I’m using a Ironkey flash drive. To unlock the encrypted part I need to run a unlock app. This app is a 32bit application. Is it possible to run this application?
The multilib repository contains 32-bit libraries.
You will need to use ld to see what libraries it needs and check if they are in the repos.
Possibly, it depends on the application.
How do I use the ld command?
Check man ld and ld --help
To keep it simple you can use ldd /path/to/binary
It needed the libgcc_s.so.1 file. Installed the lib32-gcc-libs file and now the application works. Thanks dalto.
