Hey, I do have A Mechanical keyboard form XPG, And This keyboard has a software on Windows but not for LINUX, I’ve tried installing that XPG PRIME software with WINE, but i got failed/error. I know there is virtualbox/vmware/kvm that support USB Passthrough and i’ve tried, In result its works OS recognize my keyboard MODEL, But when i do that in the HOST machine its not working, All of the key press going into VM, So i came here to know ( HOW I CAN ENABLE USB ON BOTH VM AND HOST PC? )
You cannot.
If you pass an usb device into the vm - it stops working on the host.
But this is a keyboard, So anything i have to do for work with QEMU/KVM?
XPG Prime is only a software to set per key RGB lighting. Has nothing to do with the keyboard actually working. Is the usb keyboard not functioning on vm?
XPG Prime has some specile effets such as MUSIC sync and many more and it does support Chroma RGB, I can’t do everything with my keyboards build in shotcuts. And yes USB works in the VM but issue with i want to configue my keyboard in the VM and i want to use it on HOST. without that keyboard software running i can’t use specile effets that i want.
( what i want is - I will install windows 10 on VM and i will configue that software too then i want to use it on my LINUX HOST, without that software effets will not work so i will run windows in my background all the time if needed ! )
Good luck!
It is still not available in linux yet? it should to be an option in the KVM.
What should be an option in KVM?
QEMU/KVM already is most advanced VM TOOL, but it does not have an option to like what i want ( passthough an usb keyboard or drive with HOST pc access ) something like 2 terminal side by side in one pc.
I don’t use QEMU KVM. I personally don’t like it. I use vmware pro.
Does VMware has this feature ? And how VMware performing compare to the QEMU/KVM? And why you dont like QEMU/KVM?
I don’t know i just use it. I don’t like qemu because it doesn’t set resolution properly on all installs. I don’t want to figure it out. I just want to use it. vmware just works for me. It’s easier, less graphics issues.
Okay, Thanks for replying, Now I do have to wait if someone know how to do that.
Okay i will see that tutorial. BTW do you use WINE/BOTTLES? It is alternative plan to do, I’ve tried that but i got some weird errors XPG prime app installed fine but i can’t open after install i got errors.
0x00000141f92ffe xpg-prime+0x1f92ffe: int $3
Modules:
Module Address Debug info Name (138 modules)
PE 0000000000730000-0000000000800000 Deferred crypt32
PE 0000000005980000-0000000005b00000 Deferred 89cd9a5b-dc04-433f-b149-21fb3919d6b3.tmp.node
PE 0000000010000000-0000000010002000 Deferred usp10
PE 000000007a800000-000000007a909000 Deferred opengl32
PE 000000007b000000-000000007b298000 Deferred kernelbase
PE 000000007b600000-000000007b65d000 Export kernel32
ELF 000000007d000000-000000007d005000 Deferred <wine-loader>
PE 0000000140000000-00000001459e7000 Export xpg-prime
PE 0000000170000000-00000001700a1000 Export ntdll
PE 0000000180000000-0000000180332000 Deferred ffmpeg
PE 00000001cb930000-00000001cb976000 Deferred dxgi
PE 00000001ce760000-00000001ce76e000 Deferred kerberos
PE 00000001d0e20000-00000001d0f58000 Deferred oleaut32
PE 00000001d8c90000-00000001d8cd3000 Deferred advapi32
PE 00000001dbc50000-00000001dbcc9000 Deferred dwrite
PE 00000001de160000-00000001de202000 Deferred urlmon
PE 00000001eaf60000-00000001eaf8a000 Deferred sechost
PE 00000001efe00000-00000001efe4e000 Deferred winhttp
PE 000000020b860000-000000020b981000 Deferred ole32
PE 00000002169d0000-0000000216b7b000 Deferred user32
PE 0000000218320000-000000021834a000 Deferred msdmo
PE 0000000222ed0000-0000000222fd6000 Deferred comdlg32
PE 0000000223d50000-0000000223df3000 Deferred winspool
PE 0000000228280000-000000022831a000 Deferred msvcrt
PE 000000023bc00000-000000023c523000 Deferred shell32
PE 000000023ecb0000-000000023ed25000 Deferred dbghelp
PE 00000002445a0000-00000002445b0000 Deferred ncrypt
PE 0000000244fc0000-0000000244fce000 Deferred userenv
PE 0000000250cd0000-0000000250cef000 Deferred mpr
PE 0000000251d80000-0000000251e0d000 Deferred winex11
PE 0000000259060000-000000025906d000 Deferred dhcpcsvc
PE 000000025dc30000-000000025dc3e000 Deferred version
PE 0000000263650000-0000000263683000 Deferred propsys
PE 0000000267930000-000000026793b000 Deferred psapi
PE 000000026c190000-000000026c19c000 Deferred nsi
PE 000000026c230000-000000026c266000 Deferred uxtheme
PE 000000027a8e0000-000000027a915000 Deferred d3d9
PE 0000000284ea0000-0000000284ead000 Deferred powrprof
PE 00000002945e0000-00000002946a4000 Deferred winmm
PE 0000000296590000-00000002965a7000 Deferred dnsapi
PE 000000029db00000-000000029db3e000 Deferred uiautomationcore
PE 00000002a2380000-00000002a23db000 Deferred shlwapi
PE 00000002bb0a0000-00000002bb120000 Deferred gdi32
PE 00000002bde30000-00000002bde4a000 Deferred shcore
PE 00000002c73a0000-00000002c73d9000 Deferred win32u
PE 00000002c7470000-00000002c7532000 Deferred ucrtbase
PE 00000002e0d50000-00000002e0d60000 Deferred hid
PE 00000002eb680000-00000002eb6a8000 Deferred jsproxy
PE 00000002ee630000-00000002ee648000 Deferred bcrypt
PE 00000002ef230000-00000002ef23e000 Deferred dwmapi
PE 00000002fb3c0000-00000002fb508000 Deferred comctl32
PE 0000000302d10000-0000000302d1b000 Deferred msimg32
PE 000000030b860000-000000030b8cf000 Deferred d3d11
PE 0000000313390000-00000003133ae000 Deferred compstui
PE 000000031c5d0000-000000031c62c000 Deferred combase
PE 0000000345640000-00000003456bf000 Deferred wininet
PE 0000000351a60000-0000000351a80000 Deferred msacm32
PE 0000000360d70000-0000000360d9b000 Deferred dxva2
PE 0000000367600000-0000000367860000 Deferred wined3d
PE 0000000368420000-00000003684ab000 Deferred rpcrt4
PE 0000000370f70000-0000000370f98000 Deferred ws2_32
PE 0000000393730000-000000039374a000 Deferred imm32
PE 0000000394ba0000-0000000394bae000 Deferred wtsapi32
PE 00000003982d0000-0000000398307000 Deferred iphlpapi
PE 00000003afef0000-00000003aff11000 Deferred secur32
PE 00000003b8910000-00000003b8954000 Deferred oleacc
ELF 00007fb839c60000-00007fb839cb4000 Deferred libgssapi_krb5.so.2
ELF 00007fb839cb4000-00007fb839cbb000 Deferred libkeyutils.so.1
ELF 00007fb839cbb000-00007fb839cc9000 Deferred libkrb5support.so.0
ELF 00007fb839cc9000-00007fb839ccf000 Deferred libcom_err.so.2
ELF 00007fb839ccf000-00007fb839cfd000 Deferred libk5crypto.so.3
ELF 00007fb839cfd000-00007fb839dd5000 Deferred libkrb5.so.3
ELF 00007fb839ded000-00007fb839df6000 Deferred kerberos.so
ELF 00007fb839df6000-00007fb839e01000 Deferred secur32.so
ELF 00007fb839e01000-00007fb839f36000 Deferred opengl32.so
ELF 00007fb839f36000-00007fb839f5c000 Deferred libgpg-error.so.0
ELF 00007fb839f5c000-00007fb839f7c000 Deferred libgcc_s.so.1
ELF 00007fb839f7c000-00007fb839f9e000 Deferred liblz4.so.1
ELF 00007fb839f9e000-00007fb83a0e6000 Deferred libgcrypt.so.20
ELF 00007fb83a0e6000-00007fb83a0f2000 Deferred libcap.so.2
ELF 00007fb83a0f2000-00007fb83a0fd000 Deferred libffi.so.8
ELF 00007fb83a0fd000-00007fb83a1df000 Deferred libsystemd.so.0
ELF 00007fb83a1df000-00007fb83a282000 Deferred libgmp.so.10
ELF 00007fb83a282000-00007fb83a2cb000 Deferred libhogweed.so.6
ELF 00007fb83a2cb000-00007fb83a31f000 Deferred libnettle.so.8
ELF 00007fb83a31f000-00007fb83a336000 Deferred libtasn1.so.6
ELF 00007fb83a336000-00007fb83a4f0000 Deferred libunistring.so.5
ELF 00007fb83a4f0000-00007fb83a512000 Deferred libidn2.so.0
ELF 00007fb83a512000-00007fb83a5e2000 Deferred libzstd.so.1
ELF 00007fb83a5e2000-00007fb83a686000 Deferred libbrotlienc.so.1
ELF 00007fb83a686000-00007fb83a7b9000 Deferred libp11-kit.so.0
ELF 00007fb83a7b9000-00007fb83a7be000 Deferred libdl.so.2
ELF 00007fb83a7be000-00007fb83a80f000 Deferred libdbus-1.so.3
ELF 00007fb83a80f000-00007fb83aa0d000 Deferred libgnutls.so.30
ELF 00007fb83aa0d000-00007fb83aa21000 Deferred libavahi-client.so.3
ELF 00007fb83aa21000-00007fb83aa2f000 Deferred libavahi-common.so.3
ELF 00007fb83aa2f000-00007fb83aacc000 Deferred libcups.so.2
ELF 00007fb83aacc000-00007fb83aade000 Deferred libresolv.so.2
ELF 00007fb83aadf000-00007fb83aae5000 Deferred crypt32.so
ELF 00007fb83aae5000-00007fb83aaf0000 Deferred bcrypt.so
ELF 00007fb83aaf0000-00007fb83aaf6000 Deferred dwrite.so
ELF 00007fb83ab3c000-00007fb83ab44000 Deferred libxfixes.so.3
ELF 00007fb83ab44000-00007fb83ab50000 Deferred libxcursor.so.1
ELF 00007fb83ab50000-00007fb83ab64000 Deferred libxi.so.6
ELF 00007fb83ab64000-00007fb83ab69000 Deferred libxcomposite.so.1
ELF 00007fb83ab69000-00007fb83ab76000 Deferred libxrandr.so.2
ELF 00007fb83ab76000-00007fb83ab83000 Deferred libxrender.so.1
ELF 00007fb83ab83000-00007fb83ab8a000 Deferred libxxf86vm.so.1
ELF 00007fb83ab8a000-00007fb83ab8f000 Deferred libxinerama.so.1
ELF 00007fb83ab8f000-00007fb83ab97000 Deferred libxdmcp.so.6
ELF 00007fb83ab97000-00007fb83ab9c000 Deferred libxau.so.6
ELF 00007fb83ab9c000-00007fb83abc7000 Deferred libxcb.so.1
ELF 00007fb83abc7000-00007fb83ad0a000 Deferred libx11.so.6
ELF 00007fb83ad0a000-00007fb83ad1f000 Deferred libxext.so.6
ELF 00007fb83ad20000-00007fb83ad25000 Deferred libpthread.so.0
ELF 00007fb83ad25000-00007fb83ad2b000 Deferred winspool.so
ELF 00007fb83ad2b000-00007fb83ad30000 Deferred dnsapi.so
ELF 00007fb83ad30000-00007fb83ad37000 Deferred ws2_32.so
ELF 00007fb83ad37000-00007fb83adc8000 Deferred winex11.so
ELF 00007fb83af94000-00007fb83afbf000 Deferred libexpat.so.1
ELF 00007fb83afbf000-00007fb83b00e000 Deferred libfontconfig.so.1
ELF 00007fb83b00e000-00007fb83b0a9000 Deferred libpcre2-8.so.0
ELF 00007fb83b0a9000-00007fb83b0cc000 Deferred libbrotlicommon.so.1
ELF 00007fb83b0cc000-00007fb83b20b000 Deferred libglib-2.0.so.0
ELF 00007fb83b20b000-00007fb83b305000 Deferred libharfbuzz.so.0
ELF 00007fb83b305000-00007fb83b3e2000 Deferred libfreetype.so.6
ELF 00007fb83b3e2000-00007fb83b4ca000 Deferred libm.so.6
ELF 00007fb83b4ca000-00007fb83b68a000 Deferred win32u.so
ELF 00007fb83b98a000-00007fb83bb00000 Dwarf libwine.so.1
ELF 00007fb83bf01000-00007fb83bf24000 Deferred libgraphite2.so.3
ELF 00007fb83bf24000-00007fb83bf32000 Deferred libbrotlidec.so.1
ELF 00007fb83bf32000-00007fb83bf6b000 Deferred libpng16.so.16
ELF 00007fb83bf6b000-00007fb83bf7e000 Deferred libbz2.so.1.0
ELF 00007fb83bf7e000-00007fb83bf98000 Deferred libz.so.1
ELF 00007fb83bf98000-00007fb83bfcb000 Deferred liblzma.so.5
ELF 00007fb83bfcb000-00007fb83bfe4000 Deferred libunwind.so.8
ELF 00007fb83bfe4000-00007fb83c0ab000 Deferred ntdll.so
ELF 00007fb83c2af000-00007fb83c2e4000 Deferred ld-linux-x86-64.so.2
Threads:
process tid prio name (all IDs are in hex)
00000038 services.exe
0000003c 0
00000040 0 wine_rpcrt4_server
0000004c 0 wine_rpcrt4_io
00000070 0 wine_rpcrt4_io
000000a0 0 wine_rpcrt4_io
000000b8 0 wine_rpcrt4_io
000000dc 0 wine_rpcrt4_io
000001d4 0 wine_rpcrt4_io
00000044 winedevice.exe
00000048 0
00000054 0
00000058 0 wine_sechost_service
0000005c 0
00000060 0
00000064 0
000000c4 0
00000068 winedevice.exe
0000006c 0
00000074 0
00000078 0 wine_sechost_service
0000007c 0
00000088 0
0000008c 0
00000098 0
0000009c 0
00000080 explorer.exe
00000084 0
000000c8 0
000000cc 0 wine_rpcrt4_server
00000090 plugplay.exe
00000094 0
000000a4 0
000000a8 0 wine_sechost_service
000000ac 0 wine_rpcrt4_server
00000188 0 wine_rpcrt4_io
00000190 0 wine_threadpool_worker
000000b0 svchost.exe
000000b4 0
000000bc 0
000000c0 0 wine_sechost_service
000000d4 rpcss.exe
000000d8 0
000000e4 0
000000e8 0 wine_sechost_service
000000ec 0 wine_rpcrt4_server
000000f0 0 wine_rpcrt4_server
000000f4 0 wine_rpcrt4_io
000000fc conhost.exe
00000100 0
00000104 XPG-Prime.exe
00000108 0 Main
0000010c 0 wine_threadpool_worker
00000110 0 BrokerEvent
00000114 0 Chrome_IOThread
00000118 0
0000011c 0
00000120 0
00000124 0
00000128 0
0000012c 0
00000130 0
00000134 0
00000138 0 XPG - ENE-HAL
0000013c 0 DnsConfigService
00000140 0 wine_threadpool_waitqueue
00000144 0 TaskSchedulerServiceThread
00000148 0 TaskSchedulerForegroundWorker
0000014c 0 TaskSchedulerForegroundBlockingWorker
00000150 0 TaskSchedulerForegroundBlockingWorker
00000154 0 TaskSchedulerForegroundBlockingWorker
00000158 0 TaskSchedulerForegroundBlockingWorker
0000015c -2 TaskSchedulerBackgroundWorker
00000160 -2 TaskSchedulerBackgroundBlockingWorker
00000164 -2 TaskSchedulerBackgroundBlockingWorker
00000168 -2 TaskSchedulerSingleThreadSharedBackgroundBlocking0
0000016c 0 CompositorTileWorker1/364
00000170 0 TaskSchedulerSingleThreadForegroundBlocking1
00000174 0 AudioThread
00000180 0 wine_sechost_device_notify
00000184 0 VideoCaptureThread
0000018c 0
00000194 0 TaskSchedulerSingleThreadCOMSTASharedForeground2
00000198 0 wine_rpcrt4_server
0000019c -2 TaskSchedulerBackgroundBlockingWorker
000001a0 0 CacheThread_BlockFile
000001ac 0 wine_mmdevapi_notification
000001b0 15 winepulse_mainloop
000001b4 15 winepulse_timer_loop
000001b8 0
0000024c 0 winealsa_midi_notify
00000270 15 System
00000274 0 Group 0
00000278 0 CPU 0
0000027c 0 CPU 1
00000280 0 CPU 2
00000284 0 CPU 3
00000288 0 CPU 4
0000028c 0 CPU 5
00000290 0 CPU 6
00000294 0 CPU 7
00000298 0
0000029c 0
000002ac 0 TaskSchedulerForegroundBlockingWorker
000002b4 0 TaskSchedulerForegroundBlockingWorker
00000178 XPG-Prime.exe
0000017c 0 CrGpuMain
000001c8 0 wine_threadpool_worker
000001cc 0 BrokerEvent
000001d0 0 Watchdog
00000224 0 wined3d_cs
00000228 0 TaskSchedulerServiceThread
0000022c 0 TaskSchedulerForegroundWorker
00000230 0 TaskSchedulerForegroundBlockingWorker
00000234 -2 TaskSchedulerBackgroundWorker
00000238 -2 TaskSchedulerBackgroundBlockingWorker
0000023c 0 Chrome_ChildIOThread
00000240 0 wine_threadpool_waitqueue
00000244 0 wine_threadpool_worker
000001a4 (D) C:\Program Files\XPG\XPG-Prime\XPG-Prime.exe
000001a8 0 <== CrRendererMain
000001e4 0 wine_threadpool_worker
000001e8 0 BrokerEvent
000001ec 0 TaskSchedulerServiceThread
000001f0 0 TaskSchedulerForegroundWorker
000001f4 0 TaskSchedulerForegroundBlockingWorker
000001f8 -2 TaskSchedulerBackgroundWorker
000001fc -2 TaskSchedulerBackgroundBlockingWorker
00000200 0 Chrome_ChildIOThread
00000204 0 wine_threadpool_waitqueue
00000208 0 GpuMemoryThread
0000020c 0 Compositor
00000210 0 CompositorTileWorker1/528
00000214 0 CompositorTileWorker2/532
00000218 0 CompositorTileWorker3/536
0000021c 0 CompositorTileWorker4/540
00000220 -2 CompositorTileWorkerBackground/544
000002a0 0
000002a4 0 TaskSchedulerForegroundWorker
000002a8 0 TaskSchedulerForegroundWorker
000002b0 0 TaskSchedulerForegroundWorker
000002b8 0 TaskSchedulerForegroundWorker
000002bc 0 TaskSchedulerForegroundWorker
000002c0 0 TaskSchedulerForegroundWorker
000002c4 0
000002c8 0
000002cc 0
000002d0 0
000002dc 0
000001c0 winedevice.exe
000001c4 0
000001d8 0
000001dc 0 wine_sechost_service
000001e0 0
System information:
Wine build: wine-8.2
Platform: x86_64
Version: Windows 10
Host system: Linux
Host version: 6.2.1-arch1-1
No i don’t use bottles… or wine.
Okay other users use that softwares they will help me i think.
i saw its used for gaming or running windows software but i got error IDK i did it wrong or this XPG software doesn’t work on WINE.
I use a mechanical keyboard that has RGB backlighting that has it’s own built in firmware so i don’t need other software to make it work. All the features work from the keyboard itself.
If you PASSTHROUGH a device to A VM, the HOST CANNOT use the device. It’s illogical otherwise.
Ya i want to do this so my keyboard only works on my vm. What is the point of that?
