Virtualbox 6.1.12-4 fails
14 community/virtualbox-sdk 6.1.12-4 (6.5 MiB 18.9 MiB)
    VirtualBox Software Developer Kit (SDK)
13 community/virtualbox-host-modules-arch 6.1.12-8 (154.9 KiB 152.1 KiB)
    Virtualbox host kernel modules for Arch Kernel
12 community/virtualbox-host-dkms 6.1.12-4 (704.6 KiB 10.0 MiB) (Installed)
    VirtualBox Host kernel modules sources
11 community/virtualbox-guest-utils-nox 6.1.12-4 (971.5 KiB 5.5 MiB)
    VirtualBox Guest userspace utilities without X support
10 community/virtualbox-guest-utils 6.1.12-4 (1.3 MiB 9.0 MiB)
9 community/virtualbox-guest-iso 6.1.12-1 (41.3 MiB 57.8 MiB) (Installed)
    The official VirtualBox Guest Additions ISO image
8 community/virtualbox-guest-dkms 6.1.12-4 (30.8 KiB 101.2 KiB) (Installed)
    VirtualBox Guest kernel modules sources
7 community/virtualbox-ext-vnc 6.1.12-4 (76.8 KiB 84.7 KiB)
    VirtualBox VNC extension pack
6 community/virtualbox 6.1.12-4 (35.3 MiB 160.9 MiB) (Installed)
    Powerful x86 virtualization for enterprise as well as home use
5 community/phpvirtualbox 5.2_1-2 (2.8 MiB 21.1 MiB)
    PHP/AJAX web interface for VirtualBox
4 community/libvirt 6.5.0-1 (7.3 MiB 40.0 MiB) (Installed)
    API for controlling virtualization engines (openvz,kvm,qemu,virtualbox,xen,etc)
extension build from AUR is 6.1.13 :stuck_out_tongue_winking_eye:
2 aur/virtualbox-ext-oracle 6.1.13.139853-1 (+1305 7.98) (Installed)
    Oracle VM VirtualBox Extension Pack
Okay …you mean the -4 version isn’t working. Sorry !
The downloads are really slow. I’m at 53%… usually 4-6 minutes now it’s taking forever.
I think there is definitely something wrong with the recent Virtualbox update.
I havent had any problems with my 10 or so VMs for months ( Win10, several Win Servers, Ubuntu) but right after installing this weeks update a couple crashed but came back up ok (so far), but the most important VM gets stuck during launch and I havent managed to get back in yet. Think I need to rollback as well. First time ever I have to do this.
Me too … I have been using virtualbox a long time and this is the worst i have seen problems with it.
Edit: It’s working now for me and not freezing.
@jonathon
Okay so it’s working now with the 6.1.12-3 dkms but downloads are slow. At least it’s not freezing and it’s working on the 5.7.12 kernel. So i’m sure when 5.8 is out it will not work again.
I have used qemu and vmware workstation but i prefer virtualbox and this is the first time i have had a problem with it. I find when i switch its always a problem getting them working right as i’m not as familiar with them. I just find vbox easier to use but this time it is really broken. I had never used the dkms before so this is new. I have it working now so that it’s not freezing and that will do for now.
glad it’s working.
Let’s cross that bridge when it comes out of testing. :wink:
@jonathon
I know you were just kidding about the going Arch comment. Sorry, if i came off a little annoyed. I was just getting frustrated with the freezing and didn’t understand what i needed to do to get this working again. I appreciate the help. Always willing to learn because i only know what i know and it’s not much in the realm of things.
5.8.1arch1-1 just showed up for me on an update (yes, I’m one of those compulsive updaters). Let the fun begin. :smiley:
Good then you can test virtual-box maybe.
Just stumbled over this thread, looks like 5.8.1 is not going to sort out matters https://bbs.archlinux.org/viewtopic.php?id=258118
Played some more with this:
  • Removed my extension (yay -R virtualbox-ext-oracle 6.1.13.139853-1)
  • Disabled USB support in the VM settings
  • Reboot (First time I had to use the RESUB magic key :slight_smile: )
-> Virtualbox crashes and VM is still stuck at boot and taking up one core
I’ll leave this for now, maybe there will be fixes over the weekend, and if not I will try to downgrade.
The combination of:
  • linux 5.8.1.arch1-1
  • virtualbox 6.1.12-4
  • virtualbox-ext-oracle 6.1.13.139853-1
  • virtualbox-host-modules-arch 6.1.12-9
should work (or at least, it works for me with virtualbox-host-modules-dkms 6.1.12-4 with linux and linux-zen). However, it did need a bit of juggling with unloading kernel modules and reinstalling the ext pack and a couple of reboots to make it all align correctly.
Basically, if you update and it doesn’t work then reboot before trying anything else.
I am using a similar set of packages to what @jonathon lists above, though today a new version of host modules came out. My packages are:
I have run both Win10 and EOS guests without issues with the above packages installed. I did reboot after the package installs - it seems like the virtualbox-host-modules-arch don’t play nice without the reboot.
This isn’t working for me at all.
I downgraded the host modules to .8 and have now got the exact same line up:
$ uname -a
Linux hermes 5.8.1-arch1-1 #1 SMP PREEMPT Wed, 12 Aug 2020 18:50:43 +0000 x86_64 GNU/Linux
$ yay -Q | grep virtualbox
virtualbox 6.1.12-4
And a reboot later (required RESUB) I am getting systemd core dumps:
Process 2478 (VirtualBoxVM) of user 1000 dumped core
And because the process is not there any longer VirtualBox tells me the kernel driver is not installed.
I have tried and can’t get virtual-box to work as again it just freezes up. :hole: :point_left: :walking_man:
Rick… I just loaded 5.8 and Virtual Box works at least for me! Good Luck
I have tried it every which way but Sunday as they say and it’s freezing like it did before.
Edit: https://bugs.archlinux.org/task/67488
