inxi -Fza
Kernel: 6.14.4-arch1-2 arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
clocksource: tsc avail: acpi_pm
parameters: initrd=\e0ee2436671f43cfaf66ec7f267f5f52\6.14.4-arch1-2\initrd
nvme_load=YES nowatchdog rw
root=UUID=e247b1ec-f3ab-4f33-867b-509ad9bcecee
resume=UUID=38fe6b39-ecdd-43be-b202-63a081f1287b rw
systemd.machine_id=e0ee2436671f43cfaf66ec7f267f5f52
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.13.0
wm: kwin_wayland vt: 1 dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Laptop System: HP product: HP EliteBook 850 G6 v: SBKPF
Mobo: HP model: 8549 v: KBC Version 52.6F.00 serial: <superuser required>
part-nu: 6XD79EA#ABH uuid: <superuser required> UEFI: HP
v: R70 Ver. 01.28.00 date: 04/12/2024
Battery:
ID-1: BAT0 charge: 6.1 Wh (15.6%) condition: 39.0/56.3 Wh (69.3%)
volts: 10.2 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: discharging cycles: 267
Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xFC
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2403 min/max: 400/3900 scaling: driver: intel_pstate
governor: powersave cores: 1: 2403 2: 2403 3: 2403 4: 2403 5: 2403 6: 2403
7: 2403 8: 2403 bogomips: 28800
Vulnerabilities:
Type: gather_data_sampling mitigation: Microcode
Type: ghostwrite status: Not affected
Type: itlb_multihit status: KVM: Split huge pages
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
Type: reg_file_data_sampling status: Not affected
Type: retbleed mitigation: Enhanced IBRS
Type: spec_rstack_overflow status: Not affected
prctl
sanitization
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Quanta HP HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:5 chip-ID: 0408:5373
class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_wayland driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x21ed built: 2018 res:
mode: 1920x1080 hz: 60 scale: 125% (1.25) to: 1536x864 dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris wayland:
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL
GT2) device-ID: 8086:3ea0 memory: 7.53 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (WHL GT2) driver: mesa intel v: 25.0.5-arch1.1
device-ID: 8086:3ea0 surfaces: xcb,xlib,wayland
de: kscreen-console,kscreen-doctor wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Hewlett-Packard driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0401
Device-2: Focusrite-Novation Scarlett Solo USB driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
chip-ID: 1235:801c class-ID: fe01
API: ALSA v: k6.14.4-arch1-2 status: kernel-api
Server-1: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Hewlett-Packard driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15be class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 3a:00.0 chip-ID: 8086:2723 class-ID: 0280
Info: services: NetworkManager, systemd-timesyncd, wpa_supplicant
Bluetooth:
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6 chip-ID: 8087:0029
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 238.47 GiB used: 93.9 GiB (39.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: AGHA4101 temp: 23.9 C
scheme: GPT
ID-1: / raw-size: 220.49 GiB size: 215.97 GiB (97.95%)
used: 93.67 GiB (43.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: yes
compressor: zstd max-pool: 20%
ID-1: swap-1 type: partition size: 16.98 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 35.0 C pch: 28.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 15.43 GiB used: 2.44 GiB (15.8%)
Processes: 233 Power: uptime: 11m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.16 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 257 default: graphical
tool: systemctl
Packages: 1467 pm: pacman pkgs: 1449 libs: 490 tools: yay pm: flatpak
pkgs: 18 Compilers: gcc: 15.1.1 Shell: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.38
pacman -Qs alsa
local/alsa-card-profiles 1:1.4.2-1
Low-latency audio/video router and processor - ALSA card profiles
local/alsa-firmware 1.2.4-4
Firmware binaries for loader programs in alsa-tools and hotplug firmware loader
local/alsa-lib 1.2.14-1
An alternative implementation of Linux sound support
local/alsa-plugins 1:1.2.12-4
Additional ALSA plugins
local/alsa-tools 1.2.14-1
Advanced tools for certain sound cards
local/alsa-topology-conf 1.2.5.1-4
ALSA topology configuration files
local/alsa-ucm-conf 1.2.14-2
ALSA Use Case Manager configuration (and topologies)
local/alsa-utils 1.2.14-1
Advanced Linux Sound Architecture - Utilities
local/lib32-alsa-lib 1.2.14-1
An alternative implementation of Linux sound support (32 bit)
local/lib32-alsa-plugins 1.2.12-1
Additional ALSA plugins (32-bit)
local/pipewire-alsa 1:1.4.2-1
pacman -Qs pulse
local/lib32-libcanberra 1:0.30+r2+gc0620e4-3
A small and lightweight implementation of the XDG Sound Theme Specification (32-bit)
local/lib32-libpulse 17.0+r43+g3e2bb8a1e-1
A featureful, general-purpose sound server (32-bit client libraries)
local/libcanberra 1:0.30+r2+gc0620e4-4
local/libpulse 17.0+r43+g3e2bb8a1e-1
A featureful, general-purpose sound server (client library)
local/pavucontrol 1:6.1-1
PulseAudio Volume Control
local/pipewire-pulse 1:1.4.2-1
Low-latency audio/video router and processor - PulseAudio replacement
local/plasma-pa 6.3.4-1 (plasma)
Plasma applet for audio volume management using PulseAudio
local/pulseaudio-qt 1.7.0-1
Qt bindings for libpulse
pacman -Qs pipewire
local/easyeffects 7.2.3-2
Audio Effects for Pipewire applications
local/gst-plugin-pipewire 1:1.4.2-1
Multimedia graph framework - pipewire plugin
local/kpipewire 6.3.4-1 (plasma)
Components relating to pipewire use in Plasma
local/lib32-libpipewire 1:1.4.2-1
Low-latency audio/video router and processor - 32-bit - client library
local/lib32-pipewire 1:1.4.2-1
local/libpipewire 1:1.4.2-1
Low-latency audio/video router and processor - client library
local/libwireplumber 0.5.8-1
Session / policy manager implementation for PipeWire - client library
local/pipewire 1:1.4.2-1
Low-latency audio/video router and processor - ALSA configuration
local/pipewire-audio 1:1.4.2-1
Low-latency audio/video router and processor - Audio support
local/pipewire-jack 1:1.4.2-1
Low-latency audio/video router and processor - JACK replacement
local/qpwgraph 0.9.0-1 (pro-audio)
PipeWire Graph Qt GUI Interface
local/wireplumber 0.5.8-1
The way I understand it, this is how ALSA supposedly always works (hogging the audio streams) and JACK should be used if you’re planning on having multiple audio streams at the same time.
The problem here is that JACK works very well in Reaper, but will play back the very same audio file about 15db more quietly than ALSA does.
I’ve currently registered (waiting for approval) an account over at the Cockos forum (Reaper devs) because this 15db volume difference only happens in Reaper.
I’d prefer to use JACK as well on this laptop, as I also use it for Reaper on my desktop, but the 15db volume difference was a real showstopper, until ALSA currently decided to also give up.
