is newer than extra (1:4.14.4-1)
warning: gtkmm: local (1:2.24.5-5) is newer than extra (1:2.24.5-4)
warning: gtkmm-4.0: local (4.16.0-1) is newer than extra (4.14.0-1)
warning: gtksourceview3: local (1:3.24.11+r28+g73e57b57-2) is newer than extra (1:3.24.11+r28+g73e57b57-1)
warning: gupnp: local (1:1.6.7-1) is newer than extra (1:1.6.6-1)
warning: gvfs: local (1.56.1-1) is newer than extra (1.54.2-1)
warning: gvfs-afc: local (1.56.1-1) is newer than extra (1.54.2-1)
warning: gvfs-gphoto2: local (1.56.1-1) is newer than extra (1.54.2-1)
warning: gvfs-mtp: local (1.56.1-1) is newer than extra (1.54.2-1)
warning: gvfs-nfs: local (1.56.1-1) is newer than extra (1.54.2-1)
warning: gvfs-smb: local (1.56.1-1) is newer than extra (1.54.2-1)
warning: gzip: local (1.13-4) is newer than core (1.13-2)
warning: harfbuzz: local (10.2.0-1) is newer than extra (9.0.0-1)
warning: harfbuzz-icu: local (10.2.0-1) is newer than extra (9.0.0-1)
warning: haveged: local (1.9.19-1) is newer than extra (1.9.18-2)
warning: hdparm: local (9.65-2) is newer than core (9.65-1)
warning: hidapi: local (0.14.0-3) is newer than extra (0.14.0-2)
warning: hunspell: local (1.7.2-2) is newer than extra (1.7.2-1)
warning: hwdata: local (0.391-1) is newer than core (0.383-1)
warning: hwdetect: local (2024.07.29.0933-1) is newer than extra (2024.04.14.2206-1)
warning: hwinfo: local (23.3-1) is newer than extra (23.2-1)
warning: hwloc: local (2.11.2-1) is newer than extra (2.10.0-1)
warning: hyphen: local (2.8.8-6) is newer than extra (2.8.8-5)
warning: iana-etc: local (20241206-1) is newer than core (20240412-1)
warning: icu: local (75.1-2) is newer than core (75.1-1)
warning: id3lib: local (3.8.3-19) is newer than extra (3.8.3-18)
warning: imagemagick: local (7.1.1.43-1) is newer than extra (7.1.1.34-1)
warning: imath: local (3.1.12-2) is newer than extra (3.1.11-2)
warning: imlib2: local (1.12.3-2) is newer than extra (1.12.2-2)
warning: imv: local (4.5.0-4) is newer than extra (4.5.0-2)
warning: inxi: local (3.3.37.1-1) is newer than extra (3.3.35.1-1)
warning: iproute2: local (6.12.0-1) is newer than core (6.9.0-1)
warning: iptables-nft: local (1:1.8.10-2) is newer than core (1:1.8.10-1)
warning: iputils: local (20240905-1) is newer than core (20240117-1)
warning: iso-codes: local (4.17.0-1) is newer than extra (4.16.0-1)
warning: iwd: local (3.3-1) is newer than extra (2.18-1)
warning: jasper: local (4.2.4-2) is newer than extra (4.2.4-1)
warning: jemalloc: local (1:5.3.0-5) is newer than extra (1:5.3.0-4)
warning: json-c: local (0.18-1) is newer than core (0.17-1)
warning: json-glib: local (1.10.6-1) is newer than extra (1.8.0-2)
warning: jsoncpp: local (1.9.6-3) is newer than extra (1.9.5-2)
warning: karchive: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kauth: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kbd: local (2.7.1-1) is newer than core (2.6.4-1)
warning: kbookmarks: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kcodecs: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kcolorscheme: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kcompletion: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kconfig: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kconfigwidgets: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kcoreaddons: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kcrash: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kdbusaddons: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: keyutils: local (1.6.3-3) is newer than core (1.6.3-2)
warning: kfilemetadata: local (6.10.0-1) is newer than extra (6.3.0-2)
warning: kglobalaccel: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kguiaddons: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: ki18n: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kiconthemes: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kid3: local (3.9.6-2) is newer than extra (3.9.5-4)
warning: kid3-common: local (3.9.6-2) is newer than extra (3.9.5-4)
warning: kio: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kitemviews: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kjobwidgets: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kmod: local (33-3) is newer than core (32-1)
warning: knotifications: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kparts: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kpty: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: krb5: local (1.21.3-1) is newer than core (1.21.2-2)
warning: krita: local (5.2.6-7) is newer than extra (5.2.3-1)
warning: kservice: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kwallet: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kwidgetsaddons: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kwindowsystem: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: kxmlgui: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: l-smash: local (2.14.5-4) is newer than extra (2.14.5-3)
warning: ladspa: local (1.17-5) is newer than extra (1.17-4)
warning: lame: local (3.100-5) is newer than extra (3.100-4)
warning: lapack: local (3.12.1-2) is newer than extra (3.12.0-5)
warning: ldb: local (2:4.21.3-1) is newer than extra (2:2.9.1-1)
warning: lensfun: local (1:0.3.4-5) is newer than extra (1:0.3.4-4)
warning: less: local (1:668-1) is newer than core (1:643-2)
warning: lib32-gcc-libs: local (14.2.1+r134+gab884fffe3fc-2) is newer than core (14.1.1+r58+gfc9fb69ad62-1)
warning: lib32-glibc: local (2.40+r16+gaa533d58ff-2) is newer than core (2.39+r52+gf8e4623421-1)
warning: libabw: local (0.1.3-4) is newer than extra (0.1.3-3)
warning: libadwaita: local (1:1.6.3-1) is newer than extra (1:1.5.2-1)
warning: libappindicator-gtk3: local (12.10.0.r298-4) is newer than extra (12.10.0.r298-3)
warning: libarchive: local (3.7.7-1) is newer than core (3.7.4-1)
warning: libass: local (0.17.3-1) is newer than extra (0.17.2-1)
warning: libassuan: local (3.0.0-1) is newer than core (2.5.7-2)
warning: libasyncns: local (1:0.8+r3+g68cd5af-3) is newer than extra (1:0.8+r3+g68cd5af-2)
warning: libavif: local (1.1.1-2) is newer than extra (1.0.4-4)
warning: libavtp: local (0.2.0-3) is newer than extra (0.2.0-2)
warning: libb2: local (0.98.1-3) is newer than extra (0.98.1-2)
warning: libblockdev: local (3.2.1-3) is newer than extra (3.1.1-2)
warning: libblockdev-crypto: local (3.2.1-3) is newer than extra (3.1.1-2)
warning: libblockdev-fs: local (3.2.1-3) is newer than extra (3.1.1-2)
warning: libblockdev-loop: local (3.2.1-3) is newer than extra (3.1.1-2)
warning: libblockdev-mdraid: local (3.2.1-3) is newer than extra (3.1.1-2)
warning: libblockdev-nvme: local (3.2.1-3) is newer than extra (3.1.1-2)
warning: libblockdev-part: local (3.2.1-3) is newer than extra (3.1.1-2)
warning: libblockdev-swap: local (3.2.1-3) is newer than extra (3.1.1-2)
warning: libbluray: local (1.3.4-2) is newer than extra (1.3.4-1)
warning: libbpf: local (1.5.0-1) is newer than core (1.4.2-1)
warning: libbs2b: local (3.1.0-9) is newer than extra (3.1.0-8)
warning: libbytesize: local (2.11-1) is newer than extra (2.8-3)
warning: libcaca: local (0.99.beta20-5) is newer than extra (0.99.beta20-4)
warning: libcanberra: local (1:0.30+r2+gc0620e4-4) is newer than extra (1:0.30+r2+gc0620e4-3)
warning: libcap: local (2.71-1) is newer than core (2.70-1)
warning: libcap-ng: local (0.8.5-3) is newer than core (0.8.5-2)
warning: libcdio: local (2.2.0-1) is newer than extra (2.1.0-3)
warning: libcdr: local (0.1.8-1) is newer than extra (0.1.7-8)
warning: libcmis: local (0.6.2-2) is newer than extra (0.6.2-1)
warning: libcups: local (2:2.4.11-2) is newer than extra (2:2.4.10-1)
warning: libcupsfilters: local (2.1.0-3) is newer than extra (2.0.0-2)
warning: libcurl-compat: local (8.11.1-3) is newer than core (8.8.0-1)
warning: libcurl-gnutls: local (8.11.1-3) is newer than core (8.8.0-1)
warning: libdaemon: local (0.14-6) is newer than extra (0.14-5)
warning: libde265: local (1.0.15-3) is newer than extra (1.0.15-2)
warning: libdeflate: local (1.23-1) is newer than extra (1.20-2)
warning: libdiscid: local (0.6.4-3) is newer than extra (0.6.4-2)
warning: libdovi: local (3.3.1-1) is newer than extra (3.3.0-2)
warning: libdrm: local (2.4.124-1) is newer than extra (2.4.122-1)
warning: libdvdcss: local (1.4.3-2) is newer than extra (1.4.3-1)
warning: libebur128: local (1.2.6-2) is newer than extra (1.2.6-1)
warning: libedit: local (20240808_3.1-1) is newer than core (20240517_3.1-1)
warning: libelf: local (0.192-2) is newer than core (0.191-3)
warning: libepoxy: local (1.5.10-3) is newer than extra (1.5.10-2)
warning: libepubgen: local (0.1.1-5) is newer than extra (0.1.1-4)
warning: libetonyek: local (0.1.12-1) is newer than extra (0.1.10-3)
warning: libevdev: local (1.13.3-1) is newer than extra (1.13.2-1)
warning: libexif: local (0.6.25-1) is newer than extra (0.6.24-2)
warning: libfabric: local (2.0.0-1) is newer than extra (1.21.0-1)
warning: libfbclient: local (5.0.1.1469-1) is newer than extra (4.0.4.3010-1)
warning: libfreeaptx: local (0.1.1-2) is newer than extra (0.1.1-1)
warning: libfreehand: local (0.1.2-5) is newer than extra (0.1.2-4)
warning: libgee: local (0.20.8-1) is newer than extra (0.20.6-1)
warning: libgexiv2: local (0.14.3-2) is newer than extra (0.14.2-2)
warning: libgirepository: local (1.82.0-2) is newer than extra (1.80.1-3)
warning: libgme: local (0.6.3-5) is newer than extra (0.6.3-4)
warning: libgpg-error: local (1.51-1) is newer than core (1.50-1)
warning: libgphoto2: local (2.5.31-3) is newer than extra (2.5.31-1)
warning: libgsf: local (1.14.53-1) is newer than extra (1.14.52-1)
warning: libgxps: local (0.3.2-5) is newer than extra (0.3.2-4)
warning: libheif: local (1.19.5-1) is newer than extra (1.17.6-6)
warning: libibus: local (1.5.31-2) is newer than extra (1.5.30-1)
warning: libice: local (1.1.2-1) is newer than extra (1.1.1-2)
warning: libiec61883: local (1.2.0-8) is newer than extra (1.2.0-7)
warning: libimagequant: local (4.3.3-1) is newer than extra (4.3.1-1)
warning: libimobiledevice: local (1.3.0-15) is newer than extra (1.3.0-13)
warning: libimobiledevice-glue: local (1.3.1-1) is newer than extra (1.3.0-1)
warning: libinput: local (1.27.1-1) is newer than extra (1.26.1-1)
warning: libinstpatch: local (1.1.6-3) is newer than extra (1.1.6-2)
warning: libiptcdata: local (1.0.5-4) is newer than extra (1.0.5-3)
warning: libisl: local (0.27-1) is newer than core (0.26-2)
warning: libixion: local (0.19.0-6) is newer than extra (0.19.0-2)
warning: libjpeg-turbo: local (3.1.0-1) is newer than extra (3.0.3-1)
warning: libjxl: local (0.11.1-1) is newer than extra (0.10.3-1)
warning: libkdcraw5: local (24.12.1-1) is newer than extra (24.05.1-1)
warning: libldac: local (2.0.2.3-2) is newer than extra (2.0.2.3-1)
warning: libldap: local (2.6.9-1) is newer than core (2.6.8-1)
warning: liblqr: local (0.4.3-1) is newer than extra (0.4.2-3)
warning: liblrdf: local (0.6.1-5) is newer than extra (0.6.1-4)
warning: liblsp-r3d-glx-lib: local (1.2.20-1) is newer than extra (1.2.16-1)
warning: libltc: local (1.3.2-2) is newer than extra (1.3.2-1)
warning: libmanette: local (0.2.9-2) is newer than extra (0.2.7-1)
warning: libmaxminddb: local (1.12.2-1) is newer than extra (1.10.0-1)
warning: libmd: local (1.1.0-2) is newer than extra (1.1.0-1)
warning: libmicrodns: local (0.2.0-2) is newer than extra (0.2.0-1)
warning: libmikmod: local (3.3.12-1) is newer than extra (3.3.11.1-6)
warning: libmms: local (0.6.4-5) is newer than extra (0.6.4-4)
warning: libmng: local (2.0.3-4) is newer than extra (2.0.3-3)
warning: libmodplug: local (0.8.9.0-6) is newer than extra (0.8.9.0-5)
warning: libmp4v2: local (1:2.1.3-2) is newer than extra (1:2.1.3-1)
warning: libmpc: local (1.3.1-2) is newer than core (1.3.1-1)
warning: libmpcdec: local (1:0.1+r475-6) is newer than extra (1:0.1+r475-5)
warning: libmtp: local (1.1.22-1) is newer than extra (1.1.21-1)
warning: libmwaw: local (0.3.22-3) is newer than extra (0.3.22-1)
warning: libmypaint: local (1.6.1-2) is newer than extra (1.6.1-1)
warning: libmysofa: local (1.3.3-1) is newer than extra (1.3.2-1)
warning: libnautilus-extension: local (47.1-2) is newer than extra (46.2-2)
warning: libndp: local (1.9-1) is newer than extra (1.8-2)
warning: libnewt: local (0.52.24-3) is newer than extra (0.52.24-2)
warning: libnftnl: local (1.2.8-1) is newer than core (1.2.6-1)
warning: libnghttp2: local (1.64.0-1) is newer than core (1.62.1-1)
warning: libnghttp3: local (1.7.0-1) is newer than core (1.4.0-1)
warning: libngtcp2: local (1.10.0-1) is newer than extra (1.6.0-1)
warning: libnl: local (3.11.0-1) is newer than core (3.9.0-1)
warning: libnm: local (1.50.1-2) is newer than extra (1.48.2-1)
warning: libnma: local (1.10.6-3) is newer than extra (1.10.6-2)
warning: libnma-common: local (1.10.6-3) is newer than extra (1.10.6-2)
warning: libnumbertext: local (1.0.11-2) is newer than extra (1.0.11-1)
warning: libnvme: local (1.11.1-2) is newer than extra (1.9-1)
warning: libodfgen: local (0.1.8-3) is newer than extra (0.1.8-2)
warning: libopenmpt: local (0.7.13-1) is newer than extra (0.7.8-1)
warning: libopenraw: local (0.3.7-2) is newer than extra (0.3.7-1)
warning: liborcus: local (0.19.2-4) is newer than extra (0.19.2-2)
warning: libosinfo: local (1.12.0-1) is newer than extra (1.11.0-2)
warning: libp11-kit: local (0.25.5-1) is newer than core (0.25.3-1)
warning: libpagemaker: local (0.0.4-4) is newer than extra (0.0.4-3)
warning: libpcap: local (1.10.5-2) is newer than core (1.10.4-1)
warning: libpeas: local (1.36.0-6) is newer than extra (1.36.0-5)
warning: libpipeline: local (1.5.8-1) is newer than core (1.5.7-2)
warning: libpipewire: local (1:1.2.7-1) is newer than extra (1:1.2.0-2)
warning: libplacebo: local (7.349.0-4) is newer than extra (6.338.2-7)
warning: libplist: local (2.6.0-2) is newer than extra (2.6.0-1)
warning: libpng: local (1.6.45-1) is newer than extra (1.6.43-1)
warning: libportal: local (0.9.0-1) is newer than extra (0.7.1-2)
warning: libportal-gtk3: local (0.9.0-1) is newer than extra (0.7.1-2)
warning: libportal-gtk4: local (0.9.0-1) is newer than extra (0.7.1-2)
warning: libppd: local (2.1.0-1) is newer than extra (2.0.0-1)
warning: libproxy: local (0.5.9-1) is newer than extra (0.5.7-1)
warning: libpulse: local (17.0+r43+g3e2bb8a1e-1) is newer than extra (17.0-3)
warning: libqmi: local (1.34.0-2) is newer than extra (1.34.0-1)
warning: libqrtr-glib: local (1.2.2-3) is newer than extra (1.2.2-2)
warning: libraqm: local (0.10.2-1) is newer than extra (0.10.1-1)
warning: libraw: local (0.21.3-1) is newer than extra (0.21.2-1)
warning: libreoffice-still: local (24.2.7-5) is newer than extra (7.6.7-1)
warning: librevenge: local (0.0.5-3) is newer than extra (0.0.5-2)
warning: librsvg: local (2:2.59.2-1) is newer than extra (2:2.58.1-1)
warning: librtmp0: local (2.4-6) is newer than extra (2.4-5)
warning: libsamplerate: local (0.2.2-3) is newer than extra (0.2.2-2)
warning: libsasl: local (2.1.28-5) is newer than core (2.1.28-4)
warning: libseccomp: local (2.5.5-4) is newer than core (2.5.5-3)
warning: libshout: local (1:2.4.6-3) is newer than extra (1:2.4.6-2)
warning: libsidplayfp: local (2.12.0-1) is newer than extra (2.8.0-1)
warning: libsigsegv: local (2.14-3) is newer than extra (2.14-2)
warning: libsixel: local (1.10.3-7) is newer than extra (1.10.3-5)
warning: libsm: local (1.2.5-1) is newer than extra (1.2.4-1)
warning: libsoup3: local (3.6.4-1) is newer than extra (3.4.4-1)
warning: libsoxr: local (0.1.3-4) is newer than extra (0.1.3-3)
warning: libspiro: local (1:20240903-1) is newer than extra (1:20221101-2)
warning: libssh: local (0.11.1-1) is newer than extra (0.10.6-2)
warning: libssh2: local (1.11.1-1) is newer than core (1.11.0-1)
warning: libstaroffice: local (0.0.7-3) is newer than extra (0.0.7-2)
warning: libsynctex: local (2024.2-5) is newer than extra (2024.2-2)
warning: libsysprof-capture: local (47.2-1) is newer than extra (46.0-3)
warning: libtasn1: local (4.19.0-2) is newer than core (4.19.0-1)
warning: libteam: local (1.32-2) is newer than extra (1.32-1)
warning: libtiff: local (4.7.0-1) is newer than extra (4.6.0-5)
warning: libtiff4: local (3.9.7-6) is newer than extra (3.9.7-5)
warning: libtirpc: local (1.3.6-1) is newer than core (1.3.4-1)
warning: libtool: local (2.5.4+r1+gbaa1fe41-1) is newer than core (2.5.0+14+g9a4a0261-1)
warning: libtorrent-rasterbar: local (1:2.0.10-4) is newer than extra (1:2.0.10-2)
warning: libudev0-shim: local (2-1) is newer than extra (1-4)
warning: libunistring: local (1.3-1) is newer than core (1.2-1)
warning: libupnp: local (1.14.20-2) is newer than extra (1.14.19-2)
warning: liburcu: local (0.15.0-1) is newer than extra (0.14.0-1)
warning: liburing: local (2.8-1) is newer than extra (2.6-2)
warning: libuv: local (1.50.0-1) is newer than extra (1.48.0-2)
warning: libva: local (2.22.0-1) is newer than extra (2.21.0-1)
warning: libvdpau: local (1.5-3) is newer than extra (1.5-2)
warning: libvisio: local (0.1.8-1) is newer than extra (0.1.7-11)
warning: libvpl: local (2.14.0-1) is newer than extra (2.12.0-1)
warning: libvpx: local (1.15.0-1) is newer than extra (1.14.0-1)
warning: libwacom: local (2.14.0-1) is newer than extra (2.12.2-1)
warning: libwbclient: local (2:4.21.3-1) is newer than extra (4.20.2-1)
warning: libwebp: local (1.5.0-1) is newer than extra (1.4.0-1)
warning: libwireplumber: local (0.5.7-1) is newer than extra (0.5.5-1)
warning: libwmf: local (0.2.13-4) is newer than extra (0.2.13-1)
warning: libwnck3: local (43.2-1) is newer than extra (43.0-3)
warning: libwpd: local (0.10.3-5) is newer than extra (0.10.3-4)
warning: libwpg: local (0.3.4-2) is newer than extra (0.3.4-1)
warning: libwps: local (0.4.14-2) is newer than extra (0.4.14-1)
warning: libx11: local (1.8.10-1) is newer than extra (1.8.9-1)
warning: libx86emu: local (3.5-4) is newer than extra (3.5-3)
warning: libxau: local (1.0.12-1) is newer than extra (1.0.11-2)
warning: libxcomposite: local (0.4.6-2) is newer than extra (0.4.6-1)
warning: libxcrypt: local (4.4.37-1) is newer than core (4.4.36-1)
warning: libxcrypt-compat: local (4.4.37-1) is newer than core (4.4.36-1)
warning: libxcursor: local (1.2.3-1) is newer than extra (1.2.2-1)
warning: libxcvt: local (0.1.3-1) is newer than extra (0.1.2-1)
warning: libxdamage: local (1.1.6-2) is newer than extra (1.1.6-1)
warning: libxfce4ui: local (4.20.0-3) is newer than extra (4.18.6-1)
warning: libxfce4util: local (4.20.0-2) is newer than extra (4.18.2-1)
warning: libxfixes: local (6.0.1-2) is newer than extra (6.0.1-1)
warning: libxfont2: local (2.0.7-1) is newer than extra (2.0.6-2)
warning: libxft: local (2.3.8-2) is newer than extra (2.3.8-1)
warning: libxi: local (1.8.2-1) is newer than extra (1.8.1-1)
warning: libxinerama: local (1.1.5-2) is newer than extra (1.1.5-1)
warning: libxml2: local (2.13.5-2) is newer than core (2.13.1-1)
warning: libxmlb: local (0.3.21-1) is newer than extra (0.3.19-1)
warning: libxnvctrl: local (565.57.01-1) is newer than extra (555.58-1)
warning: libxpm: local (3.5.17-2) is newer than extra (3.5.17-1)
warning: libxpresent: local (1.0.1-2) is newer than extra (1.0.1-1)
warning: libxrender: local (0.9.12-1) is newer than extra (0.9.11-1)
warning: libxres: local (1.2.2-2) is newer than extra (1.2.2-1)
warning: libxshmfence: local (1.3.3-1) is newer than extra (1.3.2-1)
warning: libxslt: local (1.1.42-2) is newer than extra (1.1.41-1)
warning: libxss: local (1.2.4-2) is newer than extra (1.2.4-1)
warning: libxt: local (1.3.1-1) is newer than extra (1.3.0-1)
warning: libxtst: local (1.2.5-1) is newer than extra (1.2.4-1)
warning: libxv: local (1.0.13-1) is newer than extra (1.0.12-1)
warning: libxxf86vm: local (1.1.6-1) is newer than extra (1.1.5-1)
warning: libyaml: local (0.2.5-3) is newer than extra (0.2.5-2)
warning: libyuv: local (r2426+464c51a03-1) is newer than extra (r2426+464c51a0-1)
warning: libzip: local (1.11.2-1) is newer than extra (1.10.1-1)
warning: licenses: local (20240728-1) is newer than core (20240206-1)
warning: lightdm-slick-greeter: local (2.0.9-1) is newer than extra (2.0.5-1)
warning: lilv: local (0.24.24-3) is newer than extra (0.24.24-2)
warning: linux: local (6.12.9.arch1-1) is newer than core (6.9.7.arch1-1)
warning: linux-api-headers: local (6.10-1) is newer than core (6.8-1)
warning: linux-firmware: local (20250109.7673dffd-1) is newer than core (20240610.9c10a208-1)
warning: linux-firmware-whence: local (20250109.7673dffd-1) is newer than core (20240610.9c10a208-1)
warning: linux-headers: local (6.12.9.arch1-1) is newer than core (6.9.7.arch1-1)
warning: linux-zen: local (6.12.9.zen1-1) is newer than extra (6.9.7.zen1-1)
warning: linux-zen-headers: local (6.12.9.zen1-1) is newer than extra (6.9.7.zen1-1)
warning: llvm: local (19.1.7-1) is newer than extra (17.0.6-5)
warning: llvm-libs: local (19.1.7-1) is newer than extra (17.0.6-5)
warning: lm_sensors: local (1:3.6.0.r41.g31d1f125-3) is newer than extra (1:3.6.0.r41.g31d1f125-2)
warning: lmdb: local (0.9.33-1) is newer than extra (0.9.32-1)
warning: logrotate: local (3.22.0-1) is newer than core (3.21.0-2)
warning: lpsolve: local (5.5.2.11-3) is newer than extra (5.5.2.11-2)
warning: lsb-release: local (2.0.r55.a25a4fc-1) is newer than extra (2.0.r53.a86f885-1)
warning: lsof: local (4.99.4-1) is newer than extra (4.99.3-2)
warning: lsp-plugins-lv2: local (1.2.20-1) is newer than extra (1.2.16-1)
warning: lsscsi: local (0.32-2) is newer than extra (0.32-1)
warning: luajit: local (2.1.1731601260-1) is newer than extra (2.1.1716656478-1)
warning: luit: local (20240910-1) is newer than extra (20240102-1)
warning: lutris: local (0.5.18-2) is newer than extra (0.5.17-5)
warning: lvm2: local (2.03.29-1) is newer than core (2.03.24-1)
warning: lxappearance-gtk3: local (0.6.3-5) is newer than extra (0.6.3-4)
warning: lz4: local (1:1.10.0-2) is newer than core (1:1.9.4-3)
warning: mailcap: local (2.1.54-2) is newer than extra (2.1.54-1)
warning: man-db: local (2.13.0-1) is newer than core (2.12.1-1)
warning: mangohud: local (0.7.2-2) is newer than extra (0.7.2-1)
warning: mariadb-libs: local (11.6.2-2) is newer than extra (11.4.2-1)
warning: mdadm: local (4.4-1) is newer than core (4.3-2)
warning: media-player-info: local (26-1) is newer than extra (24-2)
warning: meld: local (3.22.3-1) is newer than extra (3.22.2-3)
warning: mesa: local (1:24.3.3-2) is newer than extra (1:24.1.2-1)
warning: mesa-utils: local (9.0.0-5) is newer than extra (9.0.0-4)
warning: minizip-ng: local (4.0.8-1) is newer than extra (4.0.7-1)
warning: mkinitcpio: local (39.2-3) is newer than core (39.2-2)
warning: mlt: local (7.28.0-5) is newer than extra (7.24.0-3)
warning: mpd: local (0.23.16-3) is newer than extra (0.23.15-5)
warning: mpfr: local (4.2.1-4) is newer than core (4.2.1-3)
warning: mpg123: local (1.32.10-1) is newer than extra (1.32.6-1)
warning: mpv: local (1:0.39.0-4) is newer than extra (1:0.38.0-5)
warning: mtdev: local (1.1.7-1) is newer than extra (1.1.6-2)
warning: mtools: local (1:4.0.46-1) is newer than extra (1:4.0.44-1)
warning: mygui: local (3.4.2-2) is newer than extra (3.4.2-1)
warning: mypaint-brushes1: local (1.3.1-2) is newer than extra (1.3.1-1)
warning: nano: local (8.3-1) is newer than core (8.0-1)
warning: nano-syntax-highlighting: local (2022.11.02.r102.gbb94603-1) is newer than extra (2020.10.10-1)
warning: nautilus: local (47.1-2) is newer than extra (46.2-2)
warning: nbd: local (3.26.1-2) is newer than extra (3.26.1-1)
warning: ncmpcpp: local (0.10.1-1) is newer than extra (0.9.2-19)
warning: neon: local (0.34.0-1) is newer than extra (0.33.0-1)
warning: net-tools: local (2.10-3) is newer than core (2.10-2)
warning: netctl: local (1.29-2) is newer than extra (1.29-1)
warning: nettle: local (3.10.1-1) is newer than core (3.10-1)
warning: networkmanager: local (1.50.1-2) is newer than extra (1.48.2-1)
warning: newsboat: local (2.38-1) is newer than extra (2.36-1)
warning: nfs-utils: local (2.8.2-2) is newer than core (2.6.4-1)
warning: nfsidmap: local (2.8.2-2) is newer than core (2.6.4-1)
warning: nftables: local (1:1.1.1-2) is newer than extra (1:1.0.9-3)
warning: nicotine+: local (3.3.7-2) is newer than extra (3.3.4-1)
warning: ninja: local (1.12.1-2) is newer than extra (1.12.1-1)
warning: node-gyp: local (11.0.0-1) is newer than extra (10.1.0-3)
warning: nodejs: local (23.4.0-1) is newer than extra (22.3.0-1)
warning: nodejs-nopt: local (7.2.1-1) is newer than extra (7.2.0-1)
warning: noto-fonts: local (1:2025.01.01-1) is newer than extra (1:24.7.1-1)
warning: noto-fonts-emoji: local (1:2.047-1) is newer than extra (1:2.042-1)
warning: npm: local (11.0.0-1) is newer than extra (10.8.1-1)
warning: npth: local (1.8-1) is newer than core (1.7-1)
warning: nspr: local (4.36-1) is newer than core (4.35-3)
warning: nss: local (3.107-1) is newer than core (3.101.1-1)
warning: nss-mdns: local (0.15.1-2) is newer than extra (0.15.1-1)
warning: ntp: local (4.2.8.p18-2) is newer than extra (4.2.8.p18-1)
warning: numactl: local (2.0.19-1) is newer than extra (2.0.18-1)
warning: oath-toolkit: local (2.6.12-1) is newer than extra (2.6.11-2)
warning: obsidian: local (1.7.7-1) is newer than extra (1.6.5-1)
warning: ocl-icd: local (2.3.2-2) is newer than extra (2.3.2-1)
warning: onetbb: local (2022.0.0-2) is newer than extra (2021.13.0-1)
warning: oniguruma: local (6.9.10-1) is newer than extra (6.9.9-1)
warning: openal: local (1.24.2-1) is newer than extra (1.23.1-2)
warning: opencolorio: local (2.4.0-6) is newer than extra (2.3.2-3)
warning: openconnect: local (1:9.12-3) is newer than extra (1:9.12-1)
warning: opencore-amr: local (0.1.6-2) is newer than extra (0.1.6-1)
warning: openexr: local (3.3.2-1) is newer than extra (3.2.4-1)
warning: openh264: local (2.5.0-1) is newer than extra (2.4.1-1)
warning: openjpeg2: local (2.5.3-1) is newer than extra (2.5.2-1)
warning: openmpi: local (5.0.6-2) is newer than extra (5.0.3-1)
warning: openmw: local (0.48.0-9) is newer than extra (0.48.0-8)
warning: openpmix: local (5.0.6-1) is newer than extra (5.0.2-1)
warning: openscenegraph: local (3.6.5-26) is newer than extra (3.6.5-24)
warning: openssh: local (9.9p1-2) is newer than core (9.8p1-1)
warning: openssl: local (3.4.0-1) is newer than core (3.3.1-1)
warning: openssl-1.1: local (1.1.1.w-2) is newer than core (1.1.1.w-1)
warning: openucx: local (1.17.0-3) is newer than extra (1.17.0-1)
warning: openvpn: local (2.6.13-1) is newer than extra (2.6.11-1)
warning: opusfile: local (0.12-4) is newer than extra (0.12-3)
warning: orc: local (0.4.40-1) is newer than extra (0.4.38-1)
warning: os-prober: local (1.81-2) is newer than extra (1.81-1)
warning: osinfo-db: local (20240701-1) is newer than extra (20240523-1)
warning: p11-kit: local (0.25.5-1) is newer than core (0.25.3-1)
warning: pacman-contrib: local (1.10.6-2) is newer than extra (1.10.6-1)
warning: pacutils: local (0.14.0-3) is newer than extra (0.14.0-1)
warning: pahole: local (1:1.28-3) is newer than extra (1:1.27-1)
warning: pam: local (1.7.0-1) is newer than core (1.6.1-2)
warning: pambase: local (20230918-2) is newer than core (20230918-1)
warning: pangomm-2.48: local (2.54.0-1) is newer than extra (2.52.0-1)
warning: parallel: local (20241222-1) is newer than extra (20240622-1)
warning: parted: local (3.6-2) is newer than extra (3.6-1)
warning: pavucontrol: local (1:6.1-1) is newer than extra (1:6.0-1)
warning: pciutils: local (3.13.0-2) is newer than core (3.13.0-1)
warning: pcsclite: local (2.3.1-1) is newer than extra (2.2.3-1)
warning: perl: local (5.40.0-1) is newer than core (5.38.2-1)
warning: perl-clone: local (0.47-1) is newer than extra (0.46-2)
warning: perl-encode-locale: local (1.05-13) is newer than extra (1.05-11)
warning: perl-error: local (0.17029-7) is newer than extra (0.17029-5)
warning: perl-file-listing: local (6.16-4) is newer than extra (6.16-2)
warning: perl-html-parser: local (3.83-1) is newer than extra (3.82-1)
warning: perl-html-tagset: local (3.24-2) is newer than extra (3.24-1)
warning: perl-http-cookiejar: local (0.014-3) is newer than extra (0.014-1)
warning: perl-http-cookies: local (6.11-2) is newer than extra (6.11-1)
warning: perl-http-daemon: local (6.16-4) is newer than extra (6.16-2)
warning: perl-http-date: local (6.06-3) is newer than extra (6.06-1)
warning: perl-http-message: local (7.00-1) is newer than extra (6.46-1)
warning: perl-http-negotiate: local (6.01-14) is newer than extra (6.01-12)
warning: perl-io-html: local (1.004-6) is newer than extra (1.004-4)
warning: perl-libwww: local (6.77-2) is newer than extra (6.77-1)
warning: perl-lwp-mediatypes: local (6.04-6) is newer than extra (6.04-4)
warning: perl-mailtools: local (2.22-1) is newer than extra (2.21-7)
warning: perl-net-http: local (6.23-4) is newer than extra (6.23-2)
warning: perl-timedate: local (2.33-7) is newer than extra (2.33-5)
warning: perl-try-tiny: local (0.32-2) is newer than extra (0.31-3)
warning: perl-uri: local (5.31-1) is newer than extra (5.28-1)
warning: perl-www-robotrules: local (6.02-14) is newer than extra (6.02-12)
warning: perl-xml-parser: local (2.47-2) is newer than extra (2.47-1)
warning: perl-xml-writer: local (0.900-4) is newer than extra (0.900-2)
warning: picom: local (12.5-1) is newer than extra (11.2-1)
warning: pinentry: local (1.3.1-5) is newer than core (1.3.0-1)
warning: pipewire: local (1:1.2.7-1) is newer than extra (1:1.2.0-2)
warning: pipewire-alsa: local (1:1.2.7-1) is newer than extra (1:1.2.0-2)
warning: pipewire-audio: local (1:1.2.7-1) is newer than extra (1:1.2.0-2)
warning: pipewire-jack: local (1:1.2.7-1) is newer than extra (1:1.2.0-2)
warning: pipewire-pulse: local (1:1.2.7-1) is newer than extra (1:1.2.0-2)
warning: pixman: local (0.44.2-1) is newer than extra (0.43.4-1)
warning: pkgconf: local (2.3.0-1) is newer than core (2.1.1-1)
warning: pkgfile: local (22-1) is newer than extra (21-2)
warning: plocate: local (1.1.23-1) is newer than extra (1.1.22-1)
warning: polkit: local (126-2) is newer than extra (124-2)
warning: polkit-gnome: local (0.105-11) is newer than extra (0.105-10)
warning: polybar: local (3.7.2-2) is newer than extra (3.7.1-1)
warning: poppler: local (25.01.0-1) is newer than extra (24.06.1-1)
warning: poppler-data: local (0.4.12-2) is newer than extra (0.4.12-1)
warning: poppler-glib: local (25.01.0-1) is newer than extra (24.06.1-1)
warning: poppler-qt6: local (25.01.0-1) is newer than extra (24.06.1-1)
warning: popt: local (1.19-2) is newer than core (1.19-1)
warning: portaudio: local (1:19.7.0-3) is newer than extra (1:19.7.0-2)
warning: portmidi: local (1:2.0.4-2) is newer than extra (1:2.0.4-1)
warning: portsmf: local (234-3) is newer than extra (234-2)
warning: postgresql-libs: local (17.2-1) is newer than extra (16.3-1)
warning: power-profiles-daemon: local (0.23-2) is newer than extra (0.21-1)
warning: ppp: local (2.5.2-1) is newer than core (2.5.0-3)
warning: procps-ng: local (4.0.5-1) is newer than core (4.0.4-3)
warning: prrte: local (3.0.8-1) is newer than extra (3.0.5-3)
warning: pv: local (1.9.27-1) is newer than extra (1.8.10-1)
warning: pystring: local (1.1.4-2) is newer than extra (1.1.4-1)
warning: python: local (3.13.1-1) is newer than core (3.12.4-1)
warning: python-annotated-types: local (0.7.0-2) is newer than extra (0.7.0-1)
warning: python-attrs: local (23.2.0-4) is newer than extra (23.2.0-3)
warning: python-beautifulsoup4: local (4.12.3-3) is newer than extra (4.12.3-2)
warning: python-cairo: local (1.27.0-2) is newer than extra (1.26.1-1)
warning: python-capng: local (0.8.5-3) is newer than core (0.8.5-2)
warning: python-certifi: local (2024.12.14-1) is newer than extra (2024.06.02-1)
warning: python-cffi: local (1.17.1-2) is newer than extra (1.16.0-2)
warning: python-chardet: local (5.2.0-6) is newer than extra (5.2.0-2)
warning: python-charset-normalizer: local (3.4.1-1) is newer than extra (3.3.2-2)
warning: python-colorama: local (0.4.6-5) is newer than extra (0.4.6-3)
warning: python-contourpy: local (1.3.1-2) is newer than extra (1.2.1-5)
warning: python-cryptography: local (44.0.0-1) is newer than extra (42.0.6-1)
warning: python-cycler: local (0.12.1-3) is newer than extra (0.12.1-2)
warning: python-dateutil: local (2.9.0-6) is newer than extra (2.9.0-5)
warning: python-dbus: local (1.3.2-5) is newer than extra (1.3.2-4)
warning: python-defusedxml: local (0.7.1-7) is newer than extra (0.7.1-6)
warning: python-distro: local (1.9.0-3) is newer than extra (1.9.0-2)
warning: python-evdev: local (1.7.1-2) is newer than extra (1.7.0-3)
warning: python-filelock: local (3.16.1-2) is newer than extra (3.13.3-2)
warning: python-fonttools: local (4.55.3-2) is newer than extra (4.53.0-1)
warning: python-gobject: local (3.50.0-2) is newer than extra (3.48.2-1)
warning: python-idna: local (3.10-2) is newer than extra (3.7-1)
warning: python-inflect: local (7.5.0-1) is newer than extra (7.2.1-2)
warning: python-kiwisolver: local (1.4.5-5) is newer than extra (1.4.5-3)
warning: python-lxml: local (5.3.0-2) is newer than extra (5.2.2-1)
warning: python-matplotlib: local (3.10.0-1) is newer than extra (3.8.4-2)
warning: python-moddb: local (0.12.0-1) is newer than extra (0.11.0-1)
warning: python-more-itertools: local (10.5.0-1) is newer than extra (10.2.0-2)
warning: python-numpy: local (2.2.1-2) is newer than extra (2.0.0-1)
warning: python-orjson: local (3.10.15-1) is newer than extra (3.10.5-1)
warning: python-packaging: local (24.2-3) is newer than extra (24.0-1)
warning: python-pillow: local (11.0.0-3) is newer than extra (10.4.0-1)
warning: python-pip: local (24.3.1-3) is newer than extra (24.0-2)
warning: python-psutil: local (6.1.1-1) is newer than extra (5.9.8-4)
warning: python-pyaml: local (24.9.0-2) is newer than extra (23.12.0-2)
warning: python-pycparser: local (2.22-3) is newer than extra (2.22-2)
warning: python-pydantic: local (2.10.4-1) is newer than extra (2.7.4-1)
warning: python-pydantic-core: local (1:2.27.2-1) is newer than extra (1:2.18.4-1)
warning: python-pyparsing: local (3.1.2-3) is newer than extra (3.1.2-2)
warning: python-pyqt5: local (5.15.11-2) is newer than extra (5.15.10-2)
warning: python-pyqt5-sip: local (12.16.1-2) is newer than extra (12.13.0-2)
warning: python-requests: local (2.32.3-4) is newer than extra (2.32.3-1)
warning: python-shtab: local (1.7.1-3) is newer than extra (1.7.1-1)
warning: python-six: local (1.17.0-1) is newer than extra (1.16.0-9)
warning: python-soupsieve: local (2.6-2) is newer than extra (2.5-3)
warning: python-termcolor: local (2.5.0-1) is newer than extra (2.4.0-2)
warning: python-typeguard: local (4.4.1-1) is newer than extra (4.3.0-1)
warning: python-typing_extensions: local (4.12.2-3) is newer than extra (4.12.2-1)
warning: python-urllib3: local (2.3.0-1) is newer than extra (1.26.18-3)
warning: python-wheel: local (0.45.0-3) is newer than extra (0.43.0-4)
warning: python-yaml: local (6.0.2-2) is newer than extra (6.0.1-4)
warning: qbittorrent: local (5.0.3-1) is newer than extra (4.6.5-1)
warning: qca-qt6: local (2.3.9-3) is newer than extra (2.3.9-1)
warning: qhull: local (2020.2-5) is newer than extra (2020.2-4)
warning: qrencode: local (4.1.1-3) is newer than extra (4.1.1-2)
warning: qt5-base: local (5.15.16+kde+r130-3) is newer than extra (5.15.14+kde+r141-1)
warning: qt5-declarative: local (5.15.16+kde+r22-3) is newer than extra (5.15.14+kde+r28-1)
warning: qt5-svg: local (5.15.16+kde+r5-3) is newer than extra (5.15.14+kde+r5-1)
warning: qt5-tools: local (5.15.16+kde+r3-4) is newer than extra (5.15.14+kde+r4-1)
warning: qt5-translations: local (5.15.16-3) is newer than extra (5.15.14-1)
warning: qt5-wayland: local (5.15.16+kde+r59-3) is newer than extra (5.15.14+kde+r58-1)
warning: qt5-x11extras: local (5.15.16-3) is newer than extra (5.15.14-1)
warning: qt6-5compat: local (6.8.1-1) is newer than extra (6.7.2-1)
warning: qt6-base: local (6.8.1-1) is newer than extra (6.7.2-1)
warning: qt6-declarative: local (6.8.1-3) is newer than extra (6.7.2-1)
warning: qt6-multimedia: local (6.8.1-2) is newer than extra (6.7.2-1)
warning: qt6-multimedia-ffmpeg: local (6.8.1-2) is newer than extra (6.7.2-1)
warning: qt6-networkauth: local (6.8.1-1) is newer than extra (6.7.2-1)
warning: qt6-positioning: local (6.8.1-1) is newer than extra (6.7.2-1)
warning: qt6-shadertools: local (6.8.1-1) is newer than extra (6.7.2-1)
warning: qt6-svg: local (6.8.1-1) is newer than extra (6.7.2-1)
warning: qt6-tools: local (6.8.1-2) is newer than extra (6.7.2-1)
warning: qt6-translations: local (6.8.1-1) is newer than extra (6.7.2-1)
warning: qt6-wayland: local (6.8.1-1) is newer than extra (6.7.2-1)
warning: qt6-webchannel: local (6.8.1-1) is newer than extra (6.7.2-1)
warning: qt6-webengine: local (6.8.1-2) is newer than extra (6.7.2-1)
warning: radeontop: local (1.4-3) is newer than extra (1.4-2)
warning: re2: local (1:20240702-2) is newer than extra (1:20240601-1)
warning: readline: local (8.2.013-1) is newer than core (8.2.010-1)
warning: rebuild-detector: local (4.4.5-1) is newer than extra (4.4.3-3)
warning: reflector: local (2023-3) is newer than extra (2023-2)
warning: reiserfsprogs: local (3.6.27-5) is newer than core (3.6.27-4)
warning: ripgrep: local (14.1.1-1) is newer than extra (14.1.0-1)
warning: rofi: local (1.7.7-1) is newer than extra (1.7.5-3)
warning: rp-pppoe: local (4.0-4) is newer than extra (4.0-1)
warning: rpcbind: local (1.2.7-2) is newer than core (1.2.6-4)
warning: rsync: local (3.4.1-1) is newer than extra (3.3.0-2)
warning: rtkit: local (0.13-3) is newer than extra (0.13-2)
warning: rubberband: local (4.0.0-1) is newer than extra (3.3.0-1)
warning: samba: local (2:4.21.3-1) is newer than extra (4.20.2-1)
warning: sbc: local (2.0-2) is newer than extra (2.0-1)
warning: screen: local (5.0.0-2) is newer than extra (4.9.1-2)
warning: sdl12-compat: local (1.2.68-2) is newer than extra (1.2.68-1)
warning: sdl2: local (2.30.11-1) is newer than extra (2.30.4-1)
warning: sdl2_image: local (2.8.4-1) is newer than extra (2.8.2-4)
warning: sdl2_ttf: local (2.24.0-1) is newer than extra (2.22.0-1)
warning: sdl_image: local (1.2.12-9) is newer than extra (1.2.12-8)
warning: sdl_ttf: local (2.0.11-7) is newer than extra (2.0.11-6)
warning: semver: local (7.6.3-1) is newer than extra (7.6.2-1)
warning: sg3_utils: local (1.48-1) is newer than extra (1.47-1)
warning: shaderc: local (2024.4-1) is newer than extra (2024.1-1)
warning: shadow: local (4.16.0-1) is newer than core (4.15.1-2)
warning: signal-desktop: local (7.38.0-1) is newer than extra (7.14.0-1)
warning: slang: local (2.3.3-3) is newer than extra (2.3.3-2)
warning: smartmontools: local (7.4-2) is newer than extra (7.4-1)
warning: smbclient: local (2:4.21.3-1) is newer than extra (4.20.2-1)
warning: snappy: local (1.2.1-2) is newer than extra (1.1.10-1)
warning: sof-firmware: local (2024.09.2-1) is newer than extra (2024.03-1)
warning: solid: local (6.10.0-1) is newer than extra (6.3.0-1)
warning: sound-theme-freedesktop: local (0.8-6) is newer than extra (0.8-5)
warning: speex: local (1.2.1-2) is newer than extra (1.2.1-1)
warning: speexdsp: local (1.2.1-2) is newer than extra (1.2.1-1)
warning: spirv-tools: local (2024.4.rc2-1) is newer than extra (2024.2-1)
warning: sqlite: local (3.47.2-1) is newer than core (3.46.0-1)
warning: srt: local (1.5.4-1) is newer than extra (1.5.3-1)
warning: sshfs: local (3.7.3-2) is newer than extra (3.7.3-1)
warning: stfl: local (0.24-6) is newer than extra (0.24-5)
warning: sudo: local (1.9.16.p2-2) is newer than core (1.9.15.p5-1)
warning: suitesparse: local (7.8.3-1) is newer than extra (7.7.0-1)
warning: svt-av1: local (2.3.0-1) is newer than extra (2.1.0-1)
warning: sxhkd: local (0.6.2-4) is newer than extra (0.6.2-3)
warning: sysstat: local (12.7.6-1) is newer than extra (12.7.5-1)
warning: systemd: local (257.2-2) is newer than core (256.1-1)
warning: systemd-libs: local (257.2-2) is newer than core (256.1-1)
warning: systemd-sysvcompat: local (257.2-2) is newer than core (256.1-1)
warning: taglib: local (2.0.2-1) is newer than extra (2.0.1-1)
warning: talloc: local (2.4.2-4) is newer than extra (2.4.2-3)
warning: tcl: local (8.6.16-1) is newer than extra (8.6.14-4)
warning: tdb: local (1.4.12-2) is newer than extra (1.4.10-3)
warning: tevent: local (1:0.16.1-4) is newer than extra (1:0.16.1-3)
warning: texinfo: local (7.1.1-1) is newer than core (7.1-2)
warning: texlive-basic: local (2024.2-4) is newer than extra (2024.2-2)
warning: texlive-bin: local (2024.2-5) is newer than extra (2024.2-2)
warning: texlive-fontsrecommended: local (2024.2-4) is newer than extra (2024.2-2)
warning: texlive-formatsextra: local (2024.2-4) is newer than extra (2024.2-2)
warning: texlive-latex: local (2024.2-4) is newer than extra (2024.2-2)
warning: texlive-latexextra: local (2024.2-4) is newer than extra (2024.2-2)
warning: texlive-latexrecommended: local (2024.2-4) is newer than extra (2024.2-2)
warning: texlive-pictures: local (2024.2-4) is newer than extra (2024.2-2)
warning: texlive-plaingeneric: local (2024.2-4) is newer than extra (2024.2-2)
warning: thin-provisioning-tools: local (1.1.0-1) is newer than core (1.0.12-1)
warning: thunar: local (4.20.1-1) is newer than extra (4.18.10-2)
warning: thunar-archive-plugin: local (0.5.3-1) is newer than extra (0.5.2-1)
warning: thunar-media-tags-plugin: local (0.5.0-1) is newer than extra (0.4.0-2)
warning: thunar-volman: local (4.20.0-2) is newer than extra (4.18.0-1)
warning: tk: local (8.6.16-1) is newer than extra (8.6.14-4)
warning: tldr: local (3.3.0-2) is newer than extra (3.2.0-3)
warning: tpm2-tss: local (4.1.3-1) is newer than core (4.0.1-1)
warning: ttf-bitstream-vera: local (1.10-16) is newer than extra (1.10-15)
warning: ttf-liberation: local (2.1.5-2) is newer than extra (2.1.5-1)
warning: ttf-nerd-fonts-symbols: local (3.3.0-1) is newer than extra (3.2.1-1)
warning: ttf-nerd-fonts-symbols-common: local (3.3.0-1) is newer than extra (3.2.1-1)
warning: ttf-nerd-fonts-symbols-mono: local (3.3.0-1) is newer than extra (3.2.1-1)
warning: ttf-opensans: local (1.101-5) is newer than extra (1.101-2)
warning: tumbler: local (4.20.0-2) is newer than extra (4.18.2-1)
warning: tzdata: local (2024b-2) is newer than core (2024a-2)
warning: uchardet: local (0.0.8-3) is newer than extra (0.0.8-2)
warning: udisks2: local (2.10.1-5) is newer than extra (2.10.1-4)
warning: unixodbc: local (2.3.12-3) is newer than core (2.3.12-1)
warning: unrar: local (1:7.1.3-1) is newer than extra (1:7.0.9-1)
warning: unshield: local (1.5.1-3) is newer than extra (1.5.1-2)
warning: upower: local (1.90.7-1) is newer than extra (1.90.4-1)
warning: usb_modeswitch: local (2.6.1-4) is newer than extra (2.6.1-3)
warning: usbmuxd: local (1.1.1-4) is newer than extra (1.1.1-3)
warning: usbutils: local (018-1) is newer than core (017-1)
warning: util-linux: local (2.40.4-1) is newer than core (2.40.1-1)
warning: util-linux-libs: local (2.40.4-1) is newer than core (2.40.1-1)
warning: v4l-utils: local (1.28.1-2) is newer than extra (1.26.1-1)
warning: vamp-plugin-sdk: local (2.10.0-3) is newer than extra (2.10.0-2)
warning: vapoursynth: local (R70-2) is newer than extra (R68-1)
warning: vid.stab: local (1.1.1-2) is newer than extra (1.1.1-1)
warning: vim: local (9.1.1006-1) is newer than extra (9.1.0496-1)
warning: vim-runtime: local (9.1.1006-1) is newer than extra (9.1.0496-1)
warning: vivaldi: local (7.0.3495.29-1) is newer than extra (6.8.3381.46-1)
warning: volume_key: local (0.3.12-10) is newer than extra (0.3.12-9)
warning: vorbis-tools: local (1.4.2-5) is newer than extra (1.4.2-3)
warning: vte-common: local (0.78.2-1) is newer than extra (0.76.3-1)
warning: vte3: local (0.78.2-1) is newer than extra (0.76.3-1)
warning: vulkan-headers: local (1:1.4.303-1) is newer than extra (1:1.3.285-1)
warning: vulkan-icd-loader: local (1.4.303-1) is newer than extra (1.3.285-1)
warning: vulkan-radeon: local (1:24.3.3-2) is newer than extra (1:24.1.2-1)
warning: wayland: local (1.23.1-1) is newer than extra (1.23.0-1)
warning: webkit2gtk-4.1: local (2.46.5-1) is newer than extra (2.44.2-1)
warning: webrtc-audio-processing-1: local (1.3-3) is newer than extra (1.3-2)
warning: wget: local (1.25.0-1) is newer than extra (1.24.5-3)
warning: wine-mono: local (9.3.0-1) is newer than extra (9.2.0-1)
warning: wireless-regdb: local (2024.10.07-1) is newer than core (2024.05.08-1)
warning: wireplumber: local (0.5.7-1) is newer than extra (0.5.5-1)
warning: wpa_supplicant: local (2:2.11-2) is newer than core (2:2.10-8)
warning: wxwidgets-common: local (3.2.6-1) is newer than extra (3.2.5-1)
warning: wxwidgets-gtk3: local (3.2.6-1) is newer than extra (3.2.5-1)
warning: x265: local (4.0-1) is newer than extra (3.6-1)
warning: xapp: local (2.8.8-1) is newer than extra (2.8.4-1)
warning: xbindkeys: local (1.8.7-5) is newer than extra (1.8.7-4)
warning: xbitmaps: local (1.1.3-2) is newer than extra (1.1.3-1)
warning: xcb-proto: local (1.17.0-3) is newer than extra (1.17.0-2)
warning: xcb-util: local (0.4.1-2) is newer than extra (0.4.1-1)
warning: xcb-util-image: local (0.4.1-3) is newer than extra (0.4.1-2)
warning: xcb-util-keysyms: local (0.4.1-5) is newer than extra (0.4.1-4)
warning: xcb-util-renderutil: local (0.3.10-2) is newer than extra (0.3.10-1)
warning: xcb-util-wm: local (0.4.2-2) is newer than extra (0.4.2-1)
warning: xcb-util-xrm: local (1.3-3) is newer than extra (1.3-2)
warning: xclip: local (0.13-6) is newer than extra (0.13-5)
warning: xdg-dbus-proxy: local (0.1.6-1) is newer than extra (0.1.5-1)
warning: xdg-desktop-portal: local (1.18.4-2) is newer than extra (1.18.4-1)
warning: xdg-desktop-portal-gnome: local (47.1-2) is newer than extra (46.2-1)
warning: xdg-desktop-portal-gtk: local (1.15.2-1) is newer than extra (1.15.1-2)
warning: xdg-user-dirs: local (0.18-2) is newer than extra (0.18-1)
warning: xdg-user-dirs-gtk: local (0.12-1) is newer than extra (0.11-2)
warning: xdotool: local (3.20211022.1-2) is newer than extra (3.20211022.1-1)
warning: xed: local (3.8.2-1) is newer than extra (3.6.3-1)
warning: xf86-input-libinput: local (1.5.0-1) is newer than extra (1.4.0-1)
warning: xfce4-terminal: local (1.1.4-1) is newer than extra (1.1.3-1)
warning: xfconf: local (4.20.0-2) is newer than extra (4.18.3-1)
warning: xfsprogs: local (6.12.0-1) is newer than core (6.8.0-2)
warning: xkeyboard-config: local (2.43-1) is newer than extra (2.42-1)
warning: xl2tpd: local (1.3.18-2) is newer than extra (1.3.18-1)
warning: xmlsec: local (1.3.6-1) is newer than extra (1.3.4-1)
warning: xorg-server: local (21.1.15-1) is newer than extra (21.1.13-1)
warning: xorg-server-common: local (21.1.15-1) is newer than extra (21.1.13-1)
warning: xorg-setxkbmap: local (1.3.4-2) is newer than extra (1.3.4-1)
warning: xorg-xbacklight: local (1.2.4-1) is newer than extra (1.2.3-3)
warning: xorg-xdpyinfo: local (1.3.4-2) is newer than extra (1.3.4-1)
warning: xorg-xinit: local (1.4.3-1) is newer than extra (1.4.2-1)
warning: xorg-xinput: local (1.6.4-2) is newer than extra (1.6.4-1)
warning: xorg-xkill: local (1.0.6-2) is newer than extra (1.0.6-1)
warning: xorg-xmodmap: local (1.0.11-2) is newer than extra (1.0.11-1)
warning: xorg-xprop: local (1.2.8-1) is newer than extra (1.2.7-1)
warning: xorg-xrandr: local (1.5.3-1) is newer than extra (1.5.2-1)
warning: xorg-xrdb: local (1.2.2-2) is newer than extra (1.2.2-1)
warning: xorg-xset: local (1.2.5-2) is newer than extra (1.2.5-1)
warning: xorg-xsetroot: local (1.1.3-2) is newer than extra (1.1.3-1)
warning: xterm: local (397-2) is newer than extra (392-1)
warning: xvidcore: local (1.3.7-3) is newer than extra (1.3.7-2)
warning: xxhash: local (0.8.3-1) is newer than extra (0.8.2-1)
warning: yaml-cpp: local (0.8.0-2) is newer than extra (0.8.0-1)
warning: zbar: local (0.23.93-4) is newer than extra (0.23.93-1)
warning: zenity: local (4.0.3-1) is newer than extra (4.0.1-1)
warning: zita-convolver: local (4.0.3-4) is newer than extra (4.0.3-3)
warning: zlib-ng: local (2.2.3-1) is newer than extra (2.1.7-1)
warning: zxing-cpp: local (2.3.0-4) is newer than extra (2.2.1-1)
warning: zziplib: local (0.13.78-1) is newer than extra (0.13.77-1)
 there is nothing to do
Additionally when I try to update with yay
yay
yay: error while loading shared libraries: libalpm.so.15: cannot open shared object file: No such file or directory
I have no idea what’s going on, but I’ve updated mirrors with eos-rankmirrors and run pacman -Syyu. Haven’t been able to find anything that answers my problem online either.
Thanks!
try it in this order:
reflector --protocol https --verbose --latest 25 --sort rate --save /etc/pacman.d/mirrorlist
yay -Syyu
eos-rankmirrors --verbose
yay -Syyu
I’ve never had that ‘package newer’ dealio so my advice might suck.
Alright, well that fixed everything somehow :smiley: Thank you very much!
Any ideas what could have been the cause? Seemed to come out of nowhere to me.
The list of Arch mirrors was not optimal, so the reflector command essentially fixed the list.
Apparently the list of EndeavourOS mirrors (the [endeavouros] repo in file /etc/pacman.conf) was already OK.
And looks like your previous update happened rather long time ago?
de nada
it’s a fixit command I use for those kind of errors. (kind credit goes to @fbodymechanic who chronicled this in ‘the idiots guide to maintenance’ [or similar], a popular forum thread.
I update my system regularly, mirrors not so often but a couple times a year maybe. I’ve been using EndeavourOS for 2-3 years and never had anything like this happen before, though admittedly I’m not very knowledgeable :smiley:
Ok, no problem. Mirrors are sometimes causing temporary problems. And sometimes mirrors can be removed permanently, but that happens rarely. Then the remedy is to modify the (particular) list of mirrors.
But you did the right thing and asked here for some guidance. :+1:
Hi there,
I’m facing the same thing as OP and when I’m doing this
I get
[2025-01-19 09:04:15] INFO: rating 25 mirror(s) by download speed
[2025-01-19 09:04:15] INFO: Server                                                           Rate       Time
[2025-01-19 09:04:21] WARNING: failed to rate http(s) download (https://archlinux.thaller.ws/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:04:21] INFO: https://archlinux.thaller.ws/                              0.00 KiB/s     0.00 s
[2025-01-19 09:04:28] WARNING: failed to rate http(s) download (https://mirror.theo546.fr/archlinux/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:04:28] INFO: https://mirror.theo546.fr/archlinux/                       0.00 KiB/s     0.00 s
[2025-01-19 09:04:34] WARNING: failed to rate http(s) download (https://london.mirror.pkgbuild.com/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:04:34] INFO: https://london.mirror.pkgbuild.com/                        0.00 KiB/s     0.00 s
[2025-01-19 09:04:40] WARNING: failed to rate http(s) download (https://mirror.lcarilla.de/archlinux/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:04:40] INFO: https://mirror.lcarilla.de/archlinux/                      0.00 KiB/s     0.00 s
[2025-01-19 09:04:47] WARNING: failed to rate http(s) download (https://mirror.ufscar.br/archlinux/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:04:47] INFO: https://mirror.ufscar.br/archlinux/                        0.00 KiB/s     0.00 s
[2025-01-19 09:04:53] WARNING: failed to rate http(s) download (https://mirror.cyberbits.eu/archlinux/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:04:53] INFO: https://mirror.cyberbits.eu/archlinux/                     0.00 KiB/s     0.00 s
[2025-01-19 09:05:00] WARNING: failed to rate http(s) download (https://mirror.moson.org/arch/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:05:00] INFO: https://mirror.moson.org/arch/                             0.00 KiB/s     0.00 s
[2025-01-19 09:05:06] WARNING: failed to rate http(s) download (https://md.mirrors.hacktegic.com/archlinux/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:05:06] INFO: https://md.mirrors.hacktegic.com/archlinux/                0.00 KiB/s     0.00 s
[2025-01-19 09:05:13] WARNING: failed to rate http(s) download (https://mirrors.neusoft.edu.cn/archlinux/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:05:13] INFO: https://mirrors.neusoft.edu.cn/archlinux/                  0.00 KiB/s     0.00 s
[2025-01-19 09:05:19] WARNING: failed to rate http(s) download (https://mirror.telepoint.bg/archlinux/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:05:19] INFO: https://mirror.telepoint.bg/archlinux/                     0.00 KiB/s     0.00 s
[2025-01-19 09:05:25] WARNING: failed to rate http(s) download (https://mirror.pseudoform.org/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:05:25] INFO: https://mirror.pseudoform.org/                             0.00 KiB/s     0.00 s
[2025-01-19 09:05:31] WARNING: failed to rate http(s) download (https://archlinux.uk.mirror.allworldit.com/archlinux/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:05:31] INFO: https://archlinux.uk.mirror.allworldit.com/archlinux/      0.00 KiB/s     0.00 s
[2025-01-19 09:05:36] WARNING: failed to rate http(s) download (https://archlinux.za.mirror.allworldit.com/archlinux/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:05:36] INFO: https://archlinux.za.mirror.allworldit.com/archlinux/      0.00 KiB/s     0.00 s
[2025-01-19 09:05:43] WARNING: failed to rate http(s) download (https://mirror.kumi.systems/archlinux/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:05:43] INFO: https://mirror.kumi.systems/archlinux/                     0.00 KiB/s     0.00 s
[2025-01-19 09:05:49] WARNING: failed to rate http(s) download (https://arch.phinau.de/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:05:49] INFO: https://arch.phinau.de/                                    0.00 KiB/s     0.00 s
[2025-01-19 09:05:55] WARNING: failed to rate http(s) download (https://at.arch.mirror.kescher.at/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:05:55] INFO: https://at.arch.mirror.kescher.at/                         0.00 KiB/s     0.00 s
[2025-01-19 09:06:02] WARNING: failed to rate http(s) download (https://de.arch.mirror.kescher.at/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:06:02] INFO: https://de.arch.mirror.kescher.at/                         0.00 KiB/s     0.00 s
[2025-01-19 09:06:08] WARNING: failed to rate http(s) download (https://america.mirror.pkgbuild.com/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:06:08] INFO: https://america.mirror.pkgbuild.com/                       0.00 KiB/s     0.00 s
[2025-01-19 09:06:15] WARNING: failed to rate http(s) download (https://asia.mirror.pkgbuild.com/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:06:15] INFO: https://asia.mirror.pkgbuild.com/                          0.00 KiB/s     0.00 s
[2025-01-19 09:06:21] WARNING: failed to rate http(s) download (https://europe.mirror.pkgbuild.com/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:06:21] INFO: https://europe.mirror.pkgbuild.com/                        0.00 KiB/s     0.00 s
[2025-01-19 09:06:27] WARNING: failed to rate http(s) download (https://geo.mirror.pkgbuild.com/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:06:27] INFO: https://geo.mirror.pkgbuild.com/                           0.00 KiB/s     0.00 s
[2025-01-19 09:06:34] WARNING: failed to rate http(s) download (https://sydney.mirror.pkgbuild.com/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:06:34] INFO: https://sydney.mirror.pkgbuild.com/                        0.00 KiB/s     0.00 s
[2025-01-19 09:06:40] WARNING: failed to rate http(s) download (https://repo.jing.rocks/archlinux/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:06:40] INFO: https://repo.jing.rocks/archlinux/                         0.00 KiB/s     0.00 s
[2025-01-19 09:06:48] WARNING: failed to rate http(s) download (https://in.arch.niranjan.co/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:06:48] INFO: https://in.arch.niranjan.co/                               0.00 KiB/s     0.00 s
[2025-01-19 09:06:54] WARNING: failed to rate http(s) download (https://arch.mirror.constant.com/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2025-01-19 09:06:54] INFO: https://arch.mirror.constant.com/                          0.00 KiB/s     0.00 s
I guess it is not what it is supposed to be ?
Can you help ?
[edit : It works somehow, thanks :slight_smile: ]
congrats then. the secret, I was told, was both in the sequence, and the double y’s (yy).
Anytime my output looks like yours after an attempted update, that’s my go-to. even if I have to do it twice.
It probably fixed your mirror issue on the Arch side. Eos rank mirrors only fixes the EOS side.
That looks like you had no internet connection at the time.
