Want to create btrfs top level 5 subvolume in an already installed system
Well as the title says. I want to create a top level 5 btrfs subvolume without having to use a live usb to do that. Is there any way to do it?
Edit: The btrfs partition is mounted at “/”
Sure.
sudo mkdir /mnt/btrfsroot
sudo mount /dev/mybtrfsdevice /mnt/btrfsroot -o subvolid=5
sudo btrfs subvolume create /mnt/btrfsroot/mysubvolname
Replace /dev/mybtrfsdevice with your actual device. i.e. /dev/sda2
Replace “mysubvolume” with whatever you want the toplevel subvolume to be named.
The problem is that the btrfs partition is mounted already at /
That doesn’t matter. It can be mounted more than once.
Thanks, I didn’t know that. Can other file systems be mounted more than once too like ext4 etc
Yes. Although, I haven’t tested every single one. :sweat_smile:
