VMware Workstation Pro now has no cost for personal use
VMWare announced that they are no longer charging for Workstation Pro for personal use.
How does it compare to KVM/QEMU these days?
Very Nice.
Workstation still far superior.
I use VMWare day in and day out. I also use KVM. But I like KVM over VMWare because I nearly noticed the difference between working on my host computer and my VM. But VMWare has an advantage over KVM if you want to play games without parsing a VGA. Or any application that requires VGA emulation. KVM virtio can’t do that.
It depends on your needs.
VMware:
  • Easier to configure
  • Performant out of the box with no tweaking
  • Snapshot functionality is simpler and more fully featured
  • It has an MDI-style interface which is useful if you have a lot of VMs you run at the same time
  • It can connect to VMware ESXi
QEMU/KVM:
  • Open source
  • With tweaking and proper config it can be highly performant
  • Available in the repos(VMware needs an AUR package)
IMO, if QEMU/KVM is working for you, no reason not to stick with it.
I also use vmware workstation pro. I have been using it for a long time not to say i know everything about it but, it’s very easy to install, set up and use. Works very well on both my amd and Intel host.
What is the AUR package you recommend installing the VMware WS Pro?
vmware-workstation
I removed Qemu/Virt and installed vmware-workstation
I will give it a spin with a trial iso when I have some time
