Using QEMU on btrfs host with Timeshift
My dear fellows,
recently I’ve been searching and studying a lot of information about btrfs, but there is still one particular setup scenario where I would need your help or at least confirmation. It is combination of btrfs, Timeshift snapshots and using your computer as host for QEMU virtual machines.
What I have learned so far (and I really need to highlight THIS HOWTO as it is pure gold and helped me a ton:
  • When choosing btrfs during EndeavourOS installation, the installers intelligently creates subvolumes @ (for root), @home, @cache (for /var/cache), @log (for /var/log) and even @swap for storing swapfile with nocow attribute, so there is almost no reason to adjust anything, as the subvolumes layout makes perfect sense
  • The above layout, among other things, ensures that certain subvolumes are omitted from Timeshift snapshots, as Timeshift automatically skips subvolumes created/mounted underneath root (@)
  • At the same time, however, btrfs is many times considered as not ideal for storing virtual machines, especially qcow2 volumes from KVM/QEMU. It has something to do with double copy-on-write approach, with a lot of fragmentation and low performance
  • One recommended approach is to store qcow2 images in a folder which has nocow attribute set (chattr +C) and therefore all files in this folder would be created with copy-on-write disabled
  • Unfortunately, as soon as this folder is snapshotted (via Timeshift), copy-on-write is automatically enabled
And now the big question - what to do? Would the following approach be valid?
  • Create one additional subvolume, e.g. @vm, set its attribute to nocow (chattr +C) and mount it for example under /vm
  • This way, the qcow2 images would be created with copy-on-write disabled, and since the subvolume is mounted under root, Timeshift would exclude it from snapshotting
Looking very much forward to your feedback and advice!
Yes, of course. Whenever you have something that you want to exclude from snapshots, the best way is to create separate subvolume for it. You can create a subvol at the root called @vm and mount it somewhere or you can just create a nested subvol wherever you keep your VM files and not worry about mounting it.
Thank you so much dalto for the ninja-fast reply!
I don’t suppose I need the autodefrag and compress options when mounting the @vm subvolume, as long as it would only contain the qcow2 images, right?
Yes, you don’t.
