Visual glitches (ultra-wide monitor)
Hi,
Since starting my journey with EndeavourOS and transitioning from Windows, I’ve encountered a lot of visual glitches, like:
  • Flickering
  • Stutters/lags while typing text (visual only, like visual rollbacks if you prefer)
  • Artifacts
  • Completely black hamburger menus (for around 1 sec, until they appear normally)
Some of this glitches appears only on certain applications like (Flickering, rollbacks and hamburger menus) :
  • vscode & code OSS
  • Brave
  • Spotify
And not, or practically not, in others like Librewolf, terminal apps (like Neovim, etc…), Dolphin…
And the artifacts appears on the screen, usually on the taskbar or on the screen…
I’m currently using KDE Plasma 6, and the problem has persisted since Plasma 5. Despite several fresh installs, nothing has changed.
One key detail is that I’m using an Odyssey G9 screen (ultra-wide 32:9, equivalent to 2 screens wide, at 5120x1440@240Hz) that can split its screen into 2 different outputs if connected to 2 different sources (a feature I’m not using, but it might be relevant). Many of the non-application-specific glitches (such as artifacts) tend to occur on the right side of the screen (starting from the very center). I suspect that using an ultra-wide monitor may be contributing to these glitches (or not…).
I have 1 GPU (nVidia RTX) and an iGPU (on my intel),
and I used the ‘Latest nvidia card’ boot option when I reinstalled EOS yesterday
Here is my inxi -Fxxxz :
  Kernel: 6.8.4-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc
  Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A wm: kwin_wayland vt: 1 dm: SDDM
  Type: Desktop Mobo: Micro-Star model: PRO B660-A DDR4 (MS-7D59) v: 1.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 1.C0 date: 06/06/2023
  Info: 14-core (6-mt/8-st) model: 13th Gen Intel Core i5-13600K bits: 64
    type: MST AMCP smt: enabled arch: Raptor Lake rev: 1 cache: L1: 1.2 MiB
    L2: 20 MiB L3: 24 MiB
  Speed (MHz): avg: 830 high: 1100 min/max: 800/5100:3900 cores: 1: 800
    2: 800 3: 800 4: 800 5: 800 6: 800 7: 1100 8: 800 9: 800 10: 800 11: 1100
    12: 800 13: 800 14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800
    bogomips: 139820
  Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Micro-Star MSI
    driver: i915 v: kernel arch: Gen-13 ports: active: none empty: DP-4, DP-5,
    DP-6, HDMI-A-3, HDMI-A-4, HDMI-A-5, HDMI-A-6, HDMI-A-7 bus-ID: 00:02.0
    chip-ID: 8086:a780 class-ID: 0380
  Device-2: NVIDIA AD103 [GeForce RTX 4080] vendor: ASUSTeK driver: nvidia
    v: 550.67 arch: Lovelace pcie: speed: 16 GT/s lanes: 16 ports: active: none
    off: DP-2 empty: DP-1, DP-3, HDMI-A-1, HDMI-A-2 bus-ID: 01:00.0
    chip-ID: 10de:2704 class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
    alternate: fbdev,intel,nouveau,nv,vesa dri: iris gpu: i915,nvidia
    display-ID: 0
  Monitor-1: DP-2 res: 5120x1440 size: N/A modes: N/A
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia platforms: device: 0
    drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: zink
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4080/PCIe/SSE2
    display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: 1 surfaces: xcb,xlib,wayland device: 0
    type: discrete-gpu driver: nvidia device-ID: 10de:2704
  Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:7ad0
    class-ID: 0403
  Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bb class-ID: 0403
  Device-3: Logitech Logitech G PRO X Gaming Headset
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 bus-ID: 1-6:5 chip-ID: 046d:0aaa class-ID: 0300 serial: <filter>
  API: ALSA v: k6.8.4-arch1-1 status: kernel-api
  Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin
  Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
    chip-ID: 10ec:8125 class-ID: 0200
  IF: enp3s0 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel pcie: speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2725
    class-ID: 0280
Bluetooth:
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 bus-ID: 1-11.2:7 chip-ID: 8087:0032 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 1 state: down bt-service: disabled
  Local Storage: total: 2.73 TiB used: 9.94 GiB (0.4%)
  ID-1: /dev/nvme0n1 vendor: Western Digital model: WD Blue SN570 1TB
    size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: 234100WD temp: 35.9 C scheme: GPT
  ID-2: /dev/sda vendor: Seagate model: ST2000DM008-2UB102 size: 1.82 TiB
    speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001
    scheme: GPT
  ID-1: / size: 896.29 GiB used: 9.94 GiB (1.1%) fs: btrfs dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 998 MiB used: 584 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-3: /home size: 896.29 GiB used: 9.94 GiB (1.1%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-4: /var/log size: 896.29 GiB used: 9.94 GiB (1.1%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-1: swap-1 type: partition size: 34.25 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p3
  System Temperatures: cpu: 34.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 32 GiB note: est. available: 31.13 GiB used: 4 GiB (12.9%)
  Processes: 408 Power: uptime: 1h 25m states: freeze,mem,disk suspend: deep
    wakeups: 0 hibernate: platform Init: systemd v: 255 default: graphical
  Packages: pm: pacman pkgs: 1018 Compilers: gcc: 13.2.1 Shell: fish
    v: 3.7.1 running-in: kitty inxi: 3.3.33
And a journalctl -b -0 | grep fail
avril 11 14:41:45 endeavourOS kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
avril 11 14:41:47 endeavourOS kernel: platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
avril 11 14:41:47 endeavourOS kernel: cfg80211: failed to load regulatory.db
avril 11 14:41:47 endeavourOS kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
avril 11 14:41:51 endeavourOS dbus-broker-launch[807]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
avril 11 14:41:52 endeavourOS NetworkManager[912]: <info>  [1712839312.9140] device (wlan0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
avril 11 14:41:52 endeavourOS NetworkManager[912]: <warn>  [1712839312.9142] device (wlan0): Activation: failed for connection 'PlanetCampus - Prive 019297'
avril 11 14:41:52 endeavourOS NetworkManager[912]: <info>  [1712839312.9142] device (wlan0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
avril 11 14:41:53 endeavourOS wireplumber[1093]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner
avril 11 14:41:53 endeavourOS dbus-broker-launch[807]: Activation request for 'org.freedesktop.ModemManager1' failed: The systemd unit 'dbus-org.freedesktop.ModemManager1.service' could not be found.
                                            "Could not activate remote peer: activation request failed: unknown unit."
avril 11 14:41:53 endeavourOS dbus-broker-launch[807]: Activation request for 'org.bluez' failed: The systemd unit 'dbus-org.bluez.service' could not be found.
avril 11 14:41:53 endeavourOS kded6[1147]: kf.bluezqt: PendingCall Error: "Could not activate remote peer: activation request failed: unknown unit."
avril 11 14:41:53 endeavourOS org_kde_powerdevil[1222]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
avril 11 14:41:53 endeavourOS org_kde_powerdevil[1222]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
avril 11 14:41:54 endeavourOS org_kde_powerdevil[1222]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
avril 11 14:41:54 endeavourOS xwaylandvideobridge[1384]: libEGL warning: egl: failed to create dri2 screen
avril 11 14:41:59 endeavourOS dbus-broker-launch[807]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
avril 11 14:42:10 endeavourOS sudo[1822]: pam_unix(sudo:auth): authentication failure; logname=triomph uid=1000 euid=0 tty=/dev/pts/0 ruser=triomph rhost=  user=triomph
avril 11 14:44:16 endeavourOS kwin_wayland_wrapper[2276]: Crash Annotation GraphicsCriticalError: |[0][GFX1-]: GFX: CanvasTranslator failed creating WebGL shared context (t=12.3868) [GFX1-]: GFX: CanvasTranslator failed creating WebGL shared context
avril 11 14:52:37 endeavourOS dolphin[3918]: kf.notifications: Playing audio notification failed: Destroyed
avril 11 15:04:48 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigGeneral.qml: Setting initial properties failed: ConfigGeneral does not have a property called cfg_extraItems
avril 11 15:04:48 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigGeneral.qml: Setting initial properties failed: ConfigGeneral does not have a property called cfg_extraItemsDefault
avril 11 15:04:48 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigGeneral.qml: Setting initial properties failed: ConfigGeneral does not have a property called cfg_hiddenItems
avril 11 15:04:48 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigGeneral.qml: Setting initial properties failed: ConfigGeneral does not have a property called cfg_hiddenItemsDefault
avril 11 15:04:48 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigGeneral.qml: Setting initial properties failed: ConfigGeneral does not have a property called cfg_iconSpacingDefault
avril 11 15:04:48 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigGeneral.qml: Setting initial properties failed: ConfigGeneral does not have a property called cfg_knownItems
avril 11 15:04:48 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigGeneral.qml: Setting initial properties failed: ConfigGeneral does not have a property called cfg_knownItemsDefault
avril 11 15:04:48 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigGeneral.qml: Setting initial properties failed: ConfigGeneral does not have a property called cfg_pin
avril 11 15:04:48 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigGeneral.qml: Setting initial properties failed: ConfigGeneral does not have a property called cfg_pinDefault
avril 11 15:04:48 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigGeneral.qml: Setting initial properties failed: ConfigGeneral does not have a property called cfg_scaleIconsToFitDefault
avril 11 15:04:48 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigGeneral.qml: Setting initial properties failed: ConfigGeneral does not have a property called cfg_showAllItems
avril 11 15:04:48 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigGeneral.qml: Setting initial properties failed: ConfigGeneral does not have a property called cfg_showAllItemsDefault
avril 11 15:04:48 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigGeneral.qml: Setting initial properties failed: ConfigGeneral does not have a property called cfg_shownItems
avril 11 15:04:48 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigGeneral.qml: Setting initial properties failed: ConfigGeneral does not have a property called cfg_shownItemsDefault
avril 11 15:04:49 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigEntries.qml: Setting initial properties failed: ConfigEntries does not have a property called cfg_extraItemsDefault
avril 11 15:04:49 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigEntries.qml: Setting initial properties failed: ConfigEntries does not have a property called cfg_hiddenItemsDefault
avril 11 15:04:49 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigEntries.qml: Setting initial properties failed: ConfigEntries does not have a property called cfg_iconSpacing
avril 11 15:04:49 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigEntries.qml: Setting initial properties failed: ConfigEntries does not have a property called cfg_iconSpacingDefault
avril 11 15:04:49 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigEntries.qml: Setting initial properties failed: ConfigEntries does not have a property called cfg_knownItems
avril 11 15:04:49 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigEntries.qml: Setting initial properties failed: ConfigEntries does not have a property called cfg_knownItemsDefault
avril 11 15:04:49 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigEntries.qml: Setting initial properties failed: ConfigEntries does not have a property called cfg_pin
avril 11 15:04:49 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigEntries.qml: Setting initial properties failed: ConfigEntries does not have a property called cfg_pinDefault
avril 11 15:04:49 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigEntries.qml: Setting initial properties failed: ConfigEntries does not have a property called cfg_scaleIconsToFit
avril 11 15:04:49 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigEntries.qml: Setting initial properties failed: ConfigEntries does not have a property called cfg_scaleIconsToFitDefault
avril 11 15:04:49 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigEntries.qml: Setting initial properties failed: ConfigEntries does not have a property called cfg_showAllItemsDefault
avril 11 15:04:49 endeavourOS plasmashell[1163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ConfigEntries.qml: Setting initial properties failed: ConfigEntries does not have a property called cfg_shownItemsDefault
avril 11 15:13:43 endeavourOS spectacle[14719]: 'pthread_equal(impl->thread, thread_id)' failed at ../pipewire/spa/plugins/support/loop.c:363 loop_leave()
avril 11 15:15:44 endeavourOS spectacle[15366]: 'pthread_equal(impl->thread, thread_id)' failed at ../pipewire/spa/plugins/support/loop.c:363 loop_leave()
avril 11 15:17:24 endeavourOS spectacle[15734]: 'pthread_equal(impl->thread, thread_id)' failed at ../pipewire/spa/plugins/support/loop.c:363 loop_leave()
avril 11 15:18:24 endeavourOS spectacle[16612]: 'pthread_equal(impl->thread, thread_id)' failed at ../pipewire/spa/plugins/support/loop.c:363 loop_leave()
avril 11 15:19:28 endeavourOS spectacle[17141]: 'pthread_equal(impl->thread, thread_id)' failed at ../pipewire/spa/plugins/support/loop.c:363 loop_leave()
avril 11 15:27:26 endeavourOS spectacle[18600]: 'pthread_equal(impl->thread, thread_id)' failed at ../pipewire/spa/plugins/support/loop.c:363 loop_leave()
avril 11 15:28:11 endeavourOS spectacle[18898]: 'pthread_equal(impl->thread, thread_id)' failed at ../pipewire/spa/plugins/support/loop.c:363 loop_leave()
avril 11 15:31:30 endeavourOS spectacle[19270]: 'pthread_equal(impl->thread, thread_id)' failed at ../pipewire/spa/plugins/support/loop.c:363 loop_leave()
Here are some recordings that demonstrates a little part of the what I’m experiencing :
I hope someone knows how to help me find a solution, I think it’s either (from most to least likely):
  1. something missing with my nvidia drivers
  2. a conflict between my GPU and my iGPU
  3. something wrong with EOS or KDE for ultra-wide monitors
  4. or, a firmware issue with the G9
Have you tried using the x11 session for KDE?
Okay, it seems to have almost completely solved the problem. (still some little artifacts from time to time, but nothing too important)
Thank you!
I hope Wayland will become more stable, since, from what I’ve heard, X11 will gradually be phased out from KDE.
I’ve also heard that the new nvidia driver (550) has also been creating some problems with wayland. If you want to try to keep using wayland, try downgrading to 535. There is probably a guide/package list for it that someone posted.
FYI: It will be years before x11 is “phased out”. It just works. Why phase out something that works unless it actually stops working with kernels, apps, hardware, etc.?
You can safely and comfortably continue using x11 for at least another 5 years. Nothing Linux-related gets phased out quickly. That is why people with very old computers can use Linux just fine to this day even though they can’t use M$ or M@c.
