Wallpaper for EOS by Smokey
Thanks, and no problem
gears-no-logo-1366x768
gears-no-logo-no-bottom-line1366x768
binary-logo-1366x768
binary-no-logo-1366x768
Planets-no-logo-1366x768
Planets-logo-1366x768
manymoons-nologo-1366x768
Where did you find the Endeavouros text without the logo? Did you just crop it in gimp or?
I just cropped the logo in GIMP
Okay thank you.
Your welcome
spacewalk-1366x768-logo-02
spacewalk-1366x768-nologo-02
@smokey just a suggestion our forum software compresses the images which drop the quality. So, if you can put the original files in a GitHub or GitLab repo which doesn’t mess with the image quality.
You can paste the link and the image as a preview. Our community can download a better quality image from your repo using the link you posted.
Thanks for the advise, I actually have them on github
Here is the link - https://github.com/smokey5787/Wallpaper-1366x768
Nice, put that link on your starting post if you can. Really nice work with the wallpapers. Just a small request if you can make additional resolution size images for 1920x1080.
Cool, I’ll rescale them and upload shortly
Quick question, how do I add the link to the starting post?
You can edit the post. Click the three dots near the “Reply” button.
You’ll see a pencil icon after it expands.
It’s not showing, I think the original post might be too old, I can see the option on these posts
The images are rescaled though and available here
I took the liberty of adding the links to the post. Hope it’s ok with you.
Cheers
IT is created with Ailerons font - so can be created, sized, and coloured as needed… (as you may have guessed I use conky for display of the result)
blackhole-merge-1920x1080-logo
Planets-logo-text1920-1080
One new wallpaper and a slight change to another
