Volume changer sound
Hi,
When one changes the volume using the mouse wheel when hovering over the speaker icon in the taskbar it plays this sound every jump. This sound is played when you use the mouse to drag the volume bar as well but is only played on release.
Anyway this sound is REALLY loud and the notification volume bar slider in the sound settings does nothing, neither does muting notification sounds. I believe this used to work previously but not anymore. How can I kill that annoying sound?
In the Sound settings top right click Configure Volume Controls and uncheck “Play audio feedback for changes to: Audio volume”.
Oh it was that easy, thank you!
