Hi there,
I’ve initially chose a wallpaper using the welcome script, but now I just want a solid_color as background, how can I get rid of the current wallpaper?
I’ve set the color #000000
cat ~/.config/sway/config.d/output | grep background
output HDMI-A-1 resolution 3840x2160 pos 0 1080 background #000000 solid_color
output DP-2 resolution 3840x2160 pos 3840 0 background #000000 solid_color
output DP-3 resolution 3840x2160 pos 3840 2160 background #000000 solid_color
I’ve also commented the line in theme
cat ~/.config/sway/config.d/theme | grep -A2 wallpaper
# Set wallpaper:
#exec swaybg -i ~/.config/sway/sway.png
Since that did not worked, I even renamed the file sway.png to something else and reloaded sway. This crashed waybar without removing the wallpaper !
help please
