I installed libvdpau-va-gl and intel-media-driver and rebooted and still no luck. libva-intel-driver was already installed.
When running VLC from the command line I get no errors, but the image still does not move. When quitting VLC I get (opening an mp4 file):
VLC media player 3.0.18 Vetinari (revision 3.0.13-8-g41878ff4f2)
[000056227c30b5e0] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00007f8620007a40] gl gl: Initialized libplacebo v5.229.2 (API v229)
[00007f8644c211e0] avcodec decoder: Using Intel iHD driver for Intel(R) Gen Graphics - 23.1.0 () for hardware decoding
^C[h264 @ 0x7f8644ef34c0] get_buffer() failed
[h264 @ 0x7f8644ef34c0] thread_get_buffer() failed
[h264 @ 0x7f8644ef34c0] decode_slice_header error
[h264 @ 0x7f8644ef34c0] no frame!
With mpv I see no errors in the console, but still no moving pictures.
Oh! Knowing it had worked until recently triggered a thought. By recently, would that be today? The libplacebo pkg was updated today.
yay -Qi libplacebo
Version : 5.229.2-1
Description : Reusable library for GPU-accelerated video/image rendering primitives
Architecture : x86_64
URL : https://github.com/haasn/libplacebo
Licenses : LGPL2.1
Groups : None
Provides : libplacebo.so=229-64
Depends On : vulkan-icd-loader libvulkan.so=1-64 glslang lcms2 liblcms2.so=2-64 shaderc libshaderc_shared.so=1-64 glibc gcc-libs libunwind
Optional Deps : None
Required By : mpv
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 1186.67 KiB
Packager : Levente Polyak anthraxx@archlinux.org
Build Date : Sat 25 Feb 2023 06:05:01 AM CST
Install Date : Sat 25 Feb 2023 02:00:38 PM CST
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
From the last error, it looks like you have v5.229.2, so you could try to downgrade it to the previous.
At the moment, that seems like it would support the theory that downgrading the libplacebo library will help. There are still other factors at play between the ISO and bare metal, so that might only be wishful thinking.
Edit:
I also use i3, but on a HP Omen Optimus laptop. I did find an mp4 in my library, and it plays in mpv on my system. As I am using nvidia, this doesn’t really provide much help as to whether it is libplacebo, or still hunting a missing lib or config, unfortunately.
Sounds like you figured out how to compare and find the differences for ISO and installed files.
Glad to hear you got it working. Not sure why it would have stopped working for you, but you might take a look at Arch Wiki Intel, to see if you can get direction for any of the remaining errors.
Thanks. That looks very technical. It works so I stick with what I have now. I am sure any issues will fix themselves in future updates. I don’t know enough about hardware to properly troubleshoot this issue.
Postscriptum: I did a fresh install, removed xf86-video-intel, rebooted and presto.
