This one’s really good. Can I request arm colored one similar to this?
No matter what, beware of a bloated system ![]()
looks fine on my EOS, didnt it?..thanks a lot. very nice work!
i love this one ! and indeed the saturn rings are awesome ![]()
We can add a 4k version if available to community wallpapers repo
Would including in community wallpapers repo require the artwork to be free of copy rights, etc.
I know we purchased the rights to use something, Was it Endy?
Pudge
I see. Good to have some comfort food then ![]()
yes you can of course … and in 4K
and the HD version
Very happy for you … EndevourOS has a very nice community
thanks for your encouragement ![]()
I think the forum software compresses the image to 1080p, let me double check.
Could you try hosting the higher resolution versions at github or somewhere else. There is also the added benefit of having everything in a single place.
I agree and its very supporting. That’s one of the main reasons I’m here
These look awesome, thank you for do this
hi sradjoker,
could you try to download this file … it is verified on Gimp as a 3840x2160 and 96p/inch png file … if this file is making problem we shall see together what to do …
Thanks :slight_smile ![]()
I have downloaded the file and everything is OK. The file is good ! … ![]()
the properties say that its 4k, can you do the same for the other Wallpaper too.
Thanks!!
No problem …
In fact there is a problem … when I upload a jpg file that doesn(t work I got a yellow rectangle as you can see… and when I make a png that makes a big file (17Mb) that is refused… dont know what to do ! ![]()
I dont understand why my jpg file turn to bright yellow or rose , the file is slim enough …
********* SOLUTION ***********
Here you can find the file … ![]()
https://imgbox.com/1FCbhAtP
A version with the shuttle !
