Vulkan does not work on new Installation
My Problem is the following:
On a new Installation (Switching from Manjaro) Vulkan does not work (i.e. most Steam Games won’t start.
I installed vulkan-radeon and lib32-vulkan-radeon and vulkaninfo prints this
WARNING: [../mesa-24.3.2/src/amd/vulkan/radv_physical_device.c:2037] Code 0 : Device '/dev/dri/renderD128' is not using the AMDGPU kernel driver: Invalid argument (VK_ERROR_INCOMPATIBLE_DRIVER)
ERROR: [Loader Message] Code 0 : setup_loader_term_phys_devs:  Failed to detect any valid GPUs in the current config
ERROR at /usr/src/debug/vulkan-tools/Vulkan-Tools-1.4.303/vulkaninfo/./vulkaninfo.h:247:vkEnumeratePhysicalDevices failed with ERROR_INITIALIZATION_FAILED
Vulkan worked using Manjaro so my device is compatible
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Hawaii PRO [Radeon R9 290/390] (rev 80) (prog-if 00 [VGA controller])
        Subsystem: PC Partner Limited / Sapphire Technology Sapphire Nitro R9 390
        Flags: bus master, fast devsel, latency 0, IRQ 136
        Memory at c0000000 (64-bit, prefetchable) [size=256M]
        Memory at d0000000 (64-bit, prefetchable) [size=8M]
        I/O ports at e000 [size=256]
        Memory at dfe00000 (32-bit, non-prefetchable) [size=256K]
        Expansion ROM at 000c0000 [disabled] [size=128K]
        Capabilities: <access denied>
        Kernel driver in use: radeon
        Kernel modules: radeon, amdgpu
I am clueless. Could someone help me please?
Thanks in advance
Found some reports of adding following kernel parameters outlined on wiki solving this problem: https://wiki.archlinux.org/title/AMDGPU#R9_390_series_poor_performance_and/or_instability
DRM_AMDGPU_CIK kernel parameter is also noted on Gentoo wiki under Feature support
The kernel parameters did the trick.
Thank you so much. :slight_smile:
