Everything worked just find till last update(did it from pamac). The extended dysplay resolution is 1920x1080 but after update highest it can go is 1024x768.
I tired
cvt 1920 1080
xrandr --newmode "1920x1080_60.00" 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync
xrandr --addmode VGA1 1920x1080_60.00
xrandr --output VGA1 --mode 1920x1080_60.00
the message pops:
xrandr: Configure crtc 1 failed
I can’t roll back since i did not make backup, never tought of it till now
Was looking trough forums and arch wiki, did not find solution, also uninstalled xf86-video-intel, did not help, installed it again, nothing…
Here is my inxi -Fxxxz
System: Kernel: 5.15.2-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2
info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: EndeavourOS base: Arch Linux
Machine: Type: Laptop System: FUJITSU product: LIFEBOOK E734 v: 10601583233 serial: <filter> Chassis: type: 10
v: LIFEBOOK E734 serial: <filter>
Mobo: FUJITSU model: FJNB26F v: M3 serial: <filter> UEFI: FUJITSU // Phoenix v: Version 1.17 date: 09/26/2014
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 Plus serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: Discharging
CPU: Info: Quad Core model: Intel Core i7-4712MQ bits: 64 type: MT MCP arch: Haswell rev: 3 cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36734
Speed: 797 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 797 2: 1627 3: 2274 4: 798 5: 802 6: 872 7: 798
8: 965
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Fujitsu Limited. driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: Chicony FJ Camera type: USB driver: uvcvideo bus-ID: 3-12:9 chip-ID: 04f2:b3b4 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: intel
unloaded: fbdev,modesetting,vesa resolution: 1: 1366x768~60Hz 2: 1024x768~60Hz s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 21.2.5 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Fujitsu Limited. driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Fujitsu Limited. driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-arch1-1 running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Network: Device-1: Intel Ethernet I217-LM vendor: Fujitsu Limited. driver: e1000e v: kernel port: 3080 bus-ID: 00:19.0
chip-ID: 8086:153a class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 02:00.0 chip-ID: 8086:08b1 class-ID: 0280
Device-3: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter type: USB driver: hid-generic,usbhid
bus-ID: 3-10.3:8 chip-ID: 0458:6001 class-ID: 0301
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-3: wwp0s20u11c2i12 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 3-8:4 chip-ID: 8087:07dc
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled rfk-block: hardware: no software: no
address: see --recommends
Drives: Local Storage: total: 465.76 GiB used: 222.86 GiB (47.8%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 3B6Q scheme: GPT
Partition: ID-1: / size: 456.88 GiB used: 222.86 GiB (48.8%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 511 MiB used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info: Processes: 243 Uptime: 11m wakeups: 3 Memory: 15.51 GiB used: 3.05 GiB (19.7%) Init: systemd v: 249 Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1421 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.07
I hope someone can help me
