Using My Nvidia GPU on my fresh install
Hello! I just replaced my Manjaro installation with this one. Fresh off the install, didn’t do anything funny aside from installing my text editor, setting up firefox, etc.
When I booted up the live USB, I chose the “Use latest cards” option for my Nvidia card, a GeForce 1060.
However, when I downloaded steam and checked my system info, it doesn’t seem to be using my proprietary driver.
When I run inxi -Ga, this is what I have.
What do I need to do to get my driver recognized? From what I understand, the drivers should have been properly installed just from me using the proper option when I used the Live USB.
Update: I was fooling around and doing a bunch of steps even if they seemed redundant, and found one video that said to use this specific line used on the Lutris wiki.
sudo pacman -S --needed lib32-mesa vulkan-radeon lib32-vulkan-radeon vulkan-icd-loader lib32-vulkan-icd-loader
Regardless, it seems that that coupled with the advice Nomad gave me did the trick since I can now play my games on steam. Thanks a bunch, folks.
Every time I hear the word Nvidia in the context of Linux, a part of my insides begins the process of death.
To ensure the drivers are installed, try sudo pacman -S nvidia nvidia-utils
Then you might need to create or edit the Xorg configuration file to load the NVIDIA driver. Use the following command to generate the file: sudo nvidia-xconfig. This command will create /etc/X11/xorg.conf . You may need to customize this file if necessary.
When done, reboot and then check to see if the driver is loaded with nvidia-smi
You can also check Xorg logs for any errors cat /var/log/Xorg.0.log | grep NVIDIA
Will give this a go.
Tried what you suggested and it didn’t seem to change much.
My terminal output.
Are there any changes I should make to the xorg conf file?
This is rather odd. Let’s try a few more moves. Hopefully you are using GRUB for this.
First, let’s blacklist Nouveau which is the open-source driver for NVIDIA cards. It can conflict with the proprietary NVIDIA driver. To prevent it from loading, create a file named /etc/modprobe.d/blacklist.conf and add the following lines:
blacklist nouveau
options nouveau modeset=0
Then regenerate your initramfs to include the changes with: sudo mkinitcpio -P
Next, lets edit your GRUB configuration file. Open /etc/default/grub and add nvidia to the MODULES line: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nvidia"
After editing GRUB, update GRUB with sudo grub-mkconfig -o /boot/grub/grub.cfg
Reboot and see if it works.
AH, that may be part of it. I chose the systemd boot manager instead of Grub when I installed the system. I guess I should reinstall and choose GRUB this time.
I wouldn’t blame systemd. I just provided GRUB instructions, assuming you were using it.
Follow the same instructions I just gave in my previous comment but replace the GRUB instructions with the following systemd one:
Edit your systemd-boot configuration file. You can find this file at /boot/loader/entries/arch.conf or a similar path depending on your system setup. Add the nvidia module to the options line: options root=PARTUUID=<your-root-partuuid> rw quiet nvidia-drm.modeset=1
Make sure to replace <your-root-partuuid> with the actual PARTUUID of your root partition.
Reboot and check again.
Will do, boss :saluting_face:
Gave it a try and it seems that the arch.conf file already had the nvidia line in it. Steam still using my open source driver for some reason.
Is your entire OS using the open source driver, or just steam?
I believe the entire OS. What command do I use to check?
Make sure the NVIDIA kernel module is loaded. You can check this by running: lsmod | grep nvidia
If it’s not loaded, load it using sudo modprobe nvidia
Check the contents of your /etc/X11/xorg.conf file. You should see:
Section "Device"
    Identifier "Nvidia Card"
    Driver "nvidia"
    VendorName "NVIDIA Corporation"
EndSection
If you don’t. Add it and reboot.
Also check to see if the GPU is being recognized with lspci | grep -i nvidia
If this doesn’t work, then I’ll have to take a step back and let someone else who has an Nvidia card and actual experience with it take over. :crossed_fingers:t3:
Appreciate the help, friend.
I don’t know what the deal is, so I’ll just post the stuff again and hope someone stumbles across the thread.
What steam currently shows:
lsmod | grep nvidia
My pleasure.
No need to repost. Someone will pop in soon enough.
In the future, consider not buying Nvidia for a Linux machine. Intel and AMD is the way.
Noted. this was a Windows machine initially, and I’ve taken the jump from Manjaro now.
