USB mouse/keyboard fail to start on boot for minutes
For the past week or so when I boot my system my keyboard and mouse have no connection and I can’t do anything. If I wait for a few minutes, they eventually “turn on” and connect and everything is then good to go.
I’ve found the following errors after reading around for some commands to explore what’s going on:
May 07 08:46:40 cyan kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
May 07 08:46:41 cyan kernel:
May 07 08:46:44 cyan kernel: snd_hda_intel 0000:10:00.6: no codecs found!
May 07 08:46:49 cyan kernel: usb 1-7: device descriptor read/64, error -110
May 07 08:47:04 cyan kernel: usb 1-7: device descriptor read/64, error -110
May 07 08:47:10 cyan kernel: usb 1-7: device descriptor read/64, error -110
May 07 08:47:25 cyan kernel: usb 1-7: device descriptor read/64, error -110
May 07 08:47:36 cyan kernel: usb 1-7: device not accepting address 6, error -71
May 07 08:47:46 cyan kernel: usb 1-7: device not accepting address 7, error -71
May 07 08:47:46 cyan kernel: usb usb1-port7: unable to enumerate USB device
May 07 08:47:48 cyan kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
May 07 08:47:53 cyan kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
May 07 09:00:55 cyan kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
Looking up error -110 and -71 it seems that maybe this is a power issue? This is a recent new computer build and I’ve not had any errors up until the past week. I have a second hard drive I can boot windows in, and I never have the issues there.
Motherboard is MSI MAG B650 Tomahawk. I have a 850w corsair power supply. No other peripherals right now other than keyboard and mouse. I ran the latest system updates yesterday and still same problem.
The fact I have none of these issues in windows makes me feel something is not getting properly started on boot, but I’m no expert in this stuff. Any ideas for fix or further troubleshooting?
To get help, please follow this:
Taken from this post on the forum:
Here is the inxi output, thanks
https://0x0.st/X8mn.txt
