Hi,
I am trying to follow the guide at https://discovery.endeavouros.com/nvidia/new-nvidia-driver-installer-nvidia-inst/2022/03/ to install nvidia drivers with prime on my laptop. My laptop has Intel HD 4600 and Nvidia 750M graphic cards.
I found that 390 series drivers were supported:
$ nvidia-inst --drivers
NVIDIA card id: 0fe4
Series 510: not supported
Series 470: not supported
Series 390: supported
More info: https://www.nvidia.com/en-us/drivers/unix
I used the following command to install the drivers, but I received an error:
$ nvidia-inst --prime --legacyrepo
2022-04-10 15:11:21: Note: Setting up repository [kernel-lts].
2022-04-10 15:11:21: Note: This repo provides legacy Nvidia drivers and LTS kernels.
2022-04-10 15:11:21: Note: More info: https://wiki.archlinux.org/title/Unofficial_user_repositories#kernel-lts
2022-04-10 15:11:21: Note: ==> Will also update all packages (pacman -Syu) <== !!
/usr/bin/nvidia-inst: line 366: cat /home/sharazali/.nvidia-inst.LR0T3 >> /etc/pacman.conf; pacman-key --keyserver hkps://keyserver.ubuntu.com --recv-keys 76C6E477042BFE985CC220BD9C08A255442FAFF0; pacman-key --lsign-key 76C6E477042BFE985CC220BD9C08A255442FAFF0; pacman -Syu: No such file or directory
2022-04-10 15:11:21: Error: Setting up repository [kernel-lts] failed.
I wanted to ask if I am using the right commands in this case or have I made a mistake somewhere? Here is my system information:
$ inxi -Fx
  Host: Lenovo-Y510P Kernel: 5.15.33-1-lts arch: x86_64 bits: 64
    compiler: gcc v: 11.2.0 Desktop: GNOME v: 42.0 Distro: EndeavourOS
    base: Arch Linux
  Type: Laptop System: LENOVO product: 20217 v: Lenovo IdeaPad Y510P
    serial: <superuser required>
  Mobo: LENOVO model: VIQY0Y1 v: 31900004STD serial: <superuser required>
    UEFI: LENOVO v: 74CN47WW(V3.08) date: 1/30/2015
Battery:
  ID-1: BAT1 charge: 46.3 Wh (100.0%) condition: 46.3/56.4 Wh (82.1%)
    volts: 12.2 min: 10.8 model: LENOVO PABAS0241231 status: full
  Info: quad core model: Intel Core i7-4700MQ bits: 64 type: MT MCP
    arch: Haswell rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
  Speed (MHz): avg: 2257 high: 2398 min/max: 800/3400 cores: 1: 1924
    2: 2007 3: 2393 4: 2396 5: 2395 6: 2154 7: 2395 8: 2398 bogomips: 38311
  Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
    driver: i915 v: kernel bus-ID: 00:02.0
  Device-2: NVIDIA GK107M [GeForce GT 750M] vendor: Lenovo driver: nouveau
    v: kernel bus-ID: 01:00.0
  Device-3: Syntek Lenovo EasyCamera type: USB driver: uvcvideo
    bus-ID: 3-1:2
  Display: x11 server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1 driver:
    X: loaded: intel,modesetting gpu: i915 resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics 4600 (HSW GT2)
    v: 4.6 Mesa 22.0.1 direct render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  Device-3: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel
    bus-ID: 01:00.1
  Sound Server-1: ALSA v: k5.15.33-1-lts running: yes
  Sound Server-2: PulseAudio v: 15.0 running: no
  Sound Server-3: PipeWire v: 0.3.49 running: yes
  Device-1: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Lenovo
    driver: alx v: kernel port: 3000 bus-ID: 07:00.0
  IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: 28:d2:44:39:a3:d4
  Device-2: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel
    bus-ID: 08:00.0
  IF: wlan0 state: up mac: 00:c2:c6:11:08:1e
Bluetooth:
  Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB
    driver: btusb v: 0.8 bus-ID: 3-7:5
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: disabled
  Local Storage: total: 1.35 TiB used: 182.39 GiB (13.2%)
  ID-1: /dev/sda vendor: Seagate model: ST1000LM014-1EJ164 size: 931.51 GiB
  ID-2: /dev/sdb vendor: PNY model: CS900 480GB SSD size: 447.13 GiB
  ID-1: / size: 438.75 GiB used: 182.39 GiB (41.6%) fs: ext4 dev: /dev/sdb2
  ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
    dev: /dev/sdb1
  System Temperatures: cpu: 43.0 C mobo: N/A gpu: nouveau temp: 39.0 C
  Fan Speeds (RPM): N/A
  Processes: 227 Uptime: 23m Memory: 15.54 GiB used: 1.61 GiB (10.3%)
  Init: systemd Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1233
  Shell: Bash v: 5.1.16 inxi: 3.3.15
Thank you.
