Ok, thought it was stereo-duplex config setting and that worked for a little bit then everything went south again. Can someone school me how to debug this issue?
What is happening:
- Audio will play or stutter
- Video freezes
Tried:
- Firefox / Vivaldi visting youtube and vimeo and news channels with all plugins disabled
- VLC local video file
- Downgrading pipewire (no effect)
- Downgrading kernel to 6.6.6
β― pactl list | eos-sendlog
https://0x0.st/HE5K.txt
β― pipewire --version
pipewire
Compiled with libpipewire 1.0.0
Linked with libpipewire 1.0.0
~ via π v5.4.6
β― uname -r
6.6.8-arch1-1
~ via π v5.4.6
β― systemctl --user status pipewire
β pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
Active: active (running) since Sun 2023-12-31 10:10:26 EST; 59s ago
TriggeredBy: β pipewire.socket
Main PID: 1852 (pipewire)
Tasks: 3 (limit: 38239)
Memory: 6.7M (peak: 7.0M)
CPU: 24ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
ββ1852 /usr/bin/pipewire
Dec 31 10:10:26 acefour-1 systemd[1739]: Started PipeWire Multimedia Service.
~ via π v5.4.6
β― systemctl --user status pipewire-pulse
β pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; disabled; preset: enabled)
Active: active (running) since Sun 2023-12-31 10:10:28 EST; 1min 4s ago
TriggeredBy: β pipewire-pulse.socket
Main PID: 3916 (pipewire-pulse)
Memory: 3.3M (peak: 3.5M)
CPU: 13ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
ββ3916 /usr/bin/pipewire-pulse
Dec 31 10:10:28 acefour-1 systemd[1739]: Started PipeWire PulseAudio.
~ via π v5.4.6
β― journalctl -b -0 | grep firmware
Dec 31 10:10:15 acefour-1 kernel: platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
Dec 31 10:10:15 acefour-1 kernel: iwlwifi 0000:08:00.0: loaded firmware version 83.e8f84e98.0 ty-a0-gf-a0-83.ucode op_mode iwlmvm
Dec 31 10:10:17 acefour-1 kernel: Bluetooth: hci0: Found device firmware: intel/ibt-0041-0041.sfi
Dec 31 10:10:17 acefour-1 NetworkManager[731]: <info> [1704035417.3344] manager[0x55721c967cc0]: monitoring kernel firmware directory '/lib/firmware'.
Dec 31 10:10:17 acefour-1 kernel: [drm] Loading DMUB firmware via PSP: version=0x02020020
Dec 31 10:10:17 acefour-1 kernel: [drm] Found VCN firmware Version ENC: 1.29 DEC: 2 VEP: 0 Revision: 2
Dec 31 10:10:17 acefour-1 kernel: amdgpu 0000:03:00.0: amdgpu: Will use PSP to load VCN firmware
Dec 31 10:10:28 acefour-1 systemd[1]: Startup finished in 9.944s (firmware) + 2.915s (loader) + 1.088s (kernel) + 752ms (initrd) + 14.259s (userspace) = 28.960s.
~ via π v5.4.6
β― inxi -Aaz
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:7ad0 class-ID: 0403
Device-2: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
API: ALSA v: k6.6.8-arch1-1 status: kernel-api
Server-1: sndiod v: N/A status: off tools: aucat,midicat,sndioctl
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
~ via π v5.4.6
Active: active (running) since Sun 2023-12-31 10:10:28 EST; 13min ago
Memory: 4.1M (peak: 4.3M)
CPU: 15ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.servi>
