Sieder
November 11, 2025, 7:06pm
1
Hey all,
I am fairly new to Linux in general so please do not be too harsh with me.
I am experiencing a weird issue and could not get further on my own. There are some threads here and there with a similiar issue, but they did not provide anything that worked for me. I installed EOS on my Lenovo Yoga Pro 7 and since the beginning I cannot control the volume globally. I can of course control the volume within any app (if they provide a way) but in the actual volume control of the system I have either zero or maximum volume (considering the outcome, virtually I can control the volume in small steps, but it does not work; the slider shows to be at x% but the actual volume is constantly at maximum.
inxi -A gives this output:
Device-1: Intel Meteor Lake-P HD Audio driver: sof-audio-pci-intel-mtl
API: ALSA v: k6.17.7-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.4.9 status: active
Any ideas? Thank you!
EDIT: I forgot to mention: The Laptop had Windows preinstalled and the volume worked fine, so it should not be a hardware problem.
Sieder:
Welcome to the forum.
You never mentioned a DE which may be irrelevant. You are at the Master Volume of your DE’s system settings?
You slide it to something less ear-splitting and says ‘screw that’ and jumps back to 100% with its middle finger out in the system settings?
that’s trippy.
If you have WIN on half this disk that’s the first thing I’d blame. if you don’t great.
Spitballin:
Lenovo bundled software fubar?
two sound .services enabled in systemctl?
are there pipewire setting independent of system settings?
I coudn’t see anything fishy in the output. But a sound expert I am not.
Conversely in Cinnamon I’ve always left it alone and adjust thru the app:
the more I think about that’s the way I’ve always done it as far as what you call ‘globally;
–the difference being if you move it to 50% it moves itself back. A mystery. hang in there, someone will know
Sieder
November 12, 2025, 7:20am
3
Thank you!
As said in the title (it is a bit hidden) I use KDE Plasma. To clear things up:
The master volume of KDE Plasma was what I meant by “global volume”
No, it keeps the value in terms of what it displays, but it outputs max volume all the same.
I don’t, I bulldozed the disk before installing EOS.
Can they bundle stuff if I install a custom OS? You mean bundled with EOS? Never heard of such thing before.
Since the inxi -A Output only shows one I suppose there is not? Is there another way to check this?
I do not understand what that means.
Thank you for helping!
