I am using Endevour OS since a month, and have been trying to fix the internet speed for pacman and AUR, (using yay). I have tried rankmirrors to find the fastest mirrors, I have tried using reflector for the same, which throws following warnings:
WARNING: failed to rate http(s) download
WARNING: failed to rate rsync download
but the most I could get out of all this is a bump till 3Mbps. while using the speedtest-cli gets a speed till 60-70Mbps. This also causes the AUR downloads to fail with validity checks, when the AUR packages are above 1GB.
I would be happy to provide any other logs, Any help in this regard would be much appreciated.
I guess it must depend on where you are - although I would have thought that rate-mirrors would have worked OK. For decent speeds it seems the German, US and Canadian (!) mirrors are best bet for out-of-area speeds if your local mirrors are slow. I guess you could post the results of your rate-mirrors run, it might give us some clues…
Please try the application reflector-simple included in EnOS and limit your mirrors to the countries mentioned above known to have updated servers with good speed. And also choose less number of mirrors as mentioned in the previous post.
add Germany and USA to be ranked and try using the update mirrors app you can start from the welcome app it shows a GUI with options for countries e.t.c. and show your mirrors list: cat /etc/pacman.d/mirrorlist | eos-sendlog
cat /etc/xdg/reflector/reflector.conf
# Reflector configuration file for the systemd service.
# Empty lines and lines beginning with "#" are ignored. All other lines should
# contain valid reflector command-line arguments. The lines are parsed with
# Python's shlex modules so standard shell syntax should work. All arguments are
# collected into a single argument list.
# See "reflector --help" for details.
# Recommended Options
# Set the output path where the mirrorlist will be saved (--save).
--save /etc/pacman.d/mirrorlist
# Select the transfer protocol (--protocol).
--protocol https
# Select the country (--country).
# Consult the list of available countries with "reflector --list-countries" and
# select the countries nearest to you or the ones that you trust. For example:
# --country France,Germany
# Use only the most recently synchronized mirrors (--latest).
--latest 5
# Sort the mirrors by synchronization time (--sort).
--sort rate
Also enable systemd reflector timer, which will update your mirrors weekly
❯ cat /etc/pacman.d/mirrorlist | eos-sendlog
% Total % Received % Xferd Average Speed Time Time Time Current
0 0 0 0 0 0 0 0 --:--:-- 0:02:13 --:--:-- 0
curl: (28) Failed to connect to clbin.com port 443 after 133286 ms: Connection timed out
This is the error message.
the contnet of my mirrorlist:
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector --verbose -c CA -c DE -c IN -c US --protocol https --sort rate --latest 15 --download-timeout 3
# When: 2022-01-24 12:01:48 UTC
# From: https://archlinux.org/mirrors/status/json/
# Retrieved: 2022-01-24 12:00:22 UTC
# Last Check: 2022-01-24 11:15:27 UTC
## Germany
Server = https://mirror.pkgbuild.com/$repo/os/$arch
## United States
Server = https://arch.mirror.constant.com/$repo/os/$arch
## United States
Server = https://mirror.lty.me/archlinux/$repo/os/$arch
## Germany
Server = https://mirror.f4st.host/archlinux/$repo/os/$arch
## Germany
Server = https://mirror.chaoticum.net/arch/$repo/os/$arch
## United States
Server = https://mirror.hackingand.coffee/arch/$repo/os/$arch
## Germany
Server = https://phinau.de/arch/$repo/os/$arch
## United States
Server = https://america.mirror.pkgbuild.com/$repo/os/$arch
## Canada
Server = https://mirror.csclub.uwaterloo.ca/archlinux/$repo/os/$arch
## Germany
Server = https://mirror.luzea.de/archlinux/$repo/os/$arch
## Germany
Server = https://archlinux.thaller.ws/$repo/os/$arch
## Germany
Server = https://mirror.pseudoform.org/$repo/os/$arch
## Germany
Server = https://de.arch.mirror.kescher.at/$repo/os/$arch
## Germany
Server = https://ftp.halifax.rwth-aachen.de/archlinux/$repo/os/$arch
## United States
Server = https://mirror.theash.xyz/arch/$repo/os/$arch
## Worldwide
Server = https://mirror.rackspace.com/archlinux/$repo/os/$arch
you should try also rate-mirrors it has some smart stuff that also counts in real-world infrastructural stuff like undersea cables and other stuff related to your location.
» rate-mirrors --help
rate-mirrors config 0.9.0
Usually default options should work
USAGE:
rate-mirrors [FLAGS] [OPTIONS] <SUBCOMMAND>
FLAGS:
--allow-root
allow running by root
-h, --help
Prints help information
-V, --version
Prints version information
OPTIONS:
--concurrency <concurrency>
Number of simultaneous speed tests [default: 8]
--country-neighbors-per-country <country-neighbors-per-country>
Neighbor country to test per country [default: 3]
--country-test-mirrors-per-country <country-test-mirrors-per-country>
Number of mirrors to test per country [default: 2]
--entry-country <entry-country>
Entry country - first country (+ its neighbours) to test.
You don't need to change it unless you are just curious. [default: US]
--eps <eps>
Per-mirror: sigma to mean speed ratio
1.0 -- 68% probability (1 sigma), no 100% error
0.5 -- 68% probability (1 sigma), no 50% error;
0.25 -- 68% probability (1 sigma), no 25% error;
0.125 -- 95% probability (2 sigmas), no 25% error;
0.0625 -- 95% probability (2 sigmas), no 12.5% error: [default: 0.0625]
--eps-checks <eps-checks>
Per-mirror: after min measurement time elapsed, check such number of subsequently downloaded data chunks
whether speed variations are less then "eps" [default: 40]
--max-jumps <max-jumps>
Max number of jumps between countries, when finding top mirrors [default: 7]
--min-bytes-per-mirror <min-bytes-per-mirror>
Minimum number of bytes to be downloaded, required to measure mirror speed [default: 70000]
--min-per-mirror <min-per-mirror>
Minimum downloading time, required to measure mirror speed, in milliseconds [default: 300]
--per-mirror-timeout <per-mirror-timeout>
Per-mirror speed test timeout in milliseconds [default: 1500]
--protocol <protocol>...
Test only specified protocols (can be passed multiple times)
--save <save-to-file>
Filename to save the output to in case of success
--top-mirrors-number-to-retest <top-mirrors-number-to-retest>
Number of top mirrors to retest [default: 5]
SUBCOMMANDS:
arch fetch & test archlinux mirrors
artix fetch & test artix mirrors
cachyos fetch & test cachyos mirrors
endeavouros fetch & test endeavouros mirrors
help Prints this message or the help of the given subcommand(s)
manjaro fetch & test manjaro mirrors
rebornos fetch & test rebornos mirrors
stdin accepts lines of urls OR lines with tab-separated urls and countries
This is a sign that your issue is not really related to Arch mirrors and your mirrorlist selection, since AUR packages are not related to that. It’s a network problem.
A usual test for download speeds (disconnected from random speed-test providers) is to test downloading (temporarily, delete after) a Linux distro ISO from different servers, for example an archlinux ISO from random worldwide servers. Use wget or uGet (GUI) to have a cleaner outcome.
This may give you one clue about the real issue.
I think I have heard people from India complaining about the same thing, so maybe it has to do with internet provider or country standards/complications(?).
